RE: New Great Planes Revolver    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: New Great Planes Revolver
Page: <<   < prev  98 99 [100] 101 102 103 104 105 106 107   next >   >>
Login
RE: New Great Planes Revolver - 1/30/2010 8:46 PM
airraptor
Score: 131
Last Login: 6/20/2013
Status: offline
here are some pics of mods not finished with covering lol i suck at coming up with a design.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
(in reply to airraptor)
       Post #: 2476
RE: New Great Planes Revolver - 1/30/2010 10:13 PM
jet22b
Score: 110
Status: offline
Looking good, airraptor!!!!
One quick question?? What is the rear hatch for???
When you finish, she is going to be "sick"!!!!
Sonny
aka
jet22b
Spitfire Brotherhood #12
P-40 Brotherhood #52
Hide Signatures
       Post #: 2477
RE: New Great Planes Revolver - 1/31/2010 2:58 AM
airraptor
Score: 131
Status: offline
the rear hatch is where the HT elevator servo is. i have the linkage short and inside the plane to help reduce some drag some. flown yesterday and today. with out the cowl. and the stock gear. she was fast but still has more left once i get the cowl on and the wire skid on it.
I can also mount the pipe on it too if need more. with muffler it turns the 14x10 at 11,400 peak and set for about 11,000 for flight.
AMA # 186123
Hide Signatures
(in reply to jet22b)
       Post #: 2478
RE: New Great Planes Revolver - 1/31/2010 8:38 AM
mike boxtall
Score: 100
Last Login: 4/25/2013
Status: offline
Airraptor,
Just curious, your 120 ax spinning 13400 on the ground with the 13x13, OS advertises that the max rpm of that motor be only 10k. Your thoughts?
Club Saito Member #600
Hide Signatures
       Post #: 2479
RE: New Great Planes Revolver - 1/31/2010 8:44 AM
mike boxtall
Score: 100
Status: offline
My mistake the OS web site actually advertises it to be max output at 9500rpm.
Hide Signatures
(in reply to mike boxtall)
       Post #: 2480
RE: New Great Planes Revolver - 1/31/2010 9:00 PM
airraptor
Score: 131
Status: offline
it wont turn that prop that fast i had wrong numbers on it. it turns it at 11,000 on the ground with muffler and around 12,200-12,400 with a pipe. APC 14x10 with muffler at 11,400.
OS has all the AX engine set up to turn larger props at low rpm to help reduce noise. Thats why they say max power at that rpm. the 35 AX we run 19,000 on 8x8, 95 AX at around 14,000 on 12x8. I did run a 14x14 full blade on the 120 with muffler and it turned it a 7,800 and was very very quite in the air.
AMA # 186123
Hide Signatures
       Post #: 2481
RE: New Great Planes Revolver - 2/4/2010 12:44 AM
airraptor
Score: 131
Status: offline
here it has one of the cowls on it. this is a extra one so i put it on for now till i get the other one done. the real one i took of the left side check and fiberglassed it in so it not out in the slip stream. it will be painted to match the plane once all done.
wire skid(s) is for a pylon type take off. or a hand launch straight up.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
AMA # 186123
Hide Signatures
       Post #: 2482
RE: New Great Planes Revolver - 2/4/2010 1:12 AM
mike boxtall
Score: 100
Status: offline
Airraptor,
Did you beef up the firewall or just leave it stock?
Hide Signatures
       Post #: 2483
RE: New Great Planes Revolver - 2/4/2010 2:02 AM
jet22b
Score: 110
Status: offline
Airraptor;
The engine was a good fit for the cowling. No major mod needed.
I looking at the pictures with the engine on the plane, I could not see if you had beef up the firewall for this motor.
I can not wait to hear how fast she fly!!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 2484
RE: New Great Planes Revolver - 2/4/2010 5:17 AM
airraptor
Score: 131
Status: offline
yeah you need to beef up the fire wall for any engine i think. some revolvers have dowled firewall some dont. doesnt matter they all come loose in time. i shortened up mine by 1/2 inch so could get the spinner closer to the cowl. even the saito 125 still stuck along way in front of cowl. I just sanded all around firewall and box structure, rounded corners then coated with epoxy, laid cloth on it from side to side and one more layer top to bottom. use wax paper to lay on top of glass squeeze out extra and let set up over night. oh yeah use small circle of masking tape to cover holes where screws go into blind nut. dont want epoxy in them. I also while redoing the wings took a acid brush and a large bowl of wood glue and went over every joint in the fues that is used to support the tank and firewall structure. let set over night then apply one more coat. adds alot of strength and very little weight.
I will try to get a radar this friday or weekend. no dive straight and level. hoping for 135-140
AMA # 186123
Hide Signatures
       Post #: 2485
RE: New Great Planes Revolver - 2/4/2010 5:28 AM
jet22b
Score: 110
Status: offline
Good luck on your first flight this weekend!!! I hope the speed will shock you!!!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 2486
RE: New Great Planes Revolver - 2/4/2010 5:50 AM
airraptor
Score: 131
Status: offline
thanks i did fly it last weekend. . i am guessing around 125 or so with the stock landing gear and no cowl on it. i was doing knife edge passes at full throttle. just an ever so slight rudder stick movement. I will see if i can get some video of it too.
AMA # 186123
Hide Signatures
       Post #: 2487
RE: New Great Planes Revolver - 2/4/2010 6:08 AM
albsurfer
Score: 100
Status: offline
airraptor, I favour using a little Titebond wood glue in the fuse and any hard-to-reach place that CA or epoxy is really difficult to put in place. The warbird guys at my field are too into using only CA and epoxy, to the point of using the CA wick extension and spraying CA down the inside of the fuselage to try and get the stringers and braces to stick better. It doesn't even look like it gets to most of the actual joints that they try to hit. An acid brush dipped in Titebond taped to a dowel works great for getting down the fuse to hard to reach joints, stringers, etc. provides great strength with little weight.
Hide Signatures
       Post #: 2488
RE: New Great Planes Revolver - 2/4/2010 6:22 AM
fanoffive0
Score: 100
Last Login: 6/17/2013
Status: offline
What radar gun are you using?
Hide Signatures
       Post #: 2489
RE: New Great Planes Revolver - 2/4/2010 8:13 AM
airraptor
Score: 131
Status: offline
I dont know what kind it is.i was just guessing off some of the other planes that were there that have been radared. my last revolver did 136 in slight dive at the gun. this one is faster with cowl off. we put the other one at 120 level. maybe MR. APC will be out this week with his gun and can get some good times.
AMA # 186123
Hide Signatures
(in reply to fanoffive0)
       Post #: 2490
RE: New Great Planes Revolver - 2/4/2010 10:02 AM
Kostas1
Score: 330
Last Login: 6/18/2013
Status: offline
Airraptor,
the fit of the 120AX is good.
Also i guess the *speed numbers* are good too.
Only thing that IMO doesn't fit is the covering job you did.
The stock monokote trim looked good to me ,
but that's my .02$.
I,too,
am waiting for a video or even more pictures!
<==**Check my gallery for more pictures**
Club Saito member #706
Hide Signatures
       Post #: 2491
RE: New Great Planes Revolver - 2/4/2010 11:26 AM
airraptor
Score: 131
Status: offline
well any arf stock covering will peel and come loose or let oil into the airframe. yes i like the look of the stock one too but it wasnt about looks here. i had to redo the wing to the way i thought it should be for speed, made a new tail, and so on. even though i didnt come up with a super nice looking plane it will last much longer than a stock one would. i know all the failure points on this plane and i fixed all them. but now thats its going much faster i might find another failure. fingers crossed. when i fly tomorrow or friday. i will take it up till i almost cant see it then full throttle staright down. if she hold up then i can do anything to it. i have done that already but that was with the wheels and no cowl.
AMA # 186123
Hide Signatures
(in reply to Kostas1)
       Post #: 2492
RE: New Great Planes Revolver - 2/4/2010 11:55 PM
airraptor
Score: 131
Status: offline
well flew it today only one flight before it started to rain. the wire skid gear set up isnt working like i thought it would. noses over on landing and very hard to get to take off. may have to put the gear back on it. or try some thing else. i have tried the race wheels on the gear but its to week to hold up. i might have to try an aluminum set with race wheels.
AMA # 186123
Hide Signatures
       Post #: 2493
RE: New Great Planes Revolver - 2/5/2010 12:23 AM
albsurfer
Score: 100
Status: offline
the skid is probably making it bounce too much because of the built-in spring of the metal, and the drag involved when it touches the ground. If there is a breeze when you radar it next time, do one measurement up-wind, then one down-wind, and average them. It should be within 1 mph of a dead-calm run. The run should be at level flight, not even a slight dive or descent. We usually take the measurement 3 seconds after snapping out of a dive and going to level flight. The width of the cowl sticking out from the airframe may be the cause of too much drag, as compared to running it without the cowl. The Revolver has "cheeks". The spinner actually breaks a fair amount of wind around the fuse of a smaller airframe if you don't use too small a diameter.
Hide Signatures
       Post #: 2494
RE: New Great Planes Revolver - 2/5/2010 12:40 AM
airraptor
Score: 131
Status: offline
with cowl on it will be faster. i have another cowl that i am removing one of the cheeks on it and the other side has the engine sticking out in it. i am guessing 130-135 on a pylon course with no dive at all. i will play with props some more. today it was on the 13x13
AMA # 186123
Hide Signatures
(in reply to albsurfer)
       Post #: 2495
RE: New Great Planes Revolver - 2/15/2010 1:34 AM
Nitrodan73
Score: 100
Last Login: 12/23/2012
Status: offline
Does anyone have any of the original landing gear for this plane? I'm also looking for wheel pants as well. Please send me a PM if you're interested in selling them.
Hide Signatures
       Post #: 2496
RE: New Great Planes Revolver - 2/15/2010 2:11 AM
microdon2
Score: 110
Status: offline
Click to learn more about the advantages of upgrading your membership here at RC Universe
Score: 100
Last Login: 2/13/2010
Status: online Just finished building my new Rev 70 - have an OS 91 2S in it and high-torque HS-636 Hitachi servos. Also replaced the stock gear (front and rear) with Dubro gear - MUCH stronger, though not as sleek (did the same on my two 59" Revolvers, one an OS 70 4S, the other an OS 61 2S.). Had the same problems as everyone else of these gear breaking or ripping out WAY too easily (especially considering the overall sturdiness of the rest of the plane), so decided to swap all out, and am VERY happy I did! My airfield is a little rough, and I've had some less than stellar landing, and these Dubro's gear handle them easily. Had to paint the gear white (with fuel proof paint), then added three layers of trim, corresponding to the color of the plane. Also, since the main gear does not "sweep back" like the stock one, and for better appearance, I moved the mounting point back about 3". To do that I installed all new flooring (with 1/4 think hardwood strips) on the inside and 30 min epoxy to weld it in place. Then installed T-nuts - works great. Tomorrow morning the weather looks good (28 deg, 10 mph from NW) so I'll be flying my new Rev 70 for the first time - in the snow. (also installed skis last night). btw - I hate cold hands, too, which is why I spent $70 on a "Radiowarm" - covers the hands and radio - worth twice what I paid. Now I LOVE flying in the cold! Specially taking off and landing on snow. Plus, MUCH less competition for the airfield! Will post pics soon.
Hide Signatures
(in reply to Nitrodan73)
       Post #: 2497
RE: New Great Planes Revolver - 2/15/2010 4:50 AM
airraptor
Score: 131
Status: offline
i should have three sets of wheel pants if you want them. Free just pay shipping send a pm If want them
AMA # 186123
Hide Signatures
(in reply to microdon2)
       Post #: 2498
RE: New Great Planes Revolver - 2/15/2010 6:16 AM
airraptor
Score: 131
Status: offline
He is some video of my latest revolver flying. i am in the tan shirt and blue jeans. the plane is the one pictured at top of this thread. sorry camera man could see mine to well so didnt follow it to much except in first part and neqr middle.
http://www.youtube.com/watch?v=f3Lyo_44q3M
AMA # 186123
Hide Signatures
       Post #: 2499
RE: New Great Planes Revolver - 2/15/2010 6:40 AM
jet22b
Score: 110
Status: offline
airraptor;
I just watch your vid and I must say, the group was having to much fun!!! I saw in one pass, you blew the doors off of the Hangar 9 Blue Nose P-51!!!! If that was a air race, who won??? Just the sound of all the planes in the air was sweet!! Thank you for sharing the vid!! I am going back to watch it again!!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 2500
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.891RCU1
