tony-howard -> RE: Improving the TF GS Mustang Cowl (1/13/2008 10:19:57 PM)
'747 Yes. The exhaust shroud position is marked on the cowl. but not cut out. That's left to the builder. My exhaust kit is designed to be either surface mounted or recessed, recessed being a bit more work. Also the recessed portion behind the spinner will be left to the builder to remove. These are the type of comments I need to help refine how the cowl will be configured. For example, is there anyone who would not want the air filter intake covers (747drvr?). From my standpoint I would rather not incorporate them into the mold, but rather have the builder cut the opening in the cowl and then put a backing in place just as I did with the cowl in the pictures. But if thats a big selling feature, then I'll do it. In some ways the cowl is taking on a life of its own. For example I'm thanking about a laser cut jig that would insure the nose of the cowl lines up with the engine thrust line. Easy to design, but it adds cost to the end product. Things to think about. Any input will be appreciated.
