F4u5
Joined: 1/19/2002 From: Apple Valley, MN, USA Status: offline
We have a Century Jet here in town....I would avoid, myself (I advised this individual the same). The CJM P-47 has the same flaws found in the corsair. Poorly constructed and HEAVY. Every bit as bad as their Corsair that I had. For example, when we put the wing halves togehter, there was a 3/16 step between the 2 panels where they did not line up. CJM's response was that it couldn;t be so as they test fit everything. Guess what....it IS so. They do not line up at all. The spar joiner brace will need to be ripped and shimmed to get the panels lined up. Also, the aileron pockets were off. At the tip of the wing skin (outside tip of aileron) on one wing, there was a nice 3/16 to 1/4 inch pocket for the aileron where the balsa was glued in to the wing in for the hinges. On the other wing panel, the balsa is almost flush with the wing skin at the aileron tip. That means that the enitre balsa strip is off and the ailerons will not line up the same. The plywood pieces appear to just be thrown in there with a bunch of poorly laid glue beads. It looks like a 3 year old did the glue. Like the Corsair, there was a ton of flashing to be filed off, but at least CJM did that (on this one). And man will it be heavy. The cowl did not firt the fuse. IT will have to be cut and spread to mate. Cowl is too small at the back side. Look for it to be around 60+ pounds, maybe close to 70 pounds with Sierra gear (preferred), Glennis Wheels (preferred) and ballast. My Corsair still lays unfinished, as I assume this P-47 will end up.....unfinished. I am not bashing CJM, just advising of what was received for the money. I'd hold out for the Ziroli, albeit a bit smaller.
_____________________________
Where's my glue?.......I gotta build.
