Bob cat
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> Bob cat
Page: [1]
Login
Bob cat - 8/6/2007 6:04:42 PM
dave48
Status: offline
When mounting the eng. do you need too off the eng. or is built in?
       Post #: 1
RE: Bob cat - 8/6/2007 6:06:36 PM
opjose
Status: offline
I don't quite understand your question.
Are you referring to the down/up thrust? If so it's built in.
_____________________________
Build em'', fly em'', crash em'' and build more.
(in reply to dave48)
       Post #: 2
RE: Bob cat - 8/6/2007 6:52:53 PM
dave48
Status: offline
I`m sorry , what i was trying too ask do you need need too off set the eng. any degrees for eng. thrust.
(in reply to opjose)
       Post #: 3
RE: Bob cat - 8/6/2007 7:02:56 PM
opjose
Status: offline
Do you mean for Up/Down thrust?
If so, no. It's built in.
Since it's a pusher prop plane, there is also less of a "P Factor" effect for right thrust too, so get the engine lined up as straight as you can.
       Post #: 4
RE: Bob cat - 8/6/2007 7:17:49 PM
dave48
Status: offline
Thanks opjose
By the way would you know anything about the landing gear being weak? And what would be a good replacement set ?
       Post #: 5
RE: Bob cat - 8/6/2007 8:05:35 PM
opjose
Status: offline
IMHO they are not overly weak.
However they do not fair very well on hard landings and stiffer gear may do better UP TO A POINT...
( I would rather have the gear "give" then have the wing or fuselage damage. ).
I put in Robart 510W retracts in mine and these have fairly thick wire.
If you choose to go with the stock gear one simple solution is to solder a piece of re-inforcing wire as a cross brace... much like you would put in a tail support strut.
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU1
