RE: Black Magic VF3 Build Thread
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> RE: Black Magic VF3 Build Thread
Page: <<   < prev  46 47 [48] 49 50 51 52 53 54 55   next >   >>
Login
RE: Black Magic VF3 Build Thread - 6/2/2009 5:40 PM
jrpav1
Score: 100
Last Login: 2/26/2010
Status: offline
Regarding the vacuum seal issue with wing tubes: I drilled a very small hole in the center of the wing tube (1/16") and a 1/8" hole in the center of the wing socket. The holes are exactly on top when the wings are installed. Put your wing tube into the wing with the hole on top, slide into the fuse and mount your other wing. No trapped air and the holes don't seem to affect affect strength. If you'd rather not drill holes in the center then just put 2 small holes in the wings (on the bottom of the wings) through the tubes like you would do if you were using screws at the end of the wing tubes to hold the wings on.
John Pavlick
Team Black Magic, Tech-Aero Designs
Hide Signatures
(in reply to rcpattern)
       Post #: 1176
RE: Black Magic VF3 Build Thread - 6/2/2009 7:20 PM
rcpattern
Score: 100
Last Login: 3/22/2010
Status: online
I really dont like ANY holes in a carbon tube, no matter how small and no matter the location.  I don't even like the setup of drilling the tube near the tip and putting screws in to hold it in place.  Over time, I dont care how small the hole, a crack can migrate and one can form small enough you dont even know it is there.
I've never seen any problems with having the vacuum issue.
Others have had success drilling holes in carbon tubes, I just personally don't like it.
Just my .02
Arch
_____________________________
Team Futaba, YS Parts and Service, Central Hobbies, Tarable Graphics, Team Black Magic, Morgan Fuels, Tech Aero Designs
Hide Signatures
(in reply to jrpav1)
       Post #: 1177
RE: Black Magic VF3 Build Thread - 6/2/2009 7:46 PM
MHester
Score: 100
Last Login: 3/17/2010
Status: offline
I'll go on record by stating I don't condone drilling holes in carbon tube if I can help it either. Although I haven't personally yet seen any issues with holes at the tips, I wouldn't want a hole anywhere near the center section. It might indeed be just fine.....but it's not a risk I'd personally take.
of course apparently I don't have a problem taking a risk with not doing maintenance on said tube LOL
-Mike
Owner Custom Airframes of America, Team YS, Morgan Fuels, Mercury Adhesives, Hyde Soft Mounts, Vampower Pro Batteries
Hide Signatures
       Post #: 1178
RE: Black Magic VF3 Build Thread - 6/5/2009 1:38 AM
cmoore806
Score: 100
Status: offline
Alright.  Tomorrow I will likely get the wing roots lined up on my vf3 and get the wing mounting mechanisims in place and perfectly aligned.  After that its belly pan, cowl, tail blocks, etc etc.  I am placing an order from Tower soon and though I have all kinds of hinges in the shop I am wondering what you recommend.  I like plastic "klett style" hinges with the pin in them.  I plan to use them but dont know what you guys are using.  I've seen how CA attacks foam, and dont think that CA hinges are adequate for this bird.  So, whats the word?
Chris Moore
AMA 497715
Hide Signatures
(in reply to MHester)
       Post #: 1179
RE: Black Magic VF3 Build Thread - 6/5/2009 1:40 AM
Ryan Smith
Score: 103
Status: offline
Chris,
CA hinges are plenty adequate, however I would reccomend that if you went that route to use the Radio South hinges. I prefer Du-Bro plastic pinned hinges myself, but to each his own.
Team Horizon, Evil-R/C Products, YS
Hide Signatures
(in reply to cmoore806)
       Post #: 1180
RE: Black Magic VF3 Build Thread - 6/5/2009 2:21 AM
rcpattern
Score: 100
Status: online
Nothing wrong with CA hinges.  Just get the glue on the wood, not the foam.  My V3 that Mike built has all CA hinges.  Never had a problem,
Arch
Hide Signatures
(in reply to Ryan Smith)
       Post #: 1181
RE: Black Magic VF3 Build Thread - 6/5/2009 2:27 AM
RC11
Score: 105
Status: offline
Radio South ..blue CA hinges were recommended by many. I have them in my son's VF3.
Hide Signatures
       Post #: 1182
RE: Black Magic VF3 Build Thread - 6/5/2009 3:36 AM
cmoore806
Score: 100
Status: offline
they make two types, 1/4 scale (http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDZ44&P=ML) and pro hinges (http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDZ43&P=SM)  Which ones?
Chris
Chris Moore
AMA 497715
Hide Signatures
(in reply to RC11)
       Post #: 1183
RE: Black Magic VF3 Build Thread - 6/5/2009 3:38 AM
handglider
Score: 100
Status: offline
 go with the 1/4 scale
Hide Signatures
       Post #: 1184
RE: Black Magic VF3 Build Thread - 6/5/2009 3:53 AM
lodomjr
Score: 100
Status: offline
I finally finished the the new stabs and putting all the stuff back in the "NO NO Bag".   The wheelpants from Precision Aircraft worked out real well.  The plane is flying real nice and the planes now weighs 10lbs 14oz.  This now a big weight off my shoulders.  Everyone have a great time at Andesonville and the NATS and I'll see all of you again at Huntsville.  I hope to have my VF3 finished and trimmed by that time and again I'll have a new plane to make it's first appearence at this contest.  Please no mid-airs for me.
Lawrence
Hide Signatures
(in reply to handglider)
       Post #: 1185
RE: Black Magic VF3 Build Thread - 6/6/2009 9:03 PM
SByrd
Score: 100
Status: offline
I havent posted here in awhile I just thought that I would share pics of my VF3 with everyone. Thanks for designing a great flying plane Mike.
Stephen Byrd
Click to see fullsize image.
Click for fullsize
Click for fullsize
Team Futaba, CA Models, Flight Power Batteries, Smart-Fly, Neu Motors
Hide Signatures
(in reply to lodomjr)
       Post #: 1186
RE: Black Magic VF3 Build Thread - 6/6/2009 11:00 PM
rcpattern
Score: 100
Status: online
Very nice.  How did the direct drive work in the tail?  Any issues with CG?
Will you have it in Crosby next weekend?
Arch
Hide Signatures
(in reply to SByrd)
       Post #: 1187
RE: Black Magic VF3 Build Thread - 6/7/2009 12:06 AM
SByrd
Score: 100
Status: offline
The DIrect Drive worked great in the tail and wings. I didnt have any cg problems im running the battery and Ignition just in front of the leading edge of the wing and it balanced at the wing tube, im very happy with the way the plane flys.
Yes I will have it at Crosby ill let you fly on sunday.
Stephen Byrd
Hide Signatures
       Post #: 1188
RE: Black Magic VF3 Build Thread - 6/7/2009 2:02 AM
rcpattern
Score: 100
Status: online
I'll definitely take you up on that.  What does it weigh??  Were on the wing tube is the CG?  If you can get it at the very front or slightly ahead you'll really like it,
Arch
Hide Signatures
(in reply to SByrd)
       Post #: 1189
RE: Black Magic VF3 Build Thread - 6/8/2009 5:22 AM
SByrd
Score: 100
Status: offline
I am at 10.10 running the cdi unit . I have it balanced right on the front of the wing tube. The plane flys amazing at that wieght and balance.
Stephen Byrd
Hide Signatures
       Post #: 1190
RE: Black Magic VF3 Build Thread - 6/8/2009 2:37 PM
MHester
Score: 100
Status: offline
Nice job! I know what Arch was thinking on the CG....same thing I was. Wondering how the DD setup in the tail would affect the CG. LE of the wing tube seems to be the sweet spot.
I'm glad you like it. Looks like a weapon for sure!
-Mike
Hide Signatures
(in reply to SByrd)
       Post #: 1191
RE: Black Magic VF3 Build Thread - 6/8/2009 3:16 PM
SByrd
Score: 100
Status: offline
I was worried about it to but I just was careful where I mounted radio gear. Here is the inside view you can barely see the battery and ignition on the right side of the pic.
Stephen
Click for fullsize
Hide Signatures
       Post #: 1192
RE: Black Magic VF3 Build Thread - 6/8/2009 7:08 PM
BHolsten
Score: 100
Last Login: 3/20/2010
Status: offline
Here are some Pic's so far,............
Question#1: Yellow then red? #2: Red then yellow? #3: All red?
Best Regards,
Bill Holsten
Advantage Hobby Fliton Field Rep/Custom Air Frames Of America/DragonFire Customs/DuraLite/Guardian America
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to SByrd)
       Post #: 1193
RE: Black Magic VF3 Build Thread - 6/8/2009 7:25 PM
cmoore806
Score: 100
Status: offline
Bill,
I say all red is the way to go.
Chris Moore
AMA 497715
Hide Signatures
(in reply to BHolsten)
       Post #: 1194
RE: Black Magic VF3 Build Thread - 6/8/2009 7:48 PM
handglider
Score: 100
Status: offline
 NICE  !!!     Bill !
Looks like your on schedule for nats...
Hide Signatures
       Post #: 1195
RE: Black Magic VF3 Build Thread - 6/8/2009 7:49 PM
handglider
Score: 100
Status: offline
Hide Signatures
       Post #: 1196
RE: Black Magic VF3 Build Thread - 6/8/2009 8:10 PM
BHolsten
Score: 100
Status: offline
Keep the ideas coming,................open to suggestions for finishing the nose area.
Thanks Dean and Chris,..........
Bill Holsten
Hide Signatures
       Post #: 1197
RE: Black Magic VF3 Build Thread - 6/8/2009 8:58 PM
rcpattern
Score: 100
Status: online
Bill,
I'd make it all red, then you have an easier area for graphics.
Arch
Hide Signatures
       Post #: 1198
RE: Black Magic VF3 Build Thread - 6/9/2009 12:11 AM
BHolsten
Score: 100
Status: offline
Arch,....
After I looked at it several times that was the conlussion I came to,....red it is!
Thanks for the input,............
Bill Holsten
Hide Signatures
       Post #: 1199
RE: Black Magic VF3 Build Thread - 6/10/2009 3:47 AM
cmoore806
Score: 100
Status: offline
Could someone please post a pdf or similar document of a two-view line drawing of the VF3 for color scheme layout purposes?
Chris
Chris Moore
AMA 497715
Hide Signatures
       Post #: 1200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.500RCU1
