vprpilot
VA, USA Status: offline
Hi Ernie, World Models puts out one of the best ARFs I have built. I liked the ZEN so much I talked one of my friends into buying it. He too felt the quality of the aircraft was superb. I am using a Futaba 8UA to control the A/C w/3001 servos on the rudder (pull/pull) and elevator and 9601 servos (2) for the ailerons. You could use standard servos in the wings as well. Only two things gave me problems with the construction. WM included bolts for axles which I replaced with bolt on axles. Additionally the pushrod material was not threaded correctly. The threads were not really threads in that there were just some grooves in the wire. Not a big deal, I just replaced it. I also replaced the spinner with one I liked better. The airplane flies quite fast and since it is small to begin with (46" wing span) you can't let it get as far away as a .60 size aircraft. The plane flies better than I do and I do believe makes me look like a better pilot than I really am. Rolls are very axial and stringing them together is very easy to do. Knife edge flight is also quite easy to accomplish. The OS 32 provides plenty of power for large loops, cuban-8's etc. The vertical is not unlimited but I would say more than adequate. Landings are quite easily accomplished although the plane does land faster than your typical sport model. I am using a Mac's Muffler on the .32 and turning a 9x7 wooden prop. I hope this helps. If I knew how to put pictures into this email I would share a picture with you. I put some of my own graphics on the plane. Vprpilot
_____________________________
VPRPILOT
