tony-howard
WA, USA Status: offline
Andre, I think it could be done, but you would most likely have the split the cowl around the center line of the exhaust stack assemblies. Perhaps making the complete top half of the cowl removable in addtition to a lower engine access hatch. Also if I recall the Keleo installation I saw correctly, the exhaust stacks apparently have to be located differently than is scale - probably due to space considerations. (The correct location on the Top Flite GS is a little less than 2-1/8" behind the spinner with the bottom of the cut out on the engine thrust line.) If you decide to use my cowl after I get them into production, I'll be glad to work with you on the your installation.
_____________________________
Tony pacific-scaled-aircraft.com
