RaceCity
Joined: 7/10/2002 From: NotUpNorth, USA Status: offline
I'm pretty confident I know what oil X-Jet is running. If it's what I think it is....it's not a LV oil (and he doesn't say it is). I've been using the same thing now for a while. I have no way of measuring the actual viscosity of the oil, but subjectively it's about the same as castor. Pretty heavy. My only gripe about this oil is poor smoke. Probably a good indication that it's not burning up in the engine too. That's a positive! The stuff is awesome from what I can tell, even in lower-than-normal concentrations. It just doesn't give up, and I'm a die-hard synthetic hater from way back. I do however like to run a small percentage of Klotz KL200 in my high castor (FOX) fuel just because it makes a convenient dye, and I absolutely love the smell of the stuff. Mmmmmmmm With all that being said, Another poster commented that the use of LV oils (or any other oil for that matter) is clouded in BS, mock-science, and more than a smattering of marketing hype. Very true. Unless one is a chemist....at the end of the day you'd be just as well off to ask a nun at the corner church for an oil recommendation, so confused you'll be. LV oils to me seem like just another gimmick. Maybe they're the greatest thing since sliced bread, but I sure haven't seen it. The fuels with the LV oils obviously work...at least for awhile. I suppose if you run enough of anything it'll work. A good oil (for real), that is appropriate for the type motor being run (ABC/ABX, ringed, lapped, bushed) will always win the day...even after the magazine ads, and trophy waving mug shots of "Joe Pro" are long forgotten.
< Message edited by RaceCity -- 7/16/2007 4:05:17 PM >
_____________________________
AMA 63990
