RE: Convert GMS 120 glow to Gas    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: Convert GMS 120 glow to Gas
Page: <<   < prev  1 2 3 4 5 [6]
Login
RE: Convert GMS 120 glow to Gas - 6/27/2009 6:05 AM
miker42
Score: 100
Last Login: 3/20/2013
Status: offline
[image][/image]
Hi
Check it out this is a OS 160.
I have not put it on a plane yet but soon it will be on a plane.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to borna)
       Post #: 126
RE: Convert GMS 120 glow to Gas - 6/27/2009 7:57 AM
av8tor1977
Score: 665
Last Login: 5/19/2013
Status: offline
What is the line coming off the side of the crankcase? I am assuming it is a pressure pulse line for the fuel pump, but it doesn't seem to be hooked up properly at the carb. (Hard to tell from the pic.) Also, it appears to be a silicone line, which is a huge "No No" with gasoline. The gasoline will turn it to mush in a short time....
AV8TOR
_____________________________
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to miker42)
       Post #: 127
RE: Convert GMS 120 glow to Gas - 6/27/2009 9:41 AM
w8ye
Score: 318
Status: offline
that spark plug connector reminds me of "RF CITY" Do you have a resistor in there?
< Message edited by w8ye -- 6/27/2009 9:42 AM >
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to av8tor1977)
       Post #: 128
RE: Convert GMS 120 glow to Gas - 6/27/2009 5:11 PM
captinjohn
Score: 247
Status: offline
If you want a shielded cover for that small spark-plug, get in touch with Ralph at rcignition.com He did have them. Nice looking OSMax. What brand of oil and what % are you running in engine? Best Regards Capt,
I never met a engine I did not like !
Hide Signatures
(in reply to w8ye)
       Post #: 129
RE: Convert GMS 120 glow to Gas - 6/27/2009 7:34 PM
miker42
Score: 100
Status: offline
Hi
That line goes to the carb adpter ti pump the carb.
And I will change line.
Hide Signatures
       Post #: 130
RE: Convert GMS 120 glow to Gas - 6/27/2009 8:46 PM
Jezmo
Score: 168
Last Login: 3/9/2013
Status: offline
Nice looking conversion Mike. Yes change the silicone hose for sure. My SuperTigre 90 also uses an adapter plate that has the pulse connection plumbed into it. Works very well. If you decide not to change to a fully shielded plug cap then do a VERY GOOD range check. Those little Rimfire plugs don't have a resister in them and without full shielding all the way to the plug base you can get some pretty bad RF interference as w8ye mentioned above.
Spektrum DX8i, DA DLE SuperTigre OS FOX Saito Enya Jett TT: John 3:16
Hide Signatures
       Post #: 131
RE: Convert GMS 120 glow to Gas - 6/29/2009 7:21 PM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: av8tor1977
What is the line coming off the side of the crankcase? I am assuming it is a pressure pulse line for the fuel pump, but it doesn't seem to be hooked up properly at the carb. (Hard to tell from the pic.) Also, it appears to be a silicone line, which is a huge ''No No'' with gasoline. The gasoline will turn it to mush in a short time....
AV8TOR
Miker, As long as gas does not run through or collect in the silicone pulse line.....it may last a long time. On test stand...how is it seem to be doing...just curious. Capt,n P.S. Would like to hear more on how the OS Max runs. Thanks
< Message edited by captinjohn -- 6/29/2009 7:23 PM >
Hide Signatures
       Post #: 132
RE: Convert GMS 120 glow to Gas - 6/29/2009 7:32 PM
captinjohn
Score: 247
Status: offline
Miker, here is a photo of one type of sparkplug shield....there are others also. Capt,n
Click for fullsize
Hide Signatures
(in reply to captinjohn)
       Post #: 133
RE: Convert GMS 120 glow to Gas - 6/29/2009 8:18 PM
av8tor1977
Score: 665
Status: offline
Why would someone take a chance with a known improper fuel or pulse line? Good way to possibly lose an airplane if the engine quits at a bad time....
AV8TOR
< Message edited by av8tor1977 -- 6/29/2009 8:19 PM >
Hide Signatures
       Post #: 134
RE: Convert GMS 120 glow to Gas - 6/29/2009 10:00 PM
Jezmo
Score: 168
Status: offline
AV8TOR
I'm with ya on this one. Fuel line is way too cheap to take a chance.
Hide Signatures
       Post #: 135
RE: Convert GMS 120 glow to Gas - 6/30/2009 2:24 AM
captinjohn
Score: 247
Status: offline
AV8TOR
AVATOR...Can you read the post??? TEST STAND...just to see what happens. OK WITH THAT?? OH my acking A$$
Hide Signatures
       Post #: 136
RE: Convert GMS 120 glow to Gas - 6/30/2009 4:48 AM
miker42
Score: 100
Status: offline
Hi Capt,n
Where can I get a shielded plug conector like that?
I went to rcignition.com but could not find anything.
Thanks Mike
Hide Signatures
       Post #: 137
tkg
Score: 657
Status: offline
If the comments about the pump line were not made, what do you think the odds are that the engine would have installed in the plane that way.
To many people have the attitude of what is the MINIMUM I can do and still fly my plane. The correct attitude should be What are ALL the things I can do to to my plane to keep it flying.
Remember the RF signal is in MICRO volts and an engine that quits in a torque roll is breakfast food.....pancakes
DO it right, DO IT the best you can and DO IT ONCE.......
TKG
Too much power is just about right.
Hide Signatures
       Post #: 138
RE: Convert GMS 120 glow to Gas - 6/30/2009 5:05 AM
w8ye
Score: 318
Status: offline
quote:
ORIGINAL: miker42
Hi Capt,n
Thanks Mike
http://www.ch-ignitions.com/#cat
I couldn't find the Rimfire but if you call them they can fix you up
Edited to correct the fact that I had answered a different post than I thought I was
< Message edited by w8ye -- 6/30/2009 5:51 AM >
Original AMA #31261
Hide Signatures
       Post #: 139
RE: Convert GMS 120 glow to Gas - 6/30/2009 5:47 AM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: tkg
I agree...do it best the first time....that is if your flying. If Miker is just testing his engine & ignition system, he can at least see what does NOT work on the ground. He may not have the proper fuel line for pulse connector on hand now. But by doing what I said he can at least continue testing on ground ...same as a test stand. Miker...take our advise an do not fly untill all the tips others gave you are taken care of. Have a helper when you fly that can land a airplane with a dead engine. I always flew every drop out of my airplanes in the old days and would glide in. It is good pratice...in case you have a dead engine. By the way, you will find out there are many things that can go bad all of a sudden...that is the odds!!! Good luck and let us know if you run into any trouble. Capt,n
Hide Signatures
(in reply to tkg)
       Post #: 140
RE: Convert GMS 120 glow to Gas - 6/30/2009 4:53 PM
miker42
Score: 100
Status: offline
I didn't mean to cause all that about the line, I just put that line on to try the engine out, all the lines will be new when it goes in the plane
< Message edited by miker42 -- 6/30/2009 4:54 PM >
Hide Signatures
(in reply to tkg)
       Post #: 141
RE: Convert GMS 120 glow to Gas - 6/30/2009 6:34 PM
captinjohn
Score: 247
Status: offline
Miker42, you did not cause all the replys about the pluse line, Oh and the ignition. We was just helping at the moment. It looks like to me with just a few postings you have made that you are doing very well and can already post photos (something a lot of people cannot do) so to me you are above average for a new person doing some pretty good research & testing already. Keep up the good work...and you did not cause a fuss at all. It was clear who caused any fuss. Capt,n
Hide Signatures
       Post #: 142
RE: Convert GMS 120 glow to Gas - 6/30/2009 8:24 PM
av8tor1977
Score: 665
Status: offline
Sure was...
AV8TOR
Hide Signatures
       Post #: 143
RE: Convert GMS 120 glow to Gas - 7/10/2009 5:39 PM
borna
Score: 100
Last Login: 12/3/2011
Status: offline
I can see some interesting pictures and lots of posting. I haven't worked on GMS yet since I'm busy building a model engine from scratch which is taking away my interest away from GMS engine. But that doesn't mean I'm not going to work on it.
Captin, I don't have a picture of the broken ring and I have already replaced it with the new ring. However no damage to any thing when the ring broke. As you said I guess I was lucky
Miker, are you using needle bearing for the connecting rod? Have you tested the engine yet?
Borna
Hide Signatures
       Post #: 144
RE: Convert GMS 120 glow to Gas - 7/11/2009 12:52 AM
miker42
Score: 100
Status: offline
Hi
No I did not change the bearing , I have ran the engine but I am waiting on a plane I have order.
I will post when I get it in the air with some pixs
Thanks Miker
Hide Signatures
(in reply to borna)
       Post #: 145
RE: Convert GMS 120 glow to Gas - 7/11/2009 12:58 AM
miker42
Score: 100
Status: offline
Thanks Capt,n
I called ch ignition and they sent me the cap I needed and I have instaled and it works grate
Thanks Miker
Hide Signatures
(in reply to w8ye)
       Post #: 146
RE: Convert GMS 120 glow to Gas - 7/11/2009 3:30 AM
captinjohn
Score: 247
Status: offline
miker42, when helping others, one is in turn helping yourself! I am glad the ignition is working good. The CH guys are good for exact ignition parts one may need. Best Regards Capt,n
Hide Signatures
       Post #: 147
RE: Convert GMS 120 glow to Gas - 7/19/2009 7:26 AM
rjfon1
Score: 100
Last Login: 2/1/2012
Status: offline
Good Morning all from Australia.
I have been reading alot of threads regarding conversions, but wanted something smaller.
Back in 2007, Jezmo you stated that you were running a SuperTigre 51 on gas and it runs very well.
For me this would be the ideal setup, ie: small, inexpensive, hopefully easy to run. Just wondering what your setup was?
I was thinking of the following:
SuperTigre51 or ASP52 running a mix of 5:1 for breakin, and 10:1 after, and not changing the bearings initially.
the RCexcl ignition found at
http://www.dlenginesaustralia.com/dlshop/index.php?_a=viewProd&productId=125
Questions:
Did you just keep the bushes?
What do you think about the walbro wt-644 carby for this, or was the standard carb OK?
If you went to pin bearings, what size, and what fuel mix did you go?
What angle did you set the ignition? (I was thinking about 28BTDC-This ignition has auto retard advance which helps with starting)
Thanks in advance for any replies
Rob Fonhof
Melbourne Australia.
Hide Signatures
       Post #: 148
RE: Convert GMS 120 glow to Gas - 7/28/2009 11:46 AM
PlaneKrazee
Score: 205
Last Login: 6/21/2012
Status: offline
How well does that 160 fx run on gas? RPM ?
a never-ending battle for truth, justice and the American way
Hide Signatures
(in reply to rjfon1)
       Post #: 149
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: Convert GMS 120 glow to Gas
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.094RCU1
