SinCityJets
Joined: 11/13/2005 From: Henderson, NV, USA Status: offline
quote:
ORIGINAL: craigteffe What chargers are avaliable for the A123 packs? Will the acucycle work? Or do we need to purchase another charger? Craig, you have to decide if you are going to balance charge or not. If you are going to balance charge, the best charger out right now is the FMA CellPro 4S. If you are NOT going to balance charge, then you can use any nicad capable charger as long as you use a "Dapter." You can find a Dapter at SLK Electronics, or maybe even at the website in my signature. The dapter allows you to charge 1 A123 cell for every 2.5 nicad cells your charger will handle. The dapter can handle up to an 8amp charge, so the charge rate will depend on your charger's capabilities. Having said all that, if you are still undecided on balance charging, or not; most information and research out shows these cells do NOT need to be balanced, like their Lipo cousins. Especially in 2S-6S configurations. While it certainly isn't going to hurt to balance them, you might as well save yourself an extra $5 per battery.
< Message edited by SinCityJets -- 12/9/2007 3:24:29 PM >
_____________________________
Sin City Jet''s Rally 2008 November 7-9 http://www.sincityjets.com/events.htm
