RE: Black Magic VF3 Build Thread
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> RE: Black Magic VF3 Build Thread
Page: <<   < prev  47 48 [49] 50 51 52 53 54 55 56   next >   >>
Login
RE: Black Magic VF3 Build Thread - 6/10/2009 10:13 AM
lodomjr
Score: 100
Last Login: 3/22/2010
Status: offline
Shoot Dean or me a PM of your e-mail and either one of us can send you that file.  It's just fuse side and as far as the wings go I copied the file to MS paint and made my own wings.  I may have one with blank wings on it now.  I not sure what Dean may have, but I bet he does too.
Larry
Hide Signatures
(in reply to cmoore806)
       Post #: 1201
RE: Black Magic VF3 Build Thread - 6/10/2009 2:10 PM
handglider
Score: 100
Status: offline
Chris, this is a fuse side view drawing, download to your desktop and replace the .txt with .pdf
Click to see the file in new window.Attachment.txt
Hide Signatures
(in reply to lodomjr)
       Post #: 1202
RE: Black Magic VF3 Build Thread - 6/14/2009 3:54 AM
cmoore806
Score: 100
Last Login: 3/17/2010
Status: offline
Thanks for the file guys.  Here is what I came up with.  Any ideas for a wing that might look good with it?
Click to see fullsize image.
Click for fullsize
_____________________________
Chris Moore
AMA 497715
Hide Signatures
(in reply to handglider)
       Post #: 1203
RE: Black Magic VF3 Build Thread - 6/14/2009 5:54 AM
swlarcham
Score: 100
Last Login: 3/20/2010
Status: offline
I recently acquired a Black Magic with similar fuse scheme.  It has purple where you have blue.
the top wings are all yellow with purple and white stripes flaring from the front wing root  to the ou tboard trailing edge of the aileron.
botom wings are purple and yellow checkerboard (big squares)
very visible.
hope this helps =- wish I had pics to show.
eddie
Hide Signatures
       Post #: 1204
RE: Black Magic VF3 Build Thread - 6/14/2009 6:00 PM
MHester
Score: 100
Status: offline
Eddie, did you get his first or second one?
If it hasn't changed look through this thread, pics of both are in here somewhere....
-M
Owner Custom Airframes of America, Team YS, Morgan Fuels, Mercury Adhesives, Hyde Soft Mounts, Vampower Pro Batteries
Hide Signatures
(in reply to swlarcham)
       Post #: 1205
RE: Black Magic VF3 Build Thread - 6/14/2009 7:12 PM
MHester
Score: 100
Status: offline
Quick update....
A few people were wondering about the latest 2 electrics I built, so I found the pics and thought I'd post em up. They aren't complete and I don't think they've flown yet, but they're close.
I'm not positive but the total weight of the completed airframe on the gear, painted covered and everything minus equipment was under 5 lbs. Not bad for a wood roach? Also not sure how it happened but they are both within 1/2 oz of each other. I didn't do the covering or the equipment install, but, they should be pretty cool. First chance I get I'll take some pics of the insides and such.
-Mike
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to MHester)
       Post #: 1206
RE: Black Magic VF3 Build Thread - 6/14/2009 7:14 PM
MHester
Score: 100
Status: offline
Jeez I need to clean my shop...these pics are a couple months old and it's worse than that now....
-Mike
Hide Signatures
       Post #: 1207
RE: Black Magic VF3 Build Thread - 6/14/2009 11:06 PM
Aussie_Knife_Edge
Score: 100
Status: online
Hi Mike,
Good to see the electrics going again. What do you expect the flying weight to be?
Also I assume you glassed the fuse and covered the wings, stabs and rudder with film. Is this correct?
Cheers
Jason.
Hide Signatures
       Post #: 1208
RE: Black Magic VF3 Build Thread - 6/14/2009 11:33 PM
MHester
Score: 100
Status: offline
Flying weight....no telling. Since I only did the build and paint, I can't predict that accurately. I'll let you know though!
These electrics have been coming out between 10 lbs and 11 lbs and everywhere in between.
Yes I did the glass and paint work, he's doing the covering on the wings and stabs and final assembly.
This one gave me serious headaches. For years I've painted planes and very rarely had a problem. With these, I lost count of how many times I had to sand all of the paint off and repaint it. It probably would have been a few ounces lighter. So take note: something is up with the pigment in some PPG concept paint. If you have any, test it out first. It's like the pigment was more like toner (like a candy).  Wouldn't cover, wouldn't flash. I ended up using some concept I had laying around for 5-6 years and guess what? Went on like silk. So be advised. I don't know if it was just a bad batch or what, but it tried to kill me.
I did, accidentally, find the trick for a super glossy pinhole-free canopy though. Wet sand it, spray on a thick coat of clear. let it cure for a couple of days...then wet sand it again and spray on just enough to flow a coat....voila, it looks GOOD!!!
-Mike
Hide Signatures
(in reply to Aussie_Knife_Edge)
       Post #: 1209
RE: Black Magic VF3 Build Thread - 6/16/2009 12:37 PM
BHolsten
Score: 100
Status: offline
I'm ready for some set up information,..throws high and low and any thing else I may need to get a general set up in the VF3.  Next weekend is the Lake City, SC contest. Camper hook ups, full bathhouse, etc.
Thanks in advance guys!
Bill Holsten
Hide Signatures
       Post #: 1210
RE: Black Magic VF3 Build Thread - 6/16/2009 2:04 PM
rcpattern
Score: 100
Status: offline
Bill,
Throws are kind of irrelevent as everyone has their own tastes.  You can pretty much look at what you like on other planes and go from there.  Here are the important numbers.
CG - At the front of, if not just in front of the wing tube
Wing Incidence - .5 degrees positive
Stab Incidence - 0
If you match those the plane will trim INCREDIBLY easy off the bench.  You should end up with 0 mix with right rudder and maybe 1-3% mix with left rudder.  You will need about 1% mix with down elevator trim.  If you accept those numbers you wont be happier.  It is when you try to play too much to get rid of that last little bit that causes problems with this plane.  You can probably fly it with zero mixes and not notice much of a difference, except the downlines, but on a dead calm day if you really look, you'll end up with just a little bit with left rudder.
For snap setup, lots of aileron and about 70% rudder with a little elevator thrown in for good measure.  Chip Hyde and I spent a lot of time last week really dialing in the snap rates and it does a wicked snap now, even at the top of the 1 1/2 avalanche in masters and that thing is a BI^&H.
I dug through some notes and found these numbers which will get you pretty close.  I haven't measured the deflections since Chip and I played last weekend.  I'll work on that this week.
Aileron
Up 15 degrees
Dn 15 degrees
Elevator
Up  13 degrees
Down 13 degrees
Rudder
All you can get for stall turns.  Adjust for snaps.
Team Futaba, YS Parts and Service, Central Hobbies, Tarable Graphics, Team Black Magic, Morgan Fuels, Tech Aero Designs
Hide Signatures
(in reply to BHolsten)
       Post #: 1211
RE: Black Magic VF3 Build Thread - 6/16/2009 4:53 PM
BHolsten
Score: 100
Status: offline
Thanks Archie,....
That will be a "GREAT" help in getting it close right off the bat! I will probably only have next friday to fly it, practice day before the contest. I can tweek it to my liking from there. I don't fly with any mixes other than down elevator w/ throttle, they drive me nuts. My Partner flies so bad I just can't mix anything out,..tried make the things it does good bad. So, I've been just dealing with it.
The 9Z-WC2 drives me nuts doing it. I have a opprutunity to buy a 14MZ brand new (3-years old) from a buddy of mine for $1,300.00, but not 2.4 (no big deal to upgrade it). Should I just go with the 12FG,...your opinion, since you have both.
Bill Holsten
Advantage Hobby Fliton field Rep/Custom Airframes Of America/ Dragon Fire Customs/Duralite/Guardian America.
Hide Signatures
(in reply to rcpattern)
       Post #: 1212
RE: Black Magic VF3 Build Thread - 6/16/2009 6:09 PM
rcpattern
Score: 100
Status: offline
I don't own a 12FG, but a guy I fly with owns one.  I have a 12Z and a 14MZ, but my brother has been flying the 12Z, so I haven't touched it in about 2 years.
The 12FG is a great radio.  It does about 95% of the stuff the 14MZ does.  Has a good feel to it, but I wouldn't call it great.  Personally I prefer the feel of my 14MZ and there are a few little tricks I've learned with the MZ that I'm not sure the 12FG will do.  The 12FG does have servo grouping and such, so it will work well for the big stuff too.  The 12FG is a great radio, but that is a killer deal on the 14MZ.  If you don't mind spending the extra money for the 14MZ it has some features which are really nice, but you wont go wrong with the 12FG either.
Arch
Hide Signatures
       Post #: 1213
RE: Black Magic VF3 Build Thread - 6/16/2009 6:21 PM
BHolsten
Score: 100
Status: offline
Thanks Archie,........
14MZ it is! Great price for sure,..didn't know if the extra money was worth the extra 5%. I'll PM you when I get it and see if you can share some set-up/mixing tips with me?
Bill Holsten
Hide Signatures
       Post #: 1214
RE: Black Magic VF3 Build Thread - 6/16/2009 11:25 PM
handglider
Score: 100
Status: offline
I am having a JR 9303 TX issue myself.  My right hand stick is sticky and crunchy when I hold full right aileron and bump up and down elevator. Just noticed it today on my 5th practice flight. I also seem to be getting little bumps of left aileron roll when I was flying straight and level. Really weird and not cool at all.
It might be time for me to break the bank and do a major upgrade. 12x or 14mz would be nice, now I only have to rob a bank
It will be on the way to horizon tomorrow. Since I am not running any mixes I may just run my el cheapo JR 6102 until I get it back.....
It's always something
< Message edited by handglider -- 6/16/2009 11:38 PM >
Hide Signatures
       Post #: 1215
RE: Black Magic VF3 Build Thread - 6/17/2009 12:34 AM
rcpattern
Score: 100
Status: offline
Dean,
Since you fly pattern if you were going Futaba I would go with the 12FG.  It basically does everything the 12X does at about half the cost.  It does everything you'll ever need for pattern.  I know Bill plays with the bigger stuff and that is where the 14MZ and the 12Z have additional features.  The 12FG is a killer radio for a killer price right now.
Arch
Hide Signatures
       Post #: 1216
RE: Black Magic VF3 Build Thread - 6/17/2009 12:43 AM
Ryan Smith
Score: 103
Status: offline
Cough, cough, 12X. Cough.
Team Horizon, Evil-R/C Products, YS
Hide Signatures
       Post #: 1217
RE: Black Magic VF3 Build Thread - 6/17/2009 2:43 AM
handglider
Score: 100
Status: offline
just took a quick look and it may be an issue with the stiff spring riding on the steel pin.
I'll take a closer look in the light of the morning.
< Message edited by handglider -- 6/17/2009 2:44 AM >
Hide Signatures
(in reply to Ryan Smith)
       Post #: 1218
RE: Black Magic VF3 Build Thread - 6/17/2009 3:44 AM
Ryan Smith
Score: 103
Status: offline
Dean,
Are you using aftermarket springs, or no?
Hide Signatures
       Post #: 1219
RE: Black Magic VF3 Build Thread - 6/17/2009 3:55 AM
handglider
Score: 100
Status: offline
Ryan, yea I am running the radio south springs.
I've heard the steel pins might pull out and cause some issues
Hide Signatures
       Post #: 1220
RE: Black Magic VF3 Build Thread - 6/17/2009 3:57 AM
RC_Pattern_Flyer
Score: 100
Status: offline
Ummmm cough cough... Airtronics 10SD 2.4... now on the market at a mere 499.
Let me know if I can help.
Chuck Hochhalter
Team Airtronics
Team Stafford Loaners (grin)
Mark Hunt Designs
Hide Signatures
       Post #: 1221
RE: Black Magic VF3 Build Thread - 6/17/2009 4:30 AM
handglider
Score: 100
Status: offline
that does look like a cool radio. but tower says maybe july...
Hide Signatures
(in reply to RC_Pattern_Flyer)
       Post #: 1222
RE: Black Magic VF3 Build Thread - 6/17/2009 4:53 AM
Ryan Smith
Score: 103
Status: offline
Dean,
I've always heard of aftermarket springs causing damage to the radio (any radio). You can crank the tension up pretty good on the stock springs, but I know the Radio South springs are a lot stiffer. The reports that I've always heard have involved the little tabs that the springs hook to breaking since they are plastic, but nothing involving the steel pin. Check any plastic around the pins to see if there is damage, if not, it may be a good idea to send the radio in.
I'll be glad to help in any way that I can, give me a shout.
Hide Signatures
       Post #: 1223
RE: Black Magic VF3 Build Thread - 6/17/2009 1:15 PM
jonlowe
Score: 100
Last Login: 2/24/2010
Status: offline
Dean,
Easy fix.  There is a steel pin that can work its way out and starts rubbing on the side of the stick assembly. It is what the plastic levers that have the springs on the ends of them ride on.  Push the pin back in a little with a small flat bladed screw driver, and use a dab of thick CA to hold it in place.  Hit it with some accelerator, and you are done.
Stiffer springs have not been an issue on JR's that I know of, if properly installed.  Tony has some tricks to make sure they don't break the tabs.  The steel pin issue seems to be the only weakness in the 9303, and is common with the 10x.  The 12x seems to have fixed the issue with the new assemblies.
I like my 12x a lot.  The new Airtronics looks interesting, but it only came out a couple of days ago, so user experience is limited.  It is going to be interesting to see how JR and Futaba react to the new Airtronics and Hitec systems that are considerably less expensive.
Jon
quote:
ORIGINAL: handglider
Jon Lowe
Hide Signatures
       Post #: 1224
RE: Black Magic VF3 Build Thread - 6/17/2009 1:53 PM
handglider
Score: 100
Status: offline
Thanks Jon,
I remember talking with you about this issue a while back. I am about to take a look at this.
Hide Signatures
(in reply to jonlowe)
       Post #: 1225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.266RCU1
