RE: Foam Seawind EP from Great Planes...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Foamies! - RC Electric Foam Aircraft >> RE: Foam Seawind EP from Great Planes...
Page: <<   < prev  1 2 3 4 [5] 6   next >   >>
Login
RE: Foam Seawind EP from Great Planes... - 3/25/2008 4:55:22 AM
The_Mongrel
Status: offline
Looks great!
A little off topic, but if anyone is looking for another sea plane, I just maidened a Catalina - Vid of land and then water testing here... http://www.youtube.com/watch?v=b2p5Z3nJNEM
Cheers
-J
_____________________________
Crashing is such sweet sorrow!
(in reply to lthibault)
       Post #: 101
RE: Foam Seawind EP from Great Planes... - 4/2/2008 8:16:06 PM
SebM
Status: offline
quote:
ORIGINAL: Thomas B
I swapped out to a Balsa Products 2212-13, APC 8-6 slow fly prop and also moved the CG back 1/8=3/16" behind the factory suggestion.
It gets off the grass better and is flying a little better with that prop and motor....and the motor only costs 15.95.
Where did you bought this motor ? I'm trying to find one from Great Hobbies because I am in Canada but they don't sell that brand. They do offer lot's of brand but since I know nothing in electric I don't know what substitution could be as good. I like the low cost motor as it could help me buy the outfit earlier. I have nothing in electric so I need to buy everything which increase the price of getting this plane.
Thank you,
Séb
< Message edited by SebM -- 4/2/2008 8:17:17 PM >
(in reply to Thomas B)
       Post #: 102
RE: Foam Seawind EP from Great Planes... - 4/2/2008 8:59:00 PM
Dr Kiwi
Status: offline
http://www.lightflightrc.com/
Every Tom, Dick and Harry is re-badging these Suppo/Welgard motors - it is a most commonly found as a Suppo A2212/13.
Click to see fullsize image.
Click for fullsize
< Message edited by Dr Kiwi -- 4/2/2008 9:02:55 PM >
Dr Phil Millener, Chattanooga, TN
(in reply to SebM)
       Post #: 103
RE: Foam Seawind EP from Great Planes... - 4/3/2008 12:35:12 AM
SebM
Status: offline
quote:
ORIGINAL: Dr Kiwi
Nice web site, thank you. What do you think of their ESC ? The recommended ESC with the Seawind EP is a 25 A but on this web site they only have 20 or 30A and seem to recommend the 20A for their Suppo 2212-13 motor. Is that right and what do you think of this kind of ESC and motor combination compare to the recommended combination made by Great Plane ? I could save a lot but I don't want to get cheap stuff.
Séb
(in reply to Dr Kiwi)
       Post #: 104
RE: Foam Seawind EP from Great Planes... - 4/10/2008 2:30:34 PM
SebM
Status: offline
I have a dilema about my motor and batterie selection for my GP Seawind EP. I need advice about what is the best selection between theses two combo :
* Both from http://www.lightflightrc.com/
1) Suppo 2212-13 motor with 1320 Thunder Power 3s lipo batt.
OR
2) Suppo 2217-09 motor with 2100 Thunder Power 3s lipo batt.
So the first combo is really light but are ''maybe'' under powered ? While the second have lot's of power but it much more heavier, now will this extra weight cause problem ?
Here is the specs of the motors :
Suppo 2212-13 :
• 47g Mini Outrunner
• Kv: 1000, Rm: 0.090, io: 0.5A, Poles: 14
• Max watts: 145, Max amps: 12A for 60sec
• Shaft is 3.17mm
• Dimensions: 28mm x 30mm
Suppo 2217-09 :
• 70g Outrunner
• Kv: 950, Rm: 0.095, io: 0.9A, Poles: 14
• Max amps: 15A for 60sec
• Shaft is 4.0 mm
• Dimensions: 27.5mm x 30mm
* Specs of the original recommended GP motor are here : http://www.electrifly.com/powersystem/motors/motors-rimfire-28-30.html
< Message edited by SebM -- 4/10/2008 2:53:14 PM >
(in reply to SebM)
       Post #: 105
RE: Foam Seawind EP from Great Planes... - 4/10/2008 2:56:39 PM
dvagge
Status: offline
I am running the RimFire motor, but I went with a 1450KV rather than the 950 they recommended. I also use a 3 cell 2100 ThunderPower battery and the model balanced perfectly without having to add any weight.
(in reply to SebM)
       Post #: 106
RE: Foam Seawind EP from Great Planes... - 4/10/2008 3:04:43 PM
SebM
Status: offline
quote:
ORIGINAL: dvagge
And what is the weight of your motor ? If it balance perfectly with the 2100 TP and if your motor are not too much lighter than the bigger Suppo outrunner I may go with the second option. I am just a bit afraid of the complete flying weight.
* EDIT : I found your weight, it's the same 54gr. so my motor would be too heavy at 70gr.
Séb
< Message edited by SebM -- 4/10/2008 3:23:43 PM >
(in reply to dvagge)
       Post #: 107
RE: Foam Seawind EP from Great Planes... - 4/10/2008 4:22:13 PM
dvagge
Status: offline
You're right. If the motor is 70g, I think you are going to need significant weight in the nose to balance. The location of the motor is behind the CG, so that is going to be a big factor.
(in reply to SebM)
       Post #: 108
RE: Foam Seawind EP from Great Planes... - 4/15/2008 12:09:40 AM
supercubfloater
Status: offline
on the weight issue, my battery is a 2170 lipo, and i just placed it forward or back further in the fron of the plane, and i found perfect CG with the included CG balancer. not only that but with 2170mAh battery, im gonna be able to fly for 20 min at least lol
       Post #: 109
RE: Foam Seawind EP from Great Planes... - 4/30/2008 9:41:54 PM
jbarnes
Status: offline
Thought I'd post some pics of the SeaWind at Lake Powell this last weekend. Bone stock per the plans running a 2100 battery which provides a easy 15 minutes of flying time running 1/2 to 3/4 throttle. I am making one mod after this first trip out. I'm adding some 2/56 bolts to the hatch to keep it secure. If you dink a landing the hatch flys off and you find your Seawind sitting in the lake with smoke coming out of the open hatch. Note to self, always keep a spare ESC in the box.
Click for fullsize
Click for fullsize
Longmont Aircraft Modelers Association
Longmont, CO visit our site at www.lamarcclub.com
(in reply to supercubfloater)
       Post #: 110
RE: Foam Seawind EP from Great Planes... - 4/30/2008 9:45:33 PM
dvagge
Status: offline
Very cool pictures. Powell is my favorite place and that plane would add a new dimension to the trip.
(in reply to jbarnes)
       Post #: 111
RE: Foam Seawind EP from Great Planes... - 5/3/2008 1:51:42 AM
lthibault
Status: offline
Tried to maiden yesterday. Very calm conditions but the plane entered the ''skipping'' mode, then the canopy left the ship, resulting in a flooded Seawind... need more practice to master the take-off technique. I've also decided to use a screw to secure the canopy. Will try again later when conditions are less windy.
Luc
       Post #: 112
RE: Foam Seawind EP from Great Planes... - 5/3/2008 2:59:18 AM
The_Mongrel
Status: offline
BUGGER!!
I think the same rule would apply to the way I take my catalina off... smooth increase in throttle and get her up quick!!
Cheers
-J
       Post #: 113
RE: Foam Seawind EP from Great Planes... - 5/7/2008 4:06:22 AM
lthibault
Status: offline
Glad to report successful maiden yesterday. I practiced taxiing and take-off technique, once mastered it's very smooth. The plane glides beautifully and speed will lift it very quickly and gracefully.
A seaplane with a motor in this position is not responding like regular planes so it will take some time to get use to it. A few comments:
-This model is hot! Quite speedy and fast
-Ailerons were very responsive, had to use a lot of expo and reduce dual rate
On the overall I'm very satisfied with the Seawind EP! This one will be a keeper. Once you've sealed the wings and electronic equipment & secure the hatch no more water goes in. Also remember to put oil on the rods and maybe some lithium grease on the parts exposed to water.
Luc
(in reply to The_Mongrel)
       Post #: 114
RE: Foam Seawind EP from Great Planes... - 5/7/2008 6:55:35 PM
lthibault
Status: offline
Due to a perfect weather I made a few runs this morning, having more and more control and stability. I will try to mix a little bit of up elevator with the rudder (I'm lazy) and also some rudder with ailerons. The rudder make smooth and nice turns with this airplane. It has no bad habits, very smooth. I've read about the effect of a sudden throttle increase when getting close to the water but haven't really experimented it.
Going back to this topic, I really suggest that GP change the recommended low rate throws for the ailerons and reduce them. With the recommended configuration the low rate aileron throws were way too high, the plane was very nervous and rolling too much.
Luc
