ezveedub
FL, USA Status: offline
I beleive the DX7 is a full range 2.4 Ghz, while the DX6 is park flier range limited. Also the DX7 has the setup screen which makes setting much easier to see and work with. The DX7 has more setting points also. Most usually find someone selling the Tx only with the charger and battery and then get the servos & Rx as needed. I run the AR6100 Rx with mine.
_____________________________
Hornet X-3D, Trex 450SE, Mini-Z MP777, MBX5R , MBX5T, Inferno & Spada 09, MBX6, MP9
