supporting the pipe?
Tower Hobbies
Logged in as Guest
  Printable Version
Touchstart Remote Controlled Autostart Engine .61 ASP COLLECTORS !!!!!!!!!!!!!!
Seller:  vidal_felipe
Details:   $499.00   |  7/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> supporting the pipe?
Page: [1]
Login
supporting the pipe? - 8/8/2007 1:44:44 PM
Flying freak
Status: online
Hi
I have a jett 50 FIRE with tuned pipe should it be supported somwere because it is fairly long and is only held on by the header and the blue tuned pipe conector thing (the thing that looks like it could be the mother of all fuel tubing )
should i do somthign or just put the zipties on with the connector and call it a day??
Stevn
       Post #: 1
RE: supporting the pipe? - 8/8/2007 9:40:31 PM
rmenke
Status: offline
F Freak:
You need a pipe hanger for sure located at about the CG of the pipe. Go to Tower, available for around $10.00, think a Dave Brown product. Central Hobbies carries a number of different types. Its a easy install, but should connect to a piece of plywood to spread the load. Yes, the pipe-header connection is make from good quality silicone. Get the good stuff from Jett or Nelson or good HS. Last thing you want is to have the connection burn through and leave that $100.00 pipe waiving in the breez. ENJOY
(in reply to Flying freak)
       Post #: 2
RE: supporting the pipe? - 8/9/2007 1:11:48 PM
Flying freak
Status: online
Somthing like this? http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXZ667&P=M
its made by macs.....
or this http://www.greathobbies.com/productinfo/?prod_id=BRO1060
This is a 7.5cc pipe so do i need a 40 or 60 sized ^^^
Thank you
Steven
< Message edited by Flying freak -- 8/9/2007 1:16:24 PM >
(in reply to rmenke)
       Post #: 3
RE: supporting the pipe? - 8/9/2007 7:33:51 PM
bob27s
Status: offline
You definately want to support the pipe. Mount it at the fat part of the pipe --- or just aft of there.
The dave brown pipe mount is a good choice.
Hush mount or hard mount is ok. I prefer the hard mount if pulling a lot of G in the turns.
A zip tie on each side of the header coupler is needed too.
Thanks for the assistance there rmenke
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
       Post #: 4
RE: supporting the pipe? - 8/10/2007 4:46:11 PM
Flying freak
Status: online
please confrim that the Dave brown 40 size will work this is a jett 50 fire with a 7.5cc pipe
Thank you
Steven
(in reply to bob27s)
       Post #: 5
RE: supporting the pipe? - 8/10/2007 5:38:39 PM
bob27s
Status: offline
I can not directly confirm the size match, since I dont have a dave brown hush mount on hand, but the 7.5cc pipe is considered a .40 size pipe. No reason it should not fit... size mainly has to do with the size of the o-ring supplied.
I usually use the standard dave brown mount... uses a tie wrap to retain the pipe into a small cradle. So size is not an issue.
Bob Brassell
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU1
