RE: O.S.55AX whos got what with what?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Sport Flying >> RE: O.S.55AX whos got what with what?
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: O.S.55AX whos got what with what? - 4/2/2008 11:51:00 PM
Ed_Moorman
Status: offline
I have a couple of OS .55s. Great engines. Easy starting, reliable, powerful.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Ed Moorman, AMA 553, KD4QBM, Revver Bro #156
R/C Report Magazine, Fun Aerobatics Column
(in reply to Gustof Wind)
       Post #: 76
RE: O.S.55AX whos got what with what? - 4/9/2008 3:32:53 AM
Adrians flyer
Status: offline
I've got mine in a Hangar 9 T-34 Mentor running a 10X8 APC prop and even with the bulbous canopy, I can get it clock 104-109 on the radar gun. I've also got it mounted in my NitroPlanes BobCat with an 11X7 APC pusher prop. It has fixed gear so the best I ever got out of it is 94 on the radar gun (but that was with the smaller 10X8 Pusher prop. You can see the radar gun passes posted here:
http://www.rcuvideos.com/item/PKL6R966CS9VTMJS
It's better to break ground and head into the wind than to break wind and head into the ground.
(in reply to Ed_Moorman)
       Post #: 77
RE: O.S.55AX whos got what with what? - 4/10/2008 3:03:18 AM
millsap
Status: offline
I used one on a uproar 40 used 11-4 prop ran excelant never had a problem and i fly at high elavation 4500 ft
(in reply to Kostas1)
       Post #: 78
RE: O.S.55AX whos got what with what? - 4/11/2008 1:21:44 AM
Augie11
Status: offline
I've just mounted a pair on a TopFlite B-25. Haven't flown it yet but ran them in on 13x6 (MA)props. Put about 1 1/2 gallons through each and they settled in at about 9800 RPM. That's on a 50 degree day, 20% humidity and @ 5200 ft. 15% nitro fuel. Idle @ 1950 and transition was great after setting the low speed needle.....leaned it a bit.
Most pleasing aspect was that they run almost identically +/- 50rpm.
(in reply to millsap)
       Post #: 79
RE: O.S.55AX whos got what with what? - 4/13/2008 9:42:50 AM
NorfolkSouthern
Status: offline
Got mine on a Tango, like Ed. It can do just about ANYTHING!
NorfolkSouthern
(in reply to Augie11)
       Post #: 80
RE: O.S.55AX whos got what with what? - 4/16/2008 1:12:16 PM
goph
Status: offline
this is my zlin z50 with a 55 waiting on a pitts muffler. prop size ?? still thinking....any ideas
it fits perfict in side the cowl very happy with is engine..
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to NorfolkSouthern)
       Post #: 81
RE: O.S.55AX whos got what with what? - 4/19/2008 1:04:34 PM
Adam G
Status: offline
Great thread. I love my .55ax. I had it on a Carl Goldberg .40 profile Yak for 2 seasons and then plunked it hard into the ground on a low hover shattering a wing. I pulled it off and went looking for a plane to put it in. I wish I would have foound this thread about a month ago. I decided on a Hanger 9 Funtana X 50. I was going to go with the Showtime but decided it might be a little too heavy for the .55. Sounds like you guys are having good results with the .55 showtime combo.
The Funtana is about a pound less than the showtime. I only have 2 flights on it so far, but I am very happy with the way it flies. I am going to reinforce the landing gear before I take it out again. I have the Funtana X 100 with a Saito 1.25 and love that plane. I am hoping for similar performance. So far it seems that I will get what I want.
I don't know why I smell like glow fuel Chief, I was on an appointment, honest.
(in reply to goph)
       Post #: 82
RE: O.S.55AX whos got what with what? - 4/21/2008 1:22:03 AM
RoysterDW
Status: offline
As I read earlier people are using OS "F" plugs on thier 55AX.
Is it safe to try this and has anyone had any reports on how long they have been running them and the results?
(in reply to Adam G)
       Post #: 83
RE: O.S.55AX whos got what with what? - 4/21/2008 4:25:31 AM
OK2Fly
Status: offline
OS "F" plugs work great. It will not harm the engine, and they give a smooth transition and they hold heat well. Personally, though, just use an A3 it's cheaper, and the results will be similar.
Anderson
(in reply to RoysterDW)
       Post #: 84
RE: O.S.55AX whos got what with what? - 4/21/2008 8:36:33 AM
RoysterDW
Status: offline
quote:
ORIGINAL: OK2Fly
Thanks OK2Fly [)]
I have a F plug in the field box so I'll give it a go. Otherwise next time I'm at the HS I'll pick up a couple of A3s
(in reply to OK2Fly)
       Post #: 85
RE: O.S.55AX whos got what with what? - 4/25/2008 2:34:31 PM
Gustof Wind
Status: offline
Just completed an engine swap in one of my GP Easy Sport modelschanged out an MVVS that's been in there since '00 and in the predecessor of this one, so I felt it was time for a change. Bolt holes and mounting beam spacing were the same, but because of the OS's shorter prop shaft, still had to drill new holes. Also had to carve out a bit of clearance for the throttle arm. A very straight forward swap. OS started on first flip and needed a bit of low end leaning and eventually two clicks of lean on the needle. When the rain quits and the field dries, I'll fly it. Gustof (my other Easy Sport has a ST .61 in itanother great engine)
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 86
RE: O.S.55AX whos got what with what? - 4/25/2008 3:11:13 PM
panzerd18
Status: offline
I'm looking at putting a 55AX in a H9 Sundowner 50!
       Post #: 87
RE: O.S.55AX whos got what with what? - 5/25/2008 3:59:25 AM
Mustang Fever
Status: offline
I have a 55AX on an Lanier Mariner Mk II, and it's really peppy. I have another one NIB that's going to go on a Mikulasko Arrow when it's finished.
Bob Hunt
(in reply to panzerd18)
       Post #: 88
RE: O.S.55AX whos got what with what? - 5/25/2008 6:53:24 AM
OK2Fly
Status: offline
Put a tuned pipe on it.
Anderson
       Post #: 89
RE: O.S.55AX whos got what with what? - 5/25/2008 6:55:26 AM
plane_nutt93
Status: offline
For those of you who have the Showtime/ 55 AX combo, I've been curious to know how this engine works with this plane when doing ALL-OUT 3D???
Gravity Sucks- If only we could be taught on the moon.
(in reply to Mustang Fever)
