RE: SUCCESS! - A Brushless DF Conversion
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Draganfly Innovations Products >> RE: SUCCESS! - A Brushless DF Conversion
Page: <<   < prev  6 7 8 9 10 11 12 13 14 [15]
Login
RE: SUCCESS! - A Brushless DF Conversion - 10/26/2007 2:31 PM
msarid
Score: 100
Last Login: 6/21/2008
Status: offline
Hi Rusty
Please find Mike Dammar answer regarding to the motor problem.
Do your boards have a small black capacitor on the bottom of the PCB near the front the board on the 9 pin connector that attaches the vertical board?
That, and new capacitors on the motors should take care of it.
You should be able to copy the part position from one board to the other.
The part is a 68 UF 6.3 volt tantalum capacitor, make sure the polarity is correct
You can use a larger or slightly smaller capacitance, or a larger voltage part. A throughole part might be easier to come buy as well.
Have a great weekend
Moti
Hide Signatures
(in reply to 13BRV3)
       Post #: 351
RE: SUCCESS! - A Brushless DF Conversion - 10/29/2007 5:03 PM
msarid
Score: 100
Status: offline
Too quiet around here,wakeup
Hide Signatures
(in reply to msarid)
       Post #: 352
RE: SUCCESS! - A Brushless DF Conversion - 11/3/2007 3:26 AM
woorie
Score: 100
Last Login: 6/5/2008
Status: offline
Hi, all
Before CUTTING the pin of the old board for the BL modification with Berg RX, I want to ask if there is a way to 'disable' on-board RX. If I can disable on-board RX without damaging the board, and can feed PPM signal from the modified Berg into the 5th pin of the horizontal board or 9th pin of the vertical to horizontal board, I think I can easily return to the original brush motors without Spectrosolution's knowledge.
Another question is; As far as I can find PPM signals from RXs, can I use any RXs with more than 4 channels?
K.J. Woo
Hide Signatures
       Post #: 353
RE: SUCCESS! - A Brushless DF Conversion - 11/3/2007 6:26 AM
Old Man Mike
Score: 102
Last Login: 11/21/2008
Status: offline
quote:
ORIGINAL: woorie
Hi, all
If you disable the BERG receiver, the output may load down the PPM signal line. It is best to just make the cut. You can always solder it back if you want to send the board in for repair. Spectrolution really doesn't care if the board has been modified as long as you reconnect the cut pin so that they can test anything they repair.
By the way, if you have the DF with the BERG receiver, why not just unplug and remove the receiver? You could even insert a pin with the new Receiver PPM signal into the socket so that there is no modification to the board.
quote:
ORIGINAL: woorie
K.J. Woo
Yes, as long as you can find the composite PPM signal containing all the channels.
Mike
Hide Signatures
(in reply to woorie)
       Post #: 354
RE: SUCCESS! - A Brushless DF Conversion - 11/3/2007 9:39 AM
woorie
Score: 100
Status: offline
Mike
I have old board and I'm going to modify with separate 72Mhz Berg receiver and/or 40Mhz receivers from which PPM signals can be fed. (We can use both 72Mhz and 40Mhz in Korea.)
K.J. Woo
Hide Signatures
(in reply to Old Man Mike)
       Post #: 355
RE: SUCCESS! - A Brushless DF Conversion - 11/10/2007 5:15 AM
MORENOENNYC
Score: 100
Last Login: 7/25/2008
Status: offline
@13BRV3 Are you using your Futaba 2.4GHz mod with your UAVP? Do you have any updates with your mod...changes etc? I believe you're using 5 channels becuase the 6th pulse wouldn't cooperate. Lastly if possible, please explain how and where you installed the nand gate chip. Sorry for all the questions and thanks for your input.
Hide Signatures
       Post #: 356
RE: SUCCESS! - A Brushless DF Conversion - 11/10/2007 6:32 PM
13BRV3
Score: 100
Last Login: 4/22/2009
Status: offline
quote:
ORIGINAL: MORENOENNYC
The UAVP doesn't require a PPM signal, as long as the receiver outputs are "standard". The UAVP uses channels 1,3,5 and 7 (optional). The spaces between these channels are used to create the even channel inputs. The 2.4 GHz receivers don't necessarily have to play by the old rules, so they aren't all "standard", though the Futaba R606FS receiver works fine using 1,3 and 5. The 7 channel R607FS may or may not work using the 7th channel. Can't tell until Futaba release them, and Tower Hobbies fills my pre-order
One of the UAVP developers has written a beta version of the flight software that can use PPM inputs, inverted or not. This may allow some of the non-standard receivers to work, IF you can get a PPM signal out of them. With my modded Futaba receivers, I could use the PPM or not, but there's no advantage to using PPM, so I'll stick with the normal way.
Do you have any updates with your mod...changes etc? I believe you're using 5 channels because the 6th pulse wouldn't cooperate. Lastly if possible, please explain how and where you installed the nand gate chip. Sorry for all the questions and thanks for your input.
I just posted pics and more info on the 2.4 GHz DF conversion thread. If you have any other questions about the conversion, ask it there, and I'll answer if I can.
Cheers,
Rusty
Hide Signatures
(in reply to MORENOENNYC)
       Post #: 357
RE: SUCCESS! - A Brushless DF Conversion - 11/10/2007 9:54 PM
MORENOENNYC
Score: 100
Status: offline
Thanks Rusty
Hide Signatures
       Post #: 358
RE: SUCCESS! - A Brushless DF Conversion - 11/19/2007 12:59 PM
jesolins
Score: 100
Last Login: 12/9/2009
Status: offline
Mike,
Don't know if you checked out leaf rake tines for landing gear yet I found this post at the xufo forum. Here: http://forum.xufo.net/bb/viewtopic.php?t=7797 Sounds like the landing gear you were interested in was welding steel wire.
Cheers,
Jim
Hide Signatures
       Post #: 359
RE: SUCCESS! - A Brushless DF Conversion - 11/19/2007 3:43 PM
Old Man Mike
Score: 102
Status: offline
quote:
ORIGINAL: jesolins
Mike,
Cheers,
Jim
Thanks Jim but I no longer need landing gear with the 1000mm Quad Copter frame. With the recessed motors and small foam protectors at the ends of the carbon fiber tubes, no landing gear is necessary.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to jesolins)
       Post #: 360
RE: SUCCESS! - A Brushless DF Conversion - 11/20/2007 7:41 PM
tedrobphoto
Score: 100
Last Login: 4/23/2008
Status: offline
Hi, Mike
I am trying to contact you on this thread as the other thread seems to have died - I sent a private message with no success and wondered if everything is OK - it obviously is!-
A much simpler question (for now) I wanted to know the dimensions of the new board as I am building the frame ready for the new board from Mike Dammar - if you could let me know these I would appreciate it
Thanks again
Ted
Hide Signatures
       Post #: 361
RE: SUCCESS! - A Brushless DF Conversion - 11/21/2007 12:05 AM
Old Man Mike
Score: 102
Status: offline
quote:
ORIGINAL: tedrobphoto
Hi, Mike
Thanks again
Ted
Ted,
Check the other thread again. Since no one was asking questions, it fell back to page 4. It should be near the front now.
Mike
Hide Signatures
(in reply to tedrobphoto)
       Post #: 362
RE: SUCCESS! - A Brushless DF Conversion - 11/25/2007 8:38 AM
beckettrj
Score: 100
Last Login: 12/27/2009
Status: offline
I have a 2410-08 which worked on the last plane I put it on... and now I'm having a heck of a time setting up the ESC which is a Tower Pro Mag 8 18amp (the same one which was working!) I just moved the ESC and the motor over to new plane. I get beeps etc. but now the prop just rocks back and forth...
Any lay-mans terms instructions? I think I have the degrees off and i don't know what they should be...
3 degrees, 8, 15 or 30 degrees... ?
any suggestions?
Rod
Hide Signatures
       Post #: 363
RE: SUCCESS! - A Brushless DF Conversion - 11/29/2007 6:26 AM
aerohelipilot
Score: 100
Last Login: 4/6/2009
Status: offline
Is anyone interested in all the parts to do mikes orignial conversion. Motors speed controls optio isolators resistors I decided I needed money for other stuff.. All brand new never used email me at senshirev@msn.com
Hide Signatures
(in reply to beckettrj)
       Post #: 364
RE: SUCCESS! - A Brushless DF Conversion - 2/9/2008 9:30 PM
khaled_abobakr
Score: 100
Last Login: 5/25/2009
Status: offline
Old Man Mike ,
Do you think this mode will work with the X-3d quadro with the chinaboard i,, the receiver is also integrated in the board
Thank you very much
Khaled
Hide Signatures
(in reply to aerohelipilot)
       Post #: 365
RE: SUCCESS! - A Brushless DF Conversion - 2/10/2008 4:23 AM
Old Man Mike
Score: 102
Status: offline
quote:
ORIGINAL: khaled_abobakr
Old Man Mike ,
Thank you very much
Khaled
Sorry Khaled. I know nothing about that board.
Mike
Hide Signatures
(in reply to khaled_abobakr)
       Post #: 366
RE: SUCCESS! - A Brushless DF Conversion - 3/16/2008 9:13 AM
woorie
Score: 100
Status: offline
It's very quiet here.
Everybody happy with the Mike's brushless conversion?
K.J. Woo
Hide Signatures
       Post #: 367
RE: SUCCESS! - A Brushless DF Conversion - 3/18/2008 8:48 PM
jesolins
Score: 100
Status: offline
Hi Woorie,
They fly great! Mike Dammer has offered a new $375 experimental board for brushless and will mod last generation boards that can be identified by the 12 holes in the front for where the connectors for the ESC's will be installed for $55. Those fly great too, much better than the brushed versions!
Here is the info: http://www.rcgroups.com/forums/showthread.php?t=768115
Cheers,
Jim
Hide Signatures
       Post #: 368
RE: SUCCESS! - A Brushless DF Conversion - 3/23/2008 1:59 PM
woorie
Score: 100
Status: offline
I want to know whether someone who converted to Old Man Mike's method with their standard DF frame, optocouplers, TP 2410-09, 1045 props, etc..., are still enjoying their DFs.
There were sensitivity issues about gyros for larger and standard DF frames last Autumn in this forum but there seems no solutions yet.
I don't want to buy DF board for brushless motors, but want to use standard board to convert ...
In short, direct drive BL conversion on standard DF frame and standard board do not suffer from oscillation?
K.J. Woo
< Message edited by woorie -- 3/23/2008 2:20 PM >
Hide Signatures
       Post #: 369
RE: SUCCESS! - A Brushless DF Conversion - 3/24/2008 11:54 PM
jesolins
Score: 100
Status: offline
Guess I wasn't clear enough...yes I did the OMM BL opti-mod...it still flys great. Go to the link above for much more info. Many of us in that forum did this mod and then moved on to the experimental BL DF board that I also mentioned above. I also did a mod to add a 100k pot to the nick and roll gyros for even more stabilization and no continuous oscillations. Here: http://www.rcgroups.com/forums/showpost.php?p=9369652&postcount=941
Cheers,
Jim
Hide Signatures
       Post #: 370
RE: SUCCESS! - A Brushless DF Conversion - 3/29/2008 10:33 PM
khaled_abobakr
Score: 100
Status: offline
okay here is a detailed Power point version of the OMM Opto isolator brushless conversion mod applied to the Chinaboard / X-base (X-3d quad) by Jesolins
This diagram was revised by Jesolins and approved
I hope it helps anyone who wants to go brushless at an affordable price just like me hehe
Thank you very much Jesolins for your support and for revising the diagram
and of course Thank you very much Old Man Mike for making my dream come true by offering an affordable brushless solution
KhaledOMM mod detailed diagram
Hide Signatures
       Post #: 371
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.391RCU1
