Montague
Oh, I forgot, if you really want a remote, you can probably get a cap that fits from Global Hobbies. I haven't tried it, but Magnum is pretty good about parts fitting between engine sizes. So, you can probably unscrew the needle seat from the carb, screw on a cap, and then screw the needle assembly in to a remote mount. I think the part you want is the last part on this page: http://www.hobbypeople.net/part/210627.asp The carb plug. It says 32-91, but it IS the same part on the .25 and .28, and the .15 looks the same, but I've never tried it, so you're on your own there. The parts index is here: http://www.hobbypeople.net/part/partsndx.asp and you can find the Mag .15 and all it's parts. Another option (and one that I think some guys are doing) is to cut the needle off the Mag needle and then screw the needle valve all the way in. This turns it in to a plug. Then use an OS remote needle from the .15LA. The OS needles are finer than the Magnum ones. Though the new Mag .15XLS has a much finer needle with broader adjustment. But I don't know if any of the parts are interchangeable there, the carb is a totally new design.
_____________________________
Kirk Montague Adams RCCA 560
