AFSalmon
Joined: 5/24/2002 From: Beavercreek, OH, Status: offline
Yes, the 55AX is a new standard for 40 size profiles. Great choice for the Fusion as well. The smaller Fusion is much looser than the bigger one although once you get used to how responsive the controls can be you'll learn to do things even the bigger one won't do. The use of spoileron mixing on the 52" Fusion really tames down the harriers for most and I'd recommend programming in about 20% mix with elevators until you get more used to the responsiveness. Check out the video at the OMP website.
_____________________________
Mike (Salmon) Pilkenton, Chief Slab Designer Ohio Model Planes, Team OMP Captain
