RE: O.S.55AX whos got what with what?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Sport Flying >> RE: O.S.55AX whos got what with what?
Page: <<   < prev  1 [2] 3 4 5 6   next >   >>
Login
RE: O.S.55AX whos got what with what? - 8/1/2007 4:59:39 AM
PMAXX
Status: offline
Don't have to, mine runs perfectly
(in reply to Kostas1)
       Post #: 26
RE: O.S.55AX whos got what with what? - 8/1/2007 7:22:35 AM
150flyer
Status: offline
I already have two planes with the OS .55AX. The first is a Hangar 9 Ultra Stick 40 and the second is a kit built Rookie look-a-like called an SR-41. Both engines are nearly a year old and have run flawlessly since day one. Today I purchased another .55AX for the new Great Planes Revolver which recommends a .55 two-stroke at the top of its range.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by 150flyer -- 8/1/2007 7:34:12 AM >
       Post #: 27
RE: O.S.55AX whos got what with what? - 8/1/2007 9:51:32 AM
Kostas1
Status: offline
I took will order my Revolver ARF 40 size once i'' be back from my holidays....
I too will install a 55AX...and APC 11x6 or 10x8!
It will be hot ....... very hottt....
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to 150flyer)
       Post #: 28
RE: O.S.55AX whos got what with what? - 8/1/2007 10:39:42 AM
The Raven
Status: offline
quote:
ORIGINAL: Kostas1
I think you'll find those props too small. At the very least you won't get anywhere near the speed a 12x7 will yield. Some guys in my club tried 11x6 and smaller, none of them liked it. You'll be at 14000rpm on the ground and then run out of revs in the air, not good for an engine.
Of course, if you're into hovering etc then use whatever works....I don't pretend to be an expert on that stuff.
       Post #: 29
RE: O.S.55AX whos got what with what? - 8/1/2007 6:29:16 PM
Bandit
Status: offline
UPS says my GP Revolver will be arriving today. Have a 55AX to stick in the nose and a few 12X6 and 12X8 props to experiment with. With the provided 3.25" spinner, you might want to reconsider the thought of using a 11" prop. Just my .02 worth..
Rick
_____________________________
Takeoffs are optional... Landings are mandatory...
(in reply to The Raven)
       Post #: 30
RE: O.S.55AX whos got what with what? - 8/1/2007 10:14:05 PM
RoysterDW
Status: offline
Be interested to see how the revolver works out!
(in reply to Bandit)
       Post #: 31
RE: O.S.55AX whos got what with what? - 8/2/2007 12:52:46 AM
flyingJ
Status: offline
GP U CAN_DO 3D 46 with the 55 & 12x5 prop
       Post #: 32
RE: O.S.55AX whos got what with what? - 8/2/2007 4:20:39 AM
sdracer12
Status: offline
Nice planes 150flyer. It looks like your SR-41 has a Tower Hobbies muffler on it. How does the 55 like it, and it is much different than the stock muffler?
< Message edited by sdracer12 -- 8/2/2007 4:22:34 AM >
       Post #: 33
RE: O.S.55AX whos got what with what? - 8/7/2007 6:53:09 AM
150flyer
Status: offline
quote:
ORIGINAL: sdracer12
Huge difference with the Ultra Thrust. Runs as reliably as the stock muffler but tends to go from idle to full power without much mid range. That's OK because the plane I'm using it on is built for speed. I did mix some throttle curve into the radio to help improve controlling the mid range.
(in reply to sdracer12)
       Post #: 34
RE: O.S.55AX whos got what with what? - 8/10/2007 6:44:11 AM
OK2Fly
Status: offline
I've got a .55 on a Showtime 50. I've tried a 12x6 and a 13x4. Both props work fine. The 13by is better for 3D stuff. I couldn't get the stock muffler to fit so I slapped on a Bisson pitts muffler.
Anderson
       Post #: 35
RE: O.S.55AX whos got what with what? - 8/10/2007 7:01:38 AM
RoysterDW
Status: offline
Anyone using the 55AX on a Profile?
< Message edited by RoysterDW -- 8/10/2007 7:07:04 AM >
(in reply to OK2Fly)
       Post #: 36
RE: O.S.55AX whos got what with what? - 8/10/2007 7:05:46 AM
RoysterDW
Status: offline
quote:
ORIGINAL: OK2Fly
Nice! I was thinking of the Showtime 50. Got any pics?
       Post #: 37
RE: O.S.55AX whos got what with what? - 8/10/2007 9:40:45 AM
OK2Fly
Status: offline
I'll try to upload some tomorrow (today.)
Anderson
(in reply to RoysterDW)
       Post #: 38
RE: O.S.55AX whos got what with what? - 8/10/2007 8:57:44 PM
OK2Fly
Status: offline
Here she is! Love those SFG's. I've tried 2 fuels w/ the .55 (Omega 15% and Wildcat 15%.) The midrange sucks with the Omega. I'm guessing it's the castor oil?? Stick w/ Wildcat, runs great!
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by OK2Fly -- 8/11/2007 8:37:24 AM >
Anderson
       Post #: 39
