13BRV3
FL, USA Status: offline
quote:
ORIGINAL: Old Man Mike I see no reason why it would not work with the older DF boards using the integrated receiver. The only challenge would be to find the line carrying the PPM throttle signal so that you could tap it and feed it to the optical isolator board. Someone with a older board and an oscilloscope should be able to probe around and find the signal. You can do this without arming the DF since the signal is there anytime the power switch is on and the transmitter is transmitting. The signal will be a simple 1ms pulse with a low duty cycle that varies in width as the throttle is increase. By the way, here is GREAT Oscilloscope which plugs into your PC via the USB Port: USB Oscilloscope Mike Hi Mike, Very cool, and cheap scope. If my employer didn't already supply me with a nice scope, I'd sure think about buying one of those. As for the throttle signal location on the older DF boards, I'll look for that this weekend. I already had the scope on it yesterday looking at the gate signals to the hexfets. Unfortunately, the conversion required to use that the gate signals would be harder than your idea. If anyone here has a really good understanding of these brushless motors, are there other good options available? The Feigao seems perfect, and the price is right, but I wonder about availability. Cheers, Rusty (trying to resist checking the DF now)
