myrcsupply
NV, USA Status: offline
We got it for less than that.... and we ship it for free w/ preorder and really this is a great deal when you think about having to purchase the DX6 unit as well as your other items to complete the 450se airframe. I talked with eflite about this, and they said that this is there answer to the 450, at a much better value. im sure we will need to swap out some stock for alum, and other things, but its a great start when you think about everything included. just some food for thought http://myrcsupply.net/index.php?main_page=product_info&products_id=47784 Features * Completely assembled and test flown at the factory * Capable of sport flying and 3D aerobatics right out of the box * Includes Spektrum’s DX6i 2.4GHz DSM2 6-Channel computer programmable transmitter and factory-installed AR6100e Microlite receiver * DS75 Digital Sub-Micro servos and G110 Micro Heading Lock gyro offer precise and powerful control * 420H brushless motor, 25-amp brushless ESC and 3S 11.1V 1800mAh 20C Li-Po battery deliver incredible power and performance * CCPM control with push-pull elevator and direct-to-swash aileron/pitch linkages Specifications Helicopter Specs * Type RTF Electric 3D Mini Heli * Main Rotor Diameter 28.2 in (718mm) * Tail Rotor Diameter 5.3 in (135mm) * Gross Weight RTF with Li-Po battery, 23.5 oz (665 g) * Length 25.6 in (650mm) * Motor Size 420H brushless outrunner, 3800kV * Kit/ARF/RTF RTF * Control System Spektrum DX6i 2.4GHz DSM2 computer programmabe transmitter (included), Spektrum AR6100e Microlite receiver (installed), DS75 Digital Sub-Micro Servos (4 installed), 120 degree CCPM * Rotor Blade Length 12.8 in (325mm)
_____________________________
"Remember this IS a hobby" - only 40% driving :) This is Savage Country, if you listen closely, you can hear the Revo overheat... Owner My RC Supply
