davidgeorge212
AL, USA Status: offline
Hi, I have a problem with my charger. I have the super brain 989 and its not more than a couple months old, i have been charging up my lipos and they have all worked great until the other day I came in and put another battery on the charger. I pluged in the charger and the dislplay screen came up and it looked like it was ready to go so I pluged the battery in. Right after I pluged the battery in there was a real brightly glowing wire or somehting inside the charger and plumes of smoke came pouring out through the ventilation holes. luckily I tested my battery and I believe it didnt fry the battery but I have no clue as to what is wrong with the charger. I also saw that it almost melted the leads that plug into the ac power adapter box. Has anyone else experienced a problem as bad as this? Is there a way to fix it or should I just try to see if its still covered under warranty.
