RE: Just sharing - M18T - best 1/18 car I've ever bought!!!
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: Just sharing - M18T - best 1/18 car I've ever bought!!!
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 10/24/2007 9:27 PM
joeyhatch11
Score: 109
Last Login: 11/7/2009
Status: offline
hahahahaha you wont believe what i did. I, for some odd reason, had the Rx & Tx screwed up. I guess that'll make things act alittle funny. But with that fixed i'm still having a slight problem with it cogging when i hit the throttle too hard from a dead start. After reading the post about the stock receiver not being any good with these mamba systems, i'm thinking of getting Spektrum DX2. I'm hopping after that my problems will be solved. Next question would be, what is a really good servo for these 1/18 scale trucks? I'm in need of one of those as well. Thanks guys for the help too
Hide Signatures
(in reply to joeyhatch11)
       Post #: 51
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 10/25/2007 2:45 AM
HpiDrifter420
Score: 100
Last Login: 9/9/2009
Status: offline
well for mini servos for my NT18MT i just use the hitec 85mg's they run about 25-30 and have metal gears ball bearings. or you could get the hitec 81mg that just has metal gears
_____________________________
LST2,T-Maxx,Sprint2,NT18MT,Chaos,E10,Micro-T
Xboxlive:HazyRenots420
Hide Signatures
       Post #: 52
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 10/25/2007 6:56 PM
rschoi_75
Score: 100
Last Login: 10/14/2009
Status: offline
I use a hs-81mg too. I believe Mini_Me uses a polo digital, which is more expensive but centers better than the 81mg. I can't find a link for it so maybe he can post one for you.
Of course I''ll have coffee... I always have coffee when I''m watching radar. Everyone knows that!
Hide Signatures
(in reply to HpiDrifter420)
       Post #: 53
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 10/25/2007 7:35 PM
joeyhatch11
Score: 109
Status: offline
Is this the Servo your talking about? http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGZU9&P=7. if so i might have to get that. It looks sweet and torque out put is nice for a mini servo. LMK
Hide Signatures
(in reply to rschoi_75)
       Post #: 54
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 10/25/2007 7:38 PM
Mini_Me
Score: 100
Last Login: 6/27/2009
Status: offline
Yes, thats the one.
M18/T FAQ available on http://www.teamxray.com/
Hide Signatures
       Post #: 55
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 10/25/2007 9:34 PM
joeyhatch11
Score: 109
Status: offline
Is that servo worth $50 or is there something better?
Hide Signatures
(in reply to Mini_Me)
       Post #: 56
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 10/25/2007 10:09 PM
DarkHorse
Score: 100
Status: online
Had a stab at modifying my heli calc for rc car/truck.
Yes another Rollout calculator, can you have too many? maybe.
Still a bit scruffy but it works.
http://dhrc.rchomepage.com/RolloutCalc.htm
RC Car/Truck Power & Setup Calculator
Having trouble estimating brushed motors so I haven't included any. Normally I would set the efficiency number to 60% to estimate 100% performance, not sure though. Have a play... ideas welcome .
DarkHorse RC: Hornet X-3D, Ecureuil, Airworlf, X-ray M18T, Power & Setup Calculators ;) http://dhrc.rchomepage.com/
Hide Signatures
       Post #: 57
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 10/26/2007 12:22 AM
Mini_Me
Score: 100
Status: offline
Neat!
Im trying it out. Some of the circumference and rpm data doesn't update when you do the diameter FWIW.
test
Hide Signatures
(in reply to DarkHorse)
       Post #: 58
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 10/26/2007 4:13 PM
DarkHorse
Score: 100
Status: online
>...data doesn't update when you do the diameter
Yes, if your picking numbers from the browser's history (for say the diameter text edit box) then clicking a history item doesn't generate a 'change' event like entering a fresh number. Gives the appearance of nothing changing, that's another reason for the 'Calculate' button there.
Edit: I just set AUTOCOMPLETE="off" for my form since I can't trap those events easily.
Also you wouldn't expect the motor or wheel RPM to change with tyre diameter unless it were possible to model all the variables of actual motor loading, performance, cell resistance, ESC losses and friction. The best we can do is work the motor RPM from the Kv x Voltage applied / the efficiency % factor and the resulting wheel RPM from the final gear ratio.
< Message edited by DarkHorse -- 10/26/2007 6:40 PM >
Hide Signatures
       Post #: 59
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 10/29/2007 10:17 AM
DarkHorse
Score: 100
Status: online
Giving my m18t a hard time:
Broke a plastic CVD, not running but whilst tightening the ball diff, testing the slip in my hand when a pin broke off the CVD. even though I have spares I decided to drill a ~1.2 mm hole through the CVD ball joint and dremel cut the back portion of the drill bit to use as a cross pin. Works well .
Had a strange crash the other day. I geared slightly lower for loose dirt/gravel surface and was nearly maxed out over a small BMX bike jump, launched and landed about 10ft later, when the m18t looked like it hit a land mine as the truck abruptly changed direction to vertical jump 6ft in the air! It had contacted the top of a sunken rock on landing, the change in direction was very dramatic and ripped out a chunck off the chassis to the diff housing front lower suspension arm. Checked the 3s TP910 lipo which looks to have taken a shunt in the impact, otherwise still drives ok.
< Message edited by DarkHorse -- 10/29/2007 10:18 AM >
Hide Signatures
       Post #: 60
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 10/29/2007 3:29 PM
Mini_Me
Score: 100
Status: offline
Be careful with possible damaged lipos.
Hide Signatures
       Post #: 61
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 11/11/2007 9:09 PM
DarkHorse
Score: 100
Status: online
I posted a video of my m18t here.
Hide Signatures
       Post #: 62
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 1/9/2008 5:28 PM
DarkHorse
Score: 100
Status: online
Update info:
Two brushless m18t on 3s 1320mAh ThunderPower 11.1v packs (17A/27A peaks),
both geared for similar top speeds ~35mph
m18t kit Setup1: 8 Amp 2015 2800kv Himaxx ~35g short motor 10A/15A peak ESC, pulls ~10A max (~550g)
m18t kit Setup2: 18Amp Eflight 400 4200Kv 65g long motor 22A/30A peak ESC, pulls ~12A max (carrying +50g)
Pretty big difference in specs, ACTUAL difference in performance? Nothing much to shout about, almost the same head to head runtimes (15-45mins, throttle demand dependant), whatever the demands on average both 9v ESC low voltage cutoffs kick in within 30 secs of each other. The reason we can't get the extra power setup to show it on the road looks to be due to tyre slip limiting the useful power level. Maybe we would see more of a difference on carpet???
As it goes for 'our truck requirements', light weight cheaper sub 11v*10A setup performs adequately, no real need to get the more expensive weighty hungry stuff in trucks this size.
Now I've moved the power system from m18t Setup2 into an almost new RTR M18MT 630g geared to ~30mph 11.1v 4200Kv using gearing 54T/12T with 70mm tyres... yet to thrash. Looks great and should be extra good fun bashing .
Brushless is great at speed but stick to brushed for any slow climbing where the brushless motors just cog.
< Message edited by DarkHorse -- 1/9/2008 5:58 PM >
Hide Signatures
       Post #: 63
RE: Just sharing - M18T - best 1/18 car I've ever boug... - 1/9/2008 11:59 PM
bigairlife
Score: 107
Last Login: 10/12/2009
Status: offline
Ya. They are great. I love mine!
LST2 (converted from aftershock) Werks .26 v2 ~ Savage X ~ Losi Mini Comp. Crawler ~ Nitro Pede Basher
Hide Signatures
       Post #: 64
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 3/11/2008 9:51 PM
DarkHorse
Score: 100
Status: online
Oh wow, it's just raining X-ray's today!
Just acquired another give away used m18t deal with 3 body shells, brushless 3s 1320mAh pack and a bucket of spares. Ali CVDs, the down side is 2 of which are cheap Asian Atomics blue (poor sloppy copies) along with 2 Atomic blue hub blocks. All added to my own bucket of bits, m18t basher and m18t Pro minter!
After all my bashing to date I can say that the most common component I'm breaking is the 'composite suspension block' (I call hub blocks), tie bar end hoops (same as steering and shock ends), the odd front wishbone and the stock tires but any harder compounds just don't grip on street under brushless 3s demands. Using ali CVDs but won't be paying high prices for ali suspension blocks as that will only transfer the damage to another component and the hub blocks are quick and easy to change, so that's the preferred fuse point for me.
Hide Signatures
(in reply to bigairlife)
       Post #: 65
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 3/12/2008 4:53 AM
Mini_Me
Score: 100
Status: offline
I finally got my Pro (and a few hop ups) today. Gonna take my time building it.
Especially since Im still waiting on the servo and lipo I'm after to be released in the states.
Hide Signatures
       Post #: 66
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 3/12/2008 5:39 PM
rschoi_75
Score: 100
Status: offline
Nice! make sure to keep us posted on your build.
can you fill me in on which lipo and servo you plan to use? I take it you are not going to get another polo 4?
Hide Signatures
       Post #: 67
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 3/12/2008 5:42 PM
Mini_Me
Score: 100
Status: offline
Probably that Flight Power Evo 2 1600 If I can find it! Hitec 5082.. which still has not been released almost a year after its announcement here in the states!
Hide Signatures
       Post #: 68
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 3/12/2008 7:12 PM
combatman
Score: 100
Last Login: 11/8/2009
Status: offline
I am assembling an M18T from the kit, and was wondering if anyone else has re-lubricated both differentials. I only ask because my factory assembled ones don't feel or look like there is any lube in them, but a call to RCAmerica revealed that only a very thin lube is used in the factory assembly.
Do most people leave them as is, with respect to the lube?
Hide Signatures
       Post #: 69
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 3/12/2008 7:29 PM
DarkHorse
Score: 100
Status: online
I leave mine as they come, do the break in routine and they have either out lived the trucks they are in or probably will out live them .
Hide Signatures
(in reply to combatman)
       Post #: 70
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 3/13/2008 12:20 AM
Mini_Me
Score: 100
Status: offline
I rebuild mine simply because Im OC.
Hide Signatures
       Post #: 71
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 3/18/2008 8:53 PM
DarkHorse
Score: 100
Status: online
An X-ray for any occasion . They look a bit rough as they get a hard life but they go well .
Left to right:
X-ray m18t-Pro stretched carbon - speed plus precision handling
Mamba 5400Kv motor, Mamba25 ESC
3s 1320mAh lithium 11.1v, 55mm fresh pin tires, 54T/?T yet to settle
HS-81MG servo, M18MT RTR prepainted body shell, ~570g
X-ray m18t - hard street bashing, semi off road with speed plus handling, xray ali CVDs
E-flight 4200Kv motor (65g long), Mamba25 ESC
3s 1320mAh lithium 11.1v, 55mm bald pin tires, 54T/14T, top ~35mph, +40mins of play
SuperTec cheap servo, stock painted body shell, wheelie bar ~555g
X-ray M18MT - low speed abuse off road garden basher, longer grass, sloppy atomic blue ali hubs and CVDs
Himax 2015 2800Kv motor, Mamba25 ESC
3s 910mAh lithium 11.1v, 70mm hard chevron tires, 54T/9T, top ~15mph, +30mins of play
HS-81MG servo, old style Hummer body shell, ~610g
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by DarkHorse -- 3/22/2008 8:55 PM >
Hide Signatures
       Post #: 72
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 3/26/2008 8:56 PM
DarkHorse
Score: 100
Status: online
Here's another one that got me. Cogging due to weak brushless motor!
My slow setup M18MT was using a small 8A Himaxx 2015 2800Kv motor low geared 54T/9T with softer 3sTP910mAh (~15mph). After a few packs I started to get some chugging when changing direction rapidly... got worse near the end of the pack. So I swapped to a stronger 3sTP1320mAh pack and the situation was better. A few packs later the cogging crept back to become a problem. When opening a lot of throttle and the system starts to chug the motor gets hot quite quickly.
So I switched in a longer 15A Himaxx 2025 5400Kv on metal 8T pinion (more noisy, ~25mph), which I didn't want to do because the extra Kv will be too fast for what I'm trying to do, low speed in a small space bashing. Well the power and speed is much better and the chugging cogging startup issue has gone. Frankly I was surprised that the cause was a deteriorating brushless motor, once moving at speed the motor seems fine, no obvious performance problems (for it's size).
So all we can be sure of is that cogging is due to either the ESC, motor, bad gearing or battery pack, not always obvious which one, so far I've had cogging issues from a faulty ESC and now a weak motor.
Hide Signatures
       Post #: 73
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 3/29/2008 5:10 AM
Mini_Me
Score: 100
Status: offline
Yea!! T-bone racing finally made a racer version bumper.
Hide Signatures
       Post #: 74
RE: Just sharing - M18T - best 1/18 car I've ever bough... - 3/29/2008 10:00 AM
DarkHorse
Score: 100
Status: online
Yes sure could do with some of those, just to take the edge off those extra fierce impacts.
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.531RCU1
