gasdriverca
Joined: 7/15/2007 From: Brantford, ON, CANADA Status: offline
quote:
ORIGINAL: SFC K quote:
ORIGINAL: gasdriverca quote:
ORIGINAL: SFC K Well I just spent a couple of days rebuilding my RS4. This was the RTR version which came with the stock Nitrostar .15FE motor. Upgraded was the shocks to powerline aluminums with yellow springs. .18SS motor, two speed tranny, racing clutch, THS racing pipe, turnbuckle kit, HPI TE37 wheels with 6mm offset, Venom Magnetics Super grip tires, and a PTI 05' Mustang body still in need of paint. I just need to break in the new motor now. Let me know what you think. See your pressure return line on you r car,is it not kinking on your chassis? the way you have your fuel tank(opposite way around). I tried my tank like that because the line was rubbing on the gears so i switched it like yours but my line kinks. To answer your question, it is not kinking at all. It works better this way then the standard mounting of the tank. You know what I just noticed there my man! you have a tuned pipe on there with a wire mount....I still have the stock mount bracket on my car so that's why mine is kinking. I suppose I should fork out some cash and get me one of those then which would solve my problems.
