RE: World Models 1/3 Super Cub
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: World Models 1/3 Super Cub
Page: <<   < prev  1 2 3 [4] 5 6   next >   >>
Login
RE: World Models 1/3 Super Cub - 5/6/2008 8:37:56 PM
rglass1144
Status: offline
Flew my WM 1/3 super cub yesterday for the first time. Flew fine with the Fuji 64A. Does loops from level flight, rolls, unlimited inverted, etc. I climbed very very high a couple of times and did some spins for a very long distance. The plane recovers very nicely from a spin and the size of this thing make the spins look good. Does not have unlimited verticle and I did not want it. It looks more realistic to pull into the verticle and climb until it can climb no more and then give it full left or right rudder to wing it over with smoke pouring out of it. Really floats when trying to land however. I don't know how you guys with big engines get them to come down without killing the engine. The Fuji 64A ran great with no problems at all. It started easily every time with the spring starter. Now I have to get some graphics on it to dress it up a little.
Later
(in reply to wiz310)
       Post #: 76
RE: World Models 1/3 Super Cub - 5/6/2008 9:09:39 PM
sodbuster 1
Status: offline
how'd you like the quality of the build and hardware?
Still have my eyes on the Clipped version but don't want to spend $700 for something so-so
_____________________________
Once you go Yak, you never go back......
(in reply to rglass1144)
       Post #: 77
RE: World Models 1/3 Super Cub - 5/6/2008 10:21:59 PM
rglass1144
Status: offline
I did not use any of their hardware. Quality is ho hum. If I had to do it again I would have put the money towards something else. I don't know what else but if I crashed this one I would not replace it.
(in reply to sodbuster 1)
       Post #: 78
RE: World Models 1/3 Super Cub - 5/7/2008 11:34:36 AM
Whymee
Status: offline
I just picked up my WM Super Cub last night from the J&C Hobbies in Pittsburgh. ( I am in WV). Heck of a big box. Did not have time to check contents, but the box has no apparent damage to the exterior. Greyhound did a good job!
Proposed engine is a G-62, hitec 5645's all around & a 5955 on rudder.
Looks like a fun build.
Stan
WV
       Post #: 79
RE: World Models 1/3 Super Cub - 5/7/2008 1:00:33 PM
rglass1144
Status: offline
These are the 7 inch wheels that I used on the gear. Part number 5606. http://www.mecoa.com/cb/wheels.htm
The G62 will fly this airplane without any problem. You will have to add a little weight onto the firewall to get it to balance. I made the engine standoff out of plywood to add some and a steel weight under the standoff. Plenty of room to work in the engine area.
Good luck with the assembly.
(in reply to Whymee)
       Post #: 80
RE: World Models 1/3 Super Cub - 5/8/2008 9:11:23 PM
Whymee
Status: offline
Could some one post a pic of the installed cowl? I am having fits trying to mock up my motor install (G62). Am trying to get the cowl to fit before I mount the 62. My cowl seems too big where it meets the fuse and it does not want to fit flush.
And I thought this was going to be a fun build!
Blue Skies
Stan
WV
       Post #: 81
RE: World Models 1/3 Super Cub - 5/9/2008 4:37:37 PM
badedge540
Status: offline
sweet
Remember, just because you took off on 3 wheels ,Doesn't mean you will land on them.
       Post #: 82
RE: World Models 1/3 Super Cub - 5/9/2008 10:31:34 PM
Bosshossv8
Status: offline
quote:
ORIGINAL: Whymee
It Only attaches top and bottom not on the sides....And it fits very close to the windshield.
Great Airplane, the hardware is suspect, however.
"Are you brave enough to milk a Yak?"
       Post #: 83
RE: World Models 1/3 Super Cub - 5/10/2008 2:03:04 AM
Cyclic Hardover
Status: offline
quote:
ORIGINAL: rglass1144
Hi all, I bailed on this thread a long time ago. Stopped flying planes and went to helis due to a cataract lst year. So the cataract was removed, lenses installed glasses and 20/17 . I read this all over and one guy had a 3w twin. So you think the G62 is minimum, enough?
< Message edited by Cyclic Hardover -- 5/10/2008 2:04:48 AM >
Retired Army Aviator - Excuse Me! You sold me a hair with a cake around it!
       Post #: 84
RE: World Models 1/3 Super Cub - 5/10/2008 2:14:09 AM
Cyclic Hardover
Status: offline
quote:
ORIGINAL: Bosshossv8
quote:
ORIGINAL: Whymee
The hardware stinks on most planes. I've never used much of it on any plane of mine. No great loss. You canjust make it a better plane. On my WM Midget, I took the slot the elevator and rudder were in. Widened it and install duealelevators with the rudder in the middle.Real solid. With the size of this cub, should be screaming for mods
(in reply to Bosshossv8)
       Post #: 85
RE: World Models 1/3 Super Cub - 5/10/2008 12:09:04 PM
rglass1144
Status: offline
Good luck with your eyes retired Army Aviator. Air Cav? You won't have any trouble seeing this monster in the air. My son is a Navigator in the Air Force. He is leaving again this weekend for the middle east.
The G62 has plenty of power for this airplane. I am flying mine with a Fuji 64A. The Fuji 64A is a little heavier than the G62 and has more H.P.. I would recommend using the spring starter that is available for this engine for ease of starting. I use one on mine. Or if you really want to get lazy you can get the on board electric starter for this engine from Fuji and take all of the work out of starting. The added weight for this plane would hardly be noticed. More than enough power. I am changing from a 22x10 prop to a 23x8 prop to slow it down a little on landing. The instructions call for an 80 size engine. I think they did that to get the plane to balance properly. With an 80 twin however, the cylinders will be sticking out the sides of the cowl. Not very much though.
(in reply to Cyclic Hardover)
       Post #: 86
RE: World Models 1/3 Super Cub - 5/10/2008 3:03:19 PM
Cyclic Hardover
Status: offline
If switching props doesn't work, try making a bit more of a shallow approach to slow it down. Works for me on some of my speed type planes.
       Post #: 87
RE: World Models 1/3 Super Cub - 5/10/2008 6:58:47 PM
Whymee
Status: offline
I have started my build on the WM 1/3 Super Cub. Here are some random thoughts...
After opening up the box and inspecting various pieces parts I found no damage. That was a relief. I have seen how some Greyhound employees treat baggage. It is not pretty...
The covering was pretty much wrinkle free. Some if the edges around the windows etc. are loose but that is not a biggie. An iron makes short work of the builders lack of detail. WM Toughlon covering is not to bad. Shines somewhere in between Monokote & Ultracote. So far it shrinks when I need it to and sticks when I apply heat.
All laser cut parts. Can't complain there. Looks to be a tough plane. Time will tell.
Landing gear seems to be stout enough. I did contact William Wallace (via e mail) about making me a set of gear. Let me be kind by saying Willy takes 2 weeks to get back to you. And he wants me to send a check. Forget that. I do not do business with anybody that does not accept Paypal or a CC. I have been burned before. Never again.
Replaced the wheels with Dubro 6' fatties. Much nicer look.
The tailwheel mount plate on the bottom of the fuse is not long enough. Even with the stock tailwheel assy. only 1 of the 3 screws go into the ply plate. I epoxied an additional plate to the bottom. The tailwheel assy. is something to behold. A wonderful arrangement of springs, bolts & plastic. Its also heavy. Ohio Superstar got the nod as a replacement. Its not scale, but it is lighter.
The slot in the fuse that holds the horizional stab. was wonderfully level with the wing tubes. My only gripe about the method of attachment is that after you slid the hor. stab in place there was some space between the upper joint (at the front half only). It was less than a 1/16th.
All servo cutouts have been perfectly sized. A pleasant surprise. (Hitec 5645's)
The hardware that I have fondled so far is not of bad quality. As a matter of fact I was surprised to find bearings on all the control parts. WM even included the servo arms with bearings. A nice touch... The push rods need reinforcement. I dont have a carbon rod like someone suggested. I replaced with carbon arrow shafts, Rocket city, Dubro and H9 hardware. All because I did not have the correct size carbon rod in my inventory. LHS is 42 mi. round trip. 'Nuff said.
The worse part of the whole build so far (I have not started on the wings yet) is the mounting of the cowl. I tried to fit the cowl to the fuse with no motor, to get an idea of where the cowl wants to be placed. Let me make a long story short by saying that the cowl did not let me know. I am going to have to force her into submission. It is not going to be a pretty sight after it is done. Its too bad that the cowl is so far off. I take pride in my fit & finish. This cowl is not going to be up to my usual high standards. Shame on WM for the fit of this cowl.
I did call Steve at Airborne & he said the hub to firewall was 7.75". I mounted my G-62 at that measurement. I have not tried to mount the cowl. Maybe I will fly it without a cowl? It might be prettier... LOL
My Power Expander fits nicely on the provided plate. It sure is roomy in there! M1 (A123) cells will power this bird. I will make the plate removable so I can access the fuel tank (not installed) as needed.
A quick tip. I have been using Tygon fuel line for years. It will harden with age. A better alternative is Hayes Fuel line. Good for glow, gas, smoke & kerosene. Not suppose to harden either. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK824&P=ML I am hoping that it will not be too small an ID. I will report later on this.
That about all I have to report at this time. Sorry I was so long winded. Part 2 to follow as I progress.
I almost forgot: I can't stand the stripes on this plane. They do not line up with the red covering that goes across the bottom of the fuse. I pulled off the 2 stripes on the rudder. I am contemplating pulling more stripes off the fuse and either relocating them or doing away completely. But that is a story for a later date...
As always comments, questions , raves & rants always welcome!
Blue Skies,
Stan
WV
       Post #: 88
RE: World Models 1/3 Super Cub - 5/10/2008 8:29:53 PM
