vnmsgt
FL, USA Status: offline
Just got my monsoon from clermont hobby and it has been way more then I expected it to be. The only issue I had was during break in when I could not get it to run more than 10 seconds at a time. Blistered my hands pullstarting it through two tank fulls and trying to see why it would not stay running when I found out the hole from the exhaust pipe that goes to the fuel line to pressurize the tank was never drilled out. I had no pressure to tank and had to keep priming it. Drilled out the hole myself and used a set screw on the end to only allow exhaust pressure to tank and it runs fine now. Redcat is supposed to be sending my lhs a new pipe for me no questions asked, Great service their. And one other small issue was when I changed the shock oil, one nut inside a shock had come loose but no big deal. Great truggy and a bargain.
_____________________________
Caster Racing USA K8T/ZX-1R, Holeshothobbies, GO Tech engines, Fusion Fluids Do not jump on the bandwagon...CRUSH IT
