RE: World Models 1/3 Super Cub
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: World Models 1/3 Super Cub
Page: <<   < prev  1 2 [3] 4 5 6 7   next >   >>
Login
RE: World Models 1/3 Super Cub - 1/21/2008 1:34:46 PM
Bosshossv8
Status: offline
The tail assembles easily, with a great dovetail joint. Easy, the linkages are good, but, I put CF tube over the Elevator and Rudder rods, to make them stronger, they seemed a little bendy to me.
The flying wires provided are heavy gauge coated, and are a B$@#%@ to get right , because they are so thick. Substitute lighter gauge to make it hassle free.
The wheels are Junk IMO, they are inflatable, but are too skinny for my liking, AND I ripped out one valve while pumping them up.
The DuBro 6 inch inflatables are perfect. Just the right amount of cushion.
I custom made the extensions to the back, and used a Y harness and extensions for the Flaps, there are dual servo holes on the left wing for the flap, so you can properly orient the flap servo if you are using a Y or separate channels. Watch this closely, get it right.
The gas tank 50oz fits in only one direction, on it's side, with the output hole in the hole of the firewall. I used it for the original build, and will be going to 2 32 oz tanks for gas and smoke. A lot more work. Actually, leaving the 50oz in and putting the 32 under the servo tray would be easier.....
The wingtubes were a tight fit, and the struts were tight too, I spent one whole day, for final fit, outside tweaking and adjusting.
THe top pilot shelf goes in only with the rear tilted up, and then it wiggles into place, I made mine removable.
The wingtube screws will P#%# you off, get differnet ones right away, Metric. Drill and tap the left ones. The right ones are already tapped and drilled.
The WM manual takes a swipe at the builder, it says something like this...
"Screw threaded wing bolts into one side (right) of tubes after assy, then IF ADVANCED PILOT, you can drill and use tapping tool to make same on other side....IF NOT ADVANCED PILOT, you drill and use self-tapping wood screws, be careful ,as BEGINNER PILOT will strip out these holes after a few uses. (It should also say, Our crappy screws will make sure of this). I tapped mine, I hate this method of holding on wings and stabs, ...hence in the re-build we did it with blind nuts, and anti-rotaiton pins on the root.
WOW,....talk about taking a swipe at the builder.....laughable.
Good luck, in three or four evening you should have it together.
_____________________________
"Are you brave enough to milk a Yak?"
(in reply to bignuts181)
       Post #: 51
RE: World Models 1/3 Super Cub - 1/28/2008 12:39:29 PM
rglass1144
Status: offline
I purchased the WM 1/3 Super Cub last fall . I have not purchased an engine for it yet. I plan on flying this model with some mild aerobatics and also would like slow flight ability. How much should the engine weigh to get it to balance? What size ( cc ) engine will work for this plane. Like I say, mild aerobatics. No unlimited verticle etc.
(in reply to Bosshossv8)
       Post #: 52
RE: World Models 1/3 Super Cub - 1/28/2008 1:02:35 PM
Bosshossv8
Status: offline
The Reccomended GT-80 twin form Zenoah fits well, and will do very spirited aerobatics. No unlimited vertical, but enough to barnstorm in a spirited fashion.
It needs 5-6 pounds on the nose. Some have said they put a G-62 with little or no weight, but IMO it would need weight up front unless you used the spring starter and a spinner...maybe even then some batteries up front.
But, this bird is 26 lbs, and I have a 24lber with a G-62, it barnstorms, but vertical is a stretch, it climbs but not with authority.
I guess this bird is a real chameleon, because you can dress it bunch of different ways, all according to your flying style.
THe GT-80 and this bird is the standard, and it won't disappoint, a differnt story if your at 5000msl , though. In MN, no problem.
(in reply to rglass1144)
       Post #: 53
RE: World Models 1/3 Super Cub - 2/5/2008 2:24:48 PM
Bosshossv8
Status: offline
WOO HOO....I got my 1/3 Super Cub back last nite from it's rebuild.
Man, this one is NOT a World Models anymore. ....it is built American Engineering style ,...to last.
I will pst pics of her tonite.
       Post #: 54
RE: World Models 1/3 Super Cub - 2/6/2008 8:18:28 AM
bignuts181
Status: offline
As heavy as a brick sh*t house......american caddy style
quote:
ORIGINAL: Bosshossv8
       Post #: 55
RE: World Models 1/3 Super Cub - 2/6/2008 12:43:41 PM
Bosshossv8
Status: offline
HaHa....heavy....no ...rebuilt forensicly correct by my good friend and secretary of our club RSM, Ted.
Unfortunately...or well, fortunately, I have no crash pics of the mishap/shredding through the trees. If you watch my touch and go video...imagine me dorking the approach way up high and blasting through the left two trees at tree-top height.
The 3W106 made it THROUGH the trees and into the field 150ft. The airframe tumbled down sllllllooooooowwlyyyy in multiple pieces.
The left wing was largely intact but beat up, the right wing was shattered, the fuse mid section was shattered, and the cabin was split top/bottom, firewall removed .
It sat in it's crash pile for 2 months. While I mourned. Ted took it, feeling sorry for me, and looking for a challenge, 3 1/2 months later.....Wa La.....
No plans, just forensic science.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 56
RE: World Models 1/3 Super Cub - 2/6/2008 12:51:02 PM
Bosshossv8
Status: offline
Here it is covered.
The final trim scheme is not reflected in these photos....when I can, I will get some shots of it as it is now....
It is a kind of like a hybrid clipped wing scheme, sunbursts, and invasion stripes.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 57
RE: World Models 1/3 Super Cub - 2/21/2008 10:02:37 PM
Whymee
Status: offline
I am in line for the next production run of the WM Super Cub. Due sometime in April.
Am in the process of bringing together all the major pieces parts to complete this build. I downloaded the manual and it sure does look sparse. So sparse that it did not list items needed to complete, or the specs for these items. Can anyone with a "real" manual give me specs on the servos?
I am also looking for a Gt-80 (or GT-74, Z445) at a reasonable price. Was going to use a 62 but I know they shake a good bit. I like the smooth twins. Any leads?
Has anybody checked into a big converted 4 stroke for this plane? Ideas? Thoughts? Rants welcomed too!
Blue Skies
Stan
WV
(in reply to Cyclic Hardover)
       Post #: 58
RE: World Models 1/3 Super Cub - 2/22/2008 2:30:35 AM
Bosshossv8
Status: offline
Use the best servos you can afford. While the 50oz tank is way overkill, it fits. Lots of room for smoke tank and pump., I think the tail wheel and landing gear are ripe for upgrades.
You will love this plane. The manual is definitely not for a first ARF builder, but it has the dimensions and basics in it.
(in reply to Whymee)
       Post #: 59
RE: World Models 1/3 Super Cub - 2/22/2008 11:04:11 AM
bignuts181
Status: offline
Hey there Boss and all, you know I was just looking over the shape and construction of the super cub and for all intensive puposes it looks a lot like a CMPRO cub in cinstruction, only much bigger.
       Post #: 60
RE: World Models 1/3 Super Cub - 2/22/2008 12:04:43 PM
rglass1144
Status: offline
The GT-80 will not fit under the cowling. The carburetor and intake manifold are too high. The top of the cowling would have to be cut open in order for it to fit plus the sides of the cowl have to be cut open for the jugs and spark plugs to fit. I looked and looked and there is not a twin 80 or even seventy that will fit inside of the cowl. I think the only reason the manufacturer suggests an 80 cc twin is for the weight of the engine. You need a boat anchor up front to get this thing to balance. I am using a Fuji 64 in mine. I had to add 1.2 pounds of dead weight to the firewall to get it to balance. It weights in at a total of 28 pounds like they suggest. It should have plenty of power for this airplane. Balsa USA 1/3 scale Supercub uses a 50 cc engine and it weights in at 35 pounds. And in addition to the Fuji 64 fitting inside the cowl, the engine costs far far less than the Fuji 86 or the Zenoah GT-80 or the ZDZ 80 twin. Plus it only uses one muffler. Mufflers are not cheap for these engines. This airplane does not require a high performance engine to fly and do mild aerobatics but I guess if flyers want unlimited verticle and hovering ability with a cub then I guess overpowering is the answer. But with a Cub? Next thing will be Edge 540 bush planes.
       Post #: 61
RE: World Models 1/3 Super Cub - 2/22/2008 12:30:01 PM
ROGER RUSSELL
Status: offline
WOW, I have a G62 in mine, built according to plans, (changed to H9 ball link pushrods)
4721 JR servos, 2.4 RX, 4500 6 volt battery.
Balanced just fine, no DEAD weight needed or added.
I realize this is about the SUPER CUB but identical planes.
Click for fullsize
< Message edited by ROGER RUSSELL -- 2/23/2008 11:45:48 PM >
Remember to FLY HARD and LAND SOFT
       Post #: 62
