mvvs 58 needle mixup
Tower Hobbies
Logged in as Guest
  Printable Version
11mm BIG BORE CONVERSION CARBURETOR WALBRO WT324 with STACK 26.65
Seller:  bat.guy
Details:   $26.65   |  11/22/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> mvvs 58 needle mixup
Page: [1]
Login
mvvs 58 needle mixup - 7/25/2007 1:53:20 PM
negy1
Status: offline
58cc can you tell me whitch needle goes in the h side the longer one it seems i got them mixed up can you help
       Post #: 1
RE: mvvs 58 needle mixup - 7/25/2007 5:11:21 PM
BaldEagel
Status: offline
The forum support guys are not gettin notifications of new posts, I suggest you PM Pe Reivers, as I have mine set up and running well I am loath to remove the neddles, the only help I can give is that with both installed they project the same amount, I don't know if that helps, but I wish you well.
Mike
_____________________________
No matter what anyone says 100% is the maximum you can get.
(in reply to negy1)
       Post #: 2
RE: mvvs 58 needle mixup - 7/25/2007 10:23:13 PM
pe reivers
Status: offline
The needles cannot be interchanged because the thread on each of them is of different phisical size.
Walbro monkey-proofed it a long time ago.
@ mike:
I shipped your back mounts today! Have about 4 hours mail backlog, and no time to do all I want.
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl
There is sanctuary in analisys.
(in reply to negy1)
       Post #: 3
RE: mvvs 58 needle mixup - 7/26/2007 12:09:31 AM
BaldEagel
Status: offline
Thanks Pe, I had got your e-mail, I will be installing these in a Composite ARF 2.1 Extra, look out for the build thread when I eventually get the plane.
Mike
(in reply to pe reivers)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.266RCU3
