RACE READY XTREME
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Exceed RC Support - Nitro Cars >> RACE READY XTREME
Page: [1]
Login
RACE READY XTREME - 8/1/2007 12:07:47 AM
StephenW
Status: offline
wat hup ups would i get to make the xtreme race ready? Any advice will help.
       Post #: 1
RE: RACE READY XTREME - 8/1/2007 12:35:35 AM
AllAboutFunHobbies
Status: offline
You don't really want to add aluminum hop-ups to make a vehicel race ready, that makes them super heavy and slow. It depends on what kind of power you want out of your car, if you're racing off road you want to the engine to make max torque so you want a torque pipe, ex. http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_30&products_id=613 if you want more power at the top end like drag racing or street racing you want an RPM pipe, ex. http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_30&products_id=191. No matter what pipe you use, you want a smooth flow for the exhaust so you want a nice round smooth exhaust header like this one, ex. http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_30&products_id=121 along with changeing your header you need to replace your exhaust gaskets also http://allaboutfunhobbies.com/store/catalog/product_info.php?cPath=23_17_30&products_id=206, those parts alone will give you a huge boost in engine performance. Depending on what type of transmission you have you can change the clutch bells to lower or higher gears, if you go up with gears you loose bottom end speed but gain a WHOLE bunch of top speed, if you go lower with gears you loose top speed but gain a WHOLE bunch of tire spinning torque.
_____________________________
Dealer for...Redcat Racing, Traxxas, Team Associated, Cen, Racers Edge, RD Logic, Bodies by Blue, HPI, Himoto USA.....etc
(in reply to StephenW)
       Post #: 2
RE: RACE READY XTREME - 8/1/2007 2:13:57 AM
BackYardRacer
Status: offline
You should definetly get the torque stuff. Extreme bottem end is great. Im getting all that for my infinity truck
       Post #: 3
RE: RACE READY XTREME - 8/1/2007 3:21:44 AM
StephenW
Status: offline
Cool.wat does the header and gaskets do for the engine? Also wat do u mean by changing the clutch bells for lower ones? Thanks
(in reply to BackYardRacer)
       Post #: 4
RE: RACE READY XTREME - 8/1/2007 4:52:52 AM
AllAboutFunHobbies
Status: offline
The round header is smoother than the square odd shaped header and the exhaust pressure gets bounced around instead of just moving smoothly from the engine to the exhaust stinger and into the fuel tank, your exhaust system is like your fuel pump in your car. the pressures from the exhaust push fuel into the engine. With a smooth flowing exhaust you get better more even pressure going into the fuel tank, instead of irratic pulses from the stock setup. This increases the power of the engine and a more even fuel flow not to mention the exhaust can leave the engine in a fast smooth fashion. The exhaust gaskets seal the space between your exhaust headers and the engine so there is no air leaks which would cause the engine to run lean and hot. There is an exhaust gasket there now but once you remove the exhaust header you will need to replace the gasket everytime you remove the header they are not reuseable.
Clutch bells come in different tooth amounts, you can get a 10, 11, 12, 13, 14, 15 ,16, 17(stock, comes with car), 18, 19, 21 tooth and so on. The lower the tooth count the more power you have on take off, but your top speed will be reduced, the higher the tooth count the fast you will go, but your take off will be slower.
       Post #: 5
RE: RACE READY XTREME - 8/1/2007 5:22:42 AM
StephenW
Status: offline
were do u put the header? Also xtremes are 2 speed so would u get like a 10 20 so it would start fast than keep going fast or does that not work on 2 speeds
(in reply to AllAboutFunHobbies)
       Post #: 6
RE: RACE READY XTREME - 8/1/2007 5:28:43 AM
AllAboutFunHobbies
Status: offline
The header is the part that the exhaust pipe in connected to by the rubber connector, then the header is bolted to the side of the engine. No what ever tooth combination you get it has to be a five tooth difference on the 2 speeds, so it would be something like 17/22 or 13/18
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.578RCU1
