Wing Woes - 80" Edge Jig
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> Wing Woes - 80" Edge Jig
Page: [1]
Login
Wing Woes - 80" Edge Jig - 7/27/2007 2:37:24 PM
bob_nj
Status: offline
I'm sure I've either mis-read or done something terribly wrong, but here's the rub;
The instructions say to put the wing jig under the rear of the ribs.
Then the centerlines of the root and tip rib should be parallel (same distance from the work table).
Hopefully it can be seen in the photos how far off my root rib is from the tip rib.
Any thoughts, Please...
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 1
RE: Wing Woes - 80" Edge Jig - 7/27/2007 5:27:04 PM
AFSalmon
Status: offline
Hey you are doing this exactly right so proceed away! The meaning is that the distance from your board to the centerline of the rib at the leading edge and the trailing edge should be the same. For example that measurement should be the same for R1 leading edge and R1 trailing edge (i.e R1 parallel to your board) and the measurement for R9 LE equal to R9 TE (i.e R9 parallel to your board). Hope this helps.
_____________________________
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes, Team OMP Captain
(in reply to bob_nj)
       Post #: 2
RE: Wing Woes - 80" Edge Jig - 7/27/2007 5:32:21 PM
bob_nj
Status: offline
Duh
Makes sense now.
Glad you're here
Bob
(in reply to AFSalmon)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.234RCU3
