Throttle cut twinengines
Is it possible to use the throttle cut when operating dual engines. Using channel 3 and channel 8 for each engine. I'm using Aux 2 and it's linked etc. When I hit the throttle cut switch only channel 3 operates. A cure/fix for this? thanks.
KY
RE: Throttle cut twinengines
You have to run a second mix - channel 8 and "Offset". The throttle cut function will only work with one channel - 3. The "Offset" slave needs to work with the same switch as you use for the throttle cut. It is possible to do what you want to do. Bax answered this a few months ago and it works fine. Do a search using "offset" and it'll give you all the details.
