which radio for trex 450se
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> which radio for trex 450se
Page: [1]
Login
which radio for trex 450se - 7/19/2007 5:27 PM
selena1718
Score: 100
Last Login: 8/2/2009
Status: offline
hi just bought a trex 450se, which radio will go good with that and what reciever, only have 250.00 to spend on radio hoping it comes with servos ,reciever i have about 80.00 for that, any suggestions thanks
Hide Signatures
       Post #: 1
RE: which radio for trex 450se - 7/19/2007 5:44 PM
gixxernoob
Score: 100
Last Login: 2/28/2010
Status: offline
DX6 if you are on a budget its around 199.00 w/servos and ar6000 receiver. I used the servos on the cyclic for about 20 flights and eventually replaced it. however a DX7 transmitter only and a ar6000 receiver would be around 270 that is w/o servos.
_____________________________
Land: AX10, Savage 25, RS4 (Seattle Mariners FTW)
Air: Blade CX2, Trex 450se/500, T-28, Stryker
Hide Signatures
(in reply to selena1718)
       Post #: 2
RE: which radio for trex 450se - 7/19/2007 6:42 PM
HeliTB
Score: 100
Last Login: 3/8/2010
Status: offline
For thes best results you are going to want to use Hitec 65 on a budget the HB will work fine, if you have more to spend get the MG gear. Radio choice is preference, if you feel you may later get a nitro heli you want a radio that will support 7 channels. The most popular are 2.4ghz Spread Sprectrum Technology based radios.
Raptor v2 OS 37/Bobcat Jet OS .55 AX
Extra 330L 25% SV26cc/SIG Kougar OS .46 AX
Hide Signatures
(in reply to gixxernoob)
       Post #: 3
RE: which radio for trex 450se - 7/23/2007 11:01 PM
clink69
Score: 100
Last Login: 2/25/2010
Status: offline
DX6 is good. Dont waste your money on Non-MG servos , you will break them on a crash. The only ones that really hold up to repeated crashes are the HS65-mg. Ask me how I know... The servos with the DX6 are junk. If you call Hobbyzone , they will switch out the servos to the ones you want (e.g 4 crappies for 3 MGs) It may cost a few more $, but well worth it.
Hide Signatures
       Post #: 4
RE: which radio for trex 450se - 7/23/2007 11:45 PM
Synister
Score: 100
Last Login: 5/23/2009
Status: offline
The Futaba 6ex 2.4ghz offers a bit moe versatilityy than the DX6 (5point curves, full-range, etc.), while not costing as much as the DX7. However, it does not come with servos but like most everyone else has said, the ones that come with the DX6 or DX7 are pretty much garbage. Get the Futaba and a set of hs-65 servos and you are set for under $300.
Hide Signatures
(in reply to clink69)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
