RE: O.S.55AX whos got what with what?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Sport Flying >> RE: O.S.55AX whos got what with what? Page: <<   < prev  1 2 3 4 [5] 6   next >   >>
Login
RE: O.S.55AX whos got what with what? - 6/28/2008 10:34:56 PM
RoysterDW
Status: offline
Thanks for the tip Bob
I think I'll go ahead and mount it in the new planes and make sure the new tank is level with the spray bar or was it the middle of the tank level with the carby?
Any which way the mounting holes are there on the slab. Being a profile the factory has pre drilled where the tank goes but will make sure its in the right spot.
(in reply to Mustang Fever)
       Post #: 101
RE: O.S.55AX whos got what with what? - 6/29/2008 12:48:19 AM
Mustang Fever
Status: offline
Royster: centerline of tank aligned with spray bar (tube nipple).
_____________________________
Bob Hunt
(in reply to RoysterDW)
       Post #: 102
RE: O.S.55AX whos got what with what? - 6/29/2008 5:42:36 AM
Blade-breaker
Status: offline
I just installed a 55AX in a Hangar 9 Twist 3D. I just finished the plane last night and ran 2 tanks of fuel throught the engine today. I am running 15% nitro, I started with a 13-4 prop and switched to a 12-5. Tach said about 12k with the 12-5. I seen in this post someone was running a 12-4w, I have one of those I may try it tomorrow and see what it will spin it at.
Even new the engine idled Very nice, smooth transition from idle to full throttle. Midrange power and throttle response seems great. I have been running a 46FX for years now (not one dead stick) and this new engine seems to tune and run just as smooth as my perfect running 46. I have to give OS credit for a very easy to tune engine!
If the rain stops I will have it in the air tomorrow.
       Post #: 103
RE: O.S.55AX whos got what with what? - 6/29/2008 6:44:16 AM
gaRCfield
Status: offline
Just got a new 55AX yesterday; Phoenix Super Decathlon is in the mail. Should be a nice pair with a 13" prop.
..this hobby is doing weird things to me...
(in reply to Blade-breaker)
       Post #: 104
RE: O.S.55AX whos got what with what? - 7/6/2008 5:10:27 PM
jaof
Status: offline
Hi
I just started flying the Showtime 50 with the OS55AX and a 12x7 APC prop and for my style of flying which is a pattern one-it flies very nicely.
I am using the stock muffler which came with the engine and an OS muffler extension which worked out very well.
I am considering getting a GP Revolver evntually as it is a harp looking plane as well.
I have a Top Flite Cessna 310 to maiden shortly with 2 AXi 4120x18 electric motors-looking forward to it as well
Anyway take care and have fun because after all this is a hobby.
Frank
(in reply to gaRCfield)
       Post #: 105
RE: O.S.55AX whos got what with what? - 7/12/2008 9:22:34 PM
rv7driver
Status: offline
I'm putting the AX55 in my Kwik fly III, almost done with it Pete
the old saying in aviation is keep the dirty side down!; how Boring!
       Post #: 106
RE: O.S.55AX whos got what with what? - 7/14/2008 7:26:48 PM
frenchie79
Status: offline
I put mine in a NJ1 design fun fly type plane-Foam wing cores, larger controls ect.... Weighs in at 4lb 3oz. with the 13x4 prop-vertical/hovering is not a problem-just an option.
Click to see fullsize image.
Click for fullsize
Frenchie #193
(in reply to rv7driver)
       Post #: 107
RE: O.S.55AX whos got what with what? - 7/22/2008 9:21:27 PM
omra
Status: offline
Mines side mounted,using a pitts style muffler.fitted in a great planes Matt chapman cap 580,pulls it around with ease.using a master airscrew 12/7.Superb engine and model.
(in reply to Kostas1)
       Post #: 108
RE: O.S.55AX whos got what with what? - 7/24/2008 6:11:03 PM
mred33
Status: offline
Just finished up a Top Flight Contender with a new 55AX and am going to take it out this weekend. Should be fun with the 55 in there. I used to have a Contender with an HP 61 and it flew great. This one should be even better.
Ed
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING, BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS
(in reply to omra)
       Post #: 109
RE: O.S.55AX whos got what with what? - 7/24/2008 9:30:31 PM
RoysterDW
Status: offline
About to try the 55AX in a H9 Funtana X 50 with a APC 13x4.
Anyone have this combo?
(in reply to mred33)
       Post #: 110
RE: O.S.55AX whos got what with what? - 7/26/2008 2:34:42 PM
Mr. Mugen
Status: offline
I stuck the 55 in a phoenix sukhoi and love it. Needed some thrust angle help but once that was fixed it flew great. I had the 46ax in there first and it was way underpowered so the 55 it was.....never regreted it.
Kevin
Everything electronic runs on smoke.....if you let your smoke out, it''s dead! AMA#378033
       Post #: 111
RE: O.S.55AX whos got what with what? - 7/26/2008 7:14:58 PM
Mustang Fever
Status: offline
Kevin:
They're just the ticket for turning an OK flyer into a rocket, aren't they?
Bob Hunt
(in reply to Mr. Mugen)
       Post #: 112
RE: O.S.55AX whos got what with what? - 7/28/2008 3:22:58 AM
jdkxtreme
Status: offline
Well I had the motor hear with nothing to put it in.. I dug a duraplane out of the closet and put it together with the 55...So now I have one fast ugly dura brick " $20.00" with a new os 55 on it..It is amazingly fast but still a junk plane..But atleast it is flying....I guess this would be my beater plane..When I put it up everyone else lands..lol...Maybe there is a trust issue..lol
       Post #: 113
RE: O.S.55AX whos got what with what? - 8/21/2008 5:13:58 PM
Jeff Spicoli
Status: offline
I've had a Funtana 40 for a few years that I never got around to building, so I bought a OS .55 to install in that with the matching slimline pitts-style muffler that should give a very nice sound. I also have 2 55's waiting to replace the OS 46's in my TF Cessna 310. The extra power from each would make an engine out event more recoverable.
Relax. My dad''s a TV repairman, got an ultimate set of tools. I can fix it.
(in reply to jdkxtreme)
       Post #: 114
RE: O.S.55AX whos got what with what? - 8/21/2008 9:05:18 PM
Mustang Fever
Status: offline
Something doesn't quite ring true, there.
Bob Hunt
(in reply to Jeff Spicoli)
       Post #: 115
RE: O.S.55AX whos got what with what? - 8/21/2008 9:09:41 PM
Jeff Spicoli
Status: offline
quote:
ORIGINAL: Mustang Fever
Like what?
