RE: 47" Edge V3 New Batch!!!
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> RE: 47" Edge V3 New Batch!!! Page: <<   < prev  1 2 3 4 5 6 7 [8]
Login
RE: 47" Edge V3 New Batch!!! - 6/24/2008 7:32 AM
JRC
Score: 100
Last Login: 3/11/2010
Status: offline
I may have missed this - but what is the differences between the V3 and the previous versions
and can/should an unbuilt kit be retrofitted - thanks
p.s. is there an eta on more 540 v3 arf/kit
_____________________________
"In Thrust We Trust"
Hide Signatures
(in reply to AFSalmon)
       Post #: 176
RE: 47" Edge V3 New Batch!!! - 6/24/2008 6:36 PM
AFSalmon
Score: 100
Last Login: 3/14/2010
Status: offline
quote:
ORIGINAL: JRC
Many changes on the V3! Besides the two piece wings which can be removed for transport or permanently glued onto the fuse, the fuse now has a fiberglass tube internal along with balsa sheeting which provides a super strong and rigid fuselage. The wing has some improvements like slightly thinner airfoil. Also the tail control surfaces are enlarged over previous versions but the elevator counterbalances are ommitted so you won't break them off!
ETA is hard to say as I still have no hard evidence of the shipping status. Only verbal that the container has left China. Typically I would expect product in hand 4 weeks from that point.
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes
Hide Signatures
(in reply to JRC)
       Post #: 177
RE: 47" Edge V3 New Batch!!! - 6/25/2008 2:25 AM
Avalanche2
Score: 100
Last Login: 7/4/2008
Status: offline
Im having some dead stick issues with my OS 55AX.. can anyone flying one of these tell me the set up they have... rpms, low speed needle setting, h/speed setting... Ive checked all I know to check.. clunk/line is good,tank pressure ect.... sure is a blast to fly, would hate to hear silence about 10 ft off the deck... any help is appreciated..
"The only time you have too much fuel is when you're on fire."
Hide Signatures
       Post #: 178
RE: 47" Edge V3 New Batch!!! - 6/25/2008 4:28 AM
jeide
Score: 100
Last Login: 3/15/2010
Status: offline
What plug and fuel are you using? This is a great engine. OS#8 plugs are perfect. I like to use 25% cool power running a bit rich. Jim
Hide Signatures
(in reply to Avalanche2)
       Post #: 179
RE: 47" Edge V3 New Batch!!! - 6/25/2008 1:41 PM
AFSalmon
Score: 100
Status: offline
I use the stock OS plug and Cooper 10% fuel. Never had any problems. Had the stock muffler on but switched recently to the Tower Hobbies muffler and runs just as well. Flew the snot out of it this past weekend up at the Bryan Pro Bro event.
Ohio Model Planes
Hide Signatures
(in reply to jeide)
       Post #: 180
RE: 47" Edge V3 New Batch!!! - 6/26/2008 3:58 AM
Avalanche2
Score: 100
Status: offline
Im using Cool Power 15% w/ stock plug swinging a 13x4 prop... I think my last tach. reading was around 9400... It idles great, transitions good... ???? Im lost...
Hide Signatures
       Post #: 181
RE: 47" Edge V3 New Batch!!! - 3/16/2009 4:05 AM
maninblk
Score: 100
Last Login: 2/21/2010
Status: offline
Hello all, I just won this plane at the FX3D and have it outfitted with an OS 55AX, Question, what is the best prop for 3D practice. Don't want it too fast but not too slow either as i am still learning 3d stuff?
Hide Signatures
       Post #: 182
RE: 47" Edge V3 New Batch!!! - 3/16/2009 4:19 AM
Johnny Mojo
Score: 100
Last Login: 3/7/2010
Status: offline
Xoar - 13 x 4
APC - 13 x 4W
APC - 13 x 4
I like the Xoar the best, but they break easy. Get one of the APC's and you should be fine.
J.
Hide Signatures
(in reply to maninblk)
       Post #: 183
RE: 47" Edge V3 New Batch!!! - 3/16/2009 6:41 AM
maninblk
Score: 100
Status: offline
Thanks Johnny, will pick them up tomorrow and try it out.
Hide Signatures
(in reply to Johnny Mojo)
       Post #: 184
RE: 47" Edge V3 New Batch!!! - 3/16/2009 9:58 AM
Ernie Misner
Score: 105
Status: offline
Isn't anyone using the Saito 82 anymore? All I see is the talk of the 55AX which I know works great, but I have a spare Saito 82 sitting here.
With the Saito vs. the 55AX, would there be much difference in acheiving the correct CG?
Ernie
Hide Signatures
       Post #: 185
RE: 47" Edge V3 New Batch!!! - 3/16/2009 4:02 PM
rfan_1
Score: 100
Last Login: 2/19/2010
Status: offline
I started out with a 55AX, then switched to a Saito 82 to see what the difference would be. I switched back to the 55AX because the plane became too nose heavy, and that's with the 82 al the way back in the mount.
RFan
Hide Signatures
(in reply to Ernie Misner)
       Post #: 186
RE: 47" Edge V3 New Batch!!! - 3/16/2009 4:17 PM
n8kny
Score: 100
Last Login: 2/10/2010
Status: offline
I fly the V1 with an OS 70. Flies great!
Hide Signatures
(in reply to rfan_1)
       Post #: 187
RE: 47" Edge V3 New Batch!!! - 3/17/2009 7:49 PM
McChiken
Score: 100
Status: offline
quote:
ORIGINAL: rfan_1
RFan
Was reading through this cause I was thinkin of buying one to complement my MOJO . I have a new Saito82 and was thinkin of using it . I also have a .46 ax . I was looking at the weight diff between the .55ax and the Saito . The Saito is almost an 1oz lighter than the ax if you include the muffler weight . Maybe you have a lighter muff. ? I don't really like the sound of the 2-stroke winding out . Thats why i'd rather go Saito . More torque too .
< Message edited by McChiken -- 3/17/2009 7:51 PM >
Hide Signatures
       Post #: 188
RE: 47" Edge V3 New Batch!!! - 4/11/2009 6:36 PM
obriendigital
Score: 100
Last Login: 3/13/2010
Status: offline
I am considering buying a profile, more specifically an OMP product (either the Edge or ProYak). I have not had a profile before and was wondering how they handle the wind. Also, does wind make them a challenge to land?
Hide Signatures
(in reply to McChiken)
       Post #: 189
RE: 47" Edge V3 New Batch!!! - 4/11/2009 10:52 PM
The Toolman
Score: 138
Status: offline
Go look at my post over in the omp edge 540 folder you posted in
Ron
Ronnie-The Toolman<br>MTF#35665
Hide Signatures
(in reply to obriendigital)
       Post #: 190
RE: 47" Edge V3 New Batch!!! - 4/12/2009 2:13 AM
obriendigital
Score: 100
Status: offline
quote:
ORIGINAL: The Toolman
Ron
Thanks Ron, looks like a good setup. I have an engine and servos already that would work well. So, how do they handle the wind? And land?
Hide Signatures
(in reply to The Toolman)
       Post #: 191
RE: 47" Edge V3 New Batch!!! - 4/13/2009 12:54 PM
AFSalmon
Score: 100
Status: offline
I'll repeat my response here:
Flying the OMP Edge or ProYak in the wind is easy and actually a lot of fun. They handle the wing exceptionally well and honestly one of my top choices to fly when it is really windy. Doing rollers or HAKE stationary over the runway is a blast. Landings are also fun as you can float straight down onto the landing gear with zero ground speed.
Ohio Model Planes
Hide Signatures
       Post #: 192
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
