StoneColdFreak
Joined: 7/14/2007 From: Enterprise, AL, USA Status: offline
I am in the market for a Tamiya Leopard and I want to add some of these upgrades at the beginning when I build, rather than replacing stock parts later. If you have any opinions about which ones are a good upgrade or which ones are unnecessary, please let me know: Bearings; hobby shop guy told me the kit comes with bearings, but are there also brass bushings? No bushings for me, thanks. Accurate metal barrelfrom Tamiya (53761); stock is metal, but not as detailed, right? Barrel Stabilizer; a must for realism and easier to install during the build or easy enough to drop in later? Metal tracks; it just doesn't feel like a tank to me without metal tracks. I read that there have been issues with the lower hull not staying square and that some sort of brace may be needed. True? Suspension arms; the metal set are supposed to be a nice upgrade from the stock plastic. Metal storage baskets; even though the etched screen is metal, the frame is plastic and seems like a weak point (if you drive it like I plan to drive). Metal Upgrade Set (Mirrors, Tow Coupler, Track Holders & Handles, Track Adjusters, MG3 Turret Machine Gun, Gun Travel Lock Kit, Tow Shackles & Bolts, Tow Cables, Headlights & Blinkers, Side Steps, Turret Handles and 4 Piece Tool Set.) There are a lot of items in the set that I want to install before adding the camo paint job. Even though it is $400.00, I still want to get it right away, if possible. As far as the battle system goes, there are no other tankers around, so that is why it was omitted from the list. I just want the tank to look and feel as realistic as I can make it-except for the speed. I would rather control the speed with my driving, rather than install gear reductions or inline diodes. There you have it, my naive plans for a Leopard 2 A6. I could really use someone's experienced opinion. If you have a comment, it is welcome. Chad
< Message edited by StoneColdFreak -- 7/15/2007 2:26:08 AM >
_____________________________
A computer once beat me at chess, but it was no match for me at kick boxing.
