vnmsgt
FL, USA Status: offline
quote:
ORIGINAL: ugly duck quote:
ORIGINAL: vnmsgt Here is a upgrade for the differentials in the monsoon. Some people have problems with them stripping out the ring gear. I installed CEN Matrix ring and pinion gears part #MX040 and MX037. The truck rolls smooth as glass now just like my ST-RR and Hyper and does not have the grinding noise and notchiness of the stock gears when you roll the truck. A friend did this to a Hurricane buggy and it ran 10 times better with this upgrade so I figured I would try it since I just stripped my ring gear. Hey, Chris - did you ever try these diffs at the track? I looked at the pictures and counted the teeth, and it looks to me that the stock final drive is a 3.67:1 ratio (12 tooth pinion, 44 tooth ring) and the Cen gears give a 2.88:1 ratio (9 tooth pinion, 26 tooth ring). This is about a 27% increase in wheel speed, similar to strapping on a 13 tooth clutch bell. Combining this upgrade with a 12 tooth clutch bell should give a 52% increase in wheel speed, and if given a long enough run should really make for a good top end! I imagine this is not what you want at the track, but it might make for a fun basher / street racer. Damn, you guys have totally got me convinced the Monsoon is the better buy over the Avalanche. Do a couple simple mods and this truck should be hard to touch. Edit - and did you ever sell your truck? You are right about the gearing. The truck was not as good on the track unless I went back down to the 10 tooth. But with the 12 tooth the monsoon had CRAZY top end. On some of the long straights on some tracks I went to I was not even close to topping out. The thing would probably give a Jato a run for its money! Yes I sold it. Actually Schlage62 who posted about selling his monsoon is my old monsoon so if anyone wants one, that is a great one with a ton of mods done to it.
_____________________________
CASTER RACING K8T, ZX-1R, Fusion EX-1 HOLESHOTHOBBIES, GO TECH, AVID BEARINGS, Don''t jump on the bandwagon...CRUSH IT
