RE: Build Thread Herr P51
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: Build Thread Herr P51
Page: <<   < prev  1 2 [3]
Login
RE: Build Thread Herr P51 - 6/26/2008 5:24:52 PM
Mr Cox
Status: online
quote:
ORIGINAL: unclecrash
quote:
ORIGINAL: Mr Cox
How much weight does the glassing add?
I think about 2oz for the wing. Thats using epoxy thinned could save weight with polyurethane finish. But I just like the durability and strength of epoxy.
Does it really add 2 oz (!) or is that the total weight?
(in reply to unclecrash)
       Post #: 51
RE: Build Thread Herr P51 - 6/30/2008 5:10:33 AM
corbystarlet11
Status: offline
Hey, Im liking this kit your building. i've nearly finnished my First build, Herr AT-6 Teaxn and its going together very well, After this i will try and find this kit to build, Thanks for the great forum you have going here.
_____________________________
The Propeller is like a fan to a Pilot because when it stops he starts to sweat.
(in reply to Mr Cox)
       Post #: 52
RE: Build Thread Herr P51 - 6/30/2008 6:07:47 PM
unclecrash
Status: offline
quote:
ORIGINAL: corbystarlet11
Thanks, I got the kit from a friend who used to work at our LHS. Then I put it on FleaBay but no one wanted it so I decided to build it.
I Ain't Buildin No TuG Boats
(in reply to corbystarlet11)
       Post #: 53
RE: Build Thread Herr P51 - 7/1/2008 6:00:38 AM
unclecrash
Status: offline
I got the fuse glassed. Wrapped one piece all the way around no bubbles.
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 54
RE: Build Thread Herr P51 - 7/1/2008 11:46:11 PM
unclecrash
Status: offline
A quick mock up.
Click for fullsize
Click for fullsize
< Message edited by unclecrash -- 7/1/2008 11:53:46 PM >
       Post #: 55
RE: Build Thread Herr P51 - 7/3/2008 4:01:40 AM
unclecrash
Status: offline
Well I cut the aileron's to size. I have to get the hinges and some glue. I found the frame for the scoop in the box. It got squashed so I had to rebuild it. Maybe tomorrow I will go to lhs and get some glue and hinges.
Click for fullsize
       Post #: 56
RE: Build Thread Herr P51 - 7/4/2008 3:55:52 AM
unclecrash
Status: offline
Chipping away at her. I added a little hatch to the bottom of the scoop to access the wing bolts. Then glued the scoop on. Just need to glass over it.
Click for fullsize
Click for fullsize
< Message edited by unclecrash -- 7/4/2008 4:08:51 AM >
       Post #: 57
RE: Build Thread Herr P51 - 7/5/2008 4:13:06 AM
unclecrash
Status: offline
I slotted the wing for the ailerons and sanded them down. Im going to glass them and the scoop next.
Click for fullsize
Click for fullsize
       Post #: 58
RE: Build Thread Herr P51 - 7/5/2008 8:34:31 PM
jeffie8696
Status: offline
Rock ON! I'm watching.
Castor, its like Vitamin C for glow engines. I am not Dom from Airwolf but I do resemble him.......Unfortunately
       Post #: 59
RE: Build Thread Herr P51 - 7/9/2008 12:25:48 AM
unclecrash
Status: offline
I glassed the scoop today. Also the ailerons and the bottom hatch got glassed.
Click for fullsize
Click for fullsize
(in reply to jeffie8696)
       Post #: 60
RE: Build Thread Herr P51 - 7/16/2008 3:56:36 AM
unclecrash
Status: offline
Well I had to put the P51 on the back burner for a bit. A friend just gave me this CG SHOCK 3D so I did a convert from electric to glow. I put my AP.09 in it. I Had everything to slap it together so I did it.
Click for fullsize
Click for fullsize
       Post #: 61
RE: Build Thread Herr P51 - 7/16/2008 6:29:05 AM
somegeek
Status: offline
Great looking build!
Fly safe, have fun. Measure three times, cut once. The man who makes no mistakes does not usually make anything.
       Post #: 62
RE: Build Thread Herr P51 - 7/16/2008 6:43:55 AM
unclecrash
Status: offline
quote:
ORIGINAL: somegeek
Not sure if your talkin about the P51 or CG SHOCK 3D But thanks just the same.
(in reply to somegeek)
       Post #: 63
RE: Build Thread Herr P51 - 7/16/2008 3:15:25 PM
jeffie8696
Status: offline
Allowing a sport plane to interfere with the build of a warbird!!! Man, that just ain't right.
OH I'm still watching you Bub.
       Post #: 64
RE: Build Thread Herr P51 - 7/16/2008 3:45:15 PM
somegeek
Status: offline
quote:
ORIGINAL: somegeek
I was referring to the P51... though it's refreshing to see an electric converted to glow.
somegeek
