SebM
QC, CANADA Status: offline
I have a dilema about my motor and batterie selection for my GP Seawind EP. I need advice about what is the best selection between theses two combo : * Both from http://www.lightflightrc.com/ 1) Suppo 2212-13 motor with 1320 Thunder Power 3s lipo batt. OR 2) Suppo 2217-09 motor with 2100 Thunder Power 3s lipo batt. So the first combo is really light but are ''maybe'' under powered ? While the second have lot's of power but it much more heavier, now will this extra weight cause problem ? Here is the specs of the motors : Suppo 2212-13 : • 47g Mini Outrunner • Kv: 1000, Rm: 0.090, io: 0.5A, Poles: 14 • Max watts: 145, Max amps: 12A for 60sec • Shaft is 3.17mm • Dimensions: 28mm x 30mm Suppo 2217-09 : • 70g Outrunner • Kv: 950, Rm: 0.095, io: 0.9A, Poles: 14 • Max amps: 15A for 60sec • Shaft is 4.0 mm • Dimensions: 27.5mm x 30mm * Specs of the original recommended GP motor are here : http://www.electrifly.com/powersystem/motors/motors-rimfire-28-30.html
< Message edited by SebM -- 4/10/2008 2:53:14 PM >
