RE: 34% Colombo Anderson Extra 300L Buld!!
Tower Hobbies
Logged in as Guest
  Printable Version
C-130 Hercules 108" span Gas or Electric! - Kit
Seller:  penceaviation
Details:   $245.00   |  8/4/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: 34% Colombo Anderson Extra 300L Buld!!
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/18/2007 3:42:25 AM
Steve
Status: offline
Started the leading edge taper.
Click to see fullsize image.
Click for fullsize
_____________________________
AKA,, "The Spleen"
If you want to see my Super Power,,, pull my finger.
(in reply to Steve)
       Post #: 26
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/19/2007 1:00:51 AM
Steve
Status: offline
Got some end caps glued on. I always use a balsa stick down the center to keep it flat against the surface.
Click for fullsize
Click for fullsize
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 27
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/20/2007 3:53:37 AM
Steve
Status: offline
After a lot of teedious fitting and sanding, I got the wing root ends matched up to the fuselage sides and glued the root ribs on.
Click for fullsize
Click for fullsize
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 28
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/20/2007 6:07:28 PM
Steve
Status: offline
Next is setting the ani-rotation pins. There was just enough dowl to make six pins at 1 and 3/4 inches long. I marked these so I could set them so there was 1/2 inch of dowl showing when they were glued in. Just like the stabs, I used a small piece of 1/4 X 1/4 balsa when I set the incidence on the wings. Again I used the Robart meters for this process. All incidences are set at zero. Once the wings were set, I glued the 1/4 X 1/4 balsa to the fuse, under the wing so I could drill the pins without the wing wondering. I used a long 1/4 inch drill bit for this process.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 29
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/21/2007 8:03:35 AM
Olli-Matti
Status: offline
Hi Steve!
Nice to see that you have started the big one.
I am sure that with your previous experience from the 50cc version this
one should be a real winner. Just keep it as light as possible!
I have now a bit under 180 flights on my 27% extra, and it still is a pleasure to fly.
BR
Olli
(in reply to Steve)
       Post #: 30
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/21/2007 5:58:47 PM
Steve
Status: offline
Hey Olli,
Glad to hear your still flying your Extra. I need to get mine out again some time. I've been flying my 30%er all summer long. The CA has been just sitting as a backup. I think I put about 50 or so flights on it last year. I hope to have this one going by early spring. The only hold up for me is "servos", and weather. By mid October flying is done around here until we get enough snow to fly with skis on. I've been happy with the build so far. It is almost just like the 27%er, except for the tailfeathers!!
AKA,, "The Spleen"
(in reply to Olli-Matti)
       Post #: 31
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/21/2007 9:26:48 PM
Steve
Status: offline
After doing some thinking on the wing atatchment method, I went with the root end bolt. I cut four 1" X 1" X 1/4" hardwood blocks and made two 1" X 1" X 1/2" blocks and glued these into the root ends of the wings. I previously make a template with the root ply pieces to cover these. Once the blocks were glued in, I glued the support pieces over top for extra strength. Then I drilled through the fuse side and into the wings, center block. The blocks were then tapped for 1/4X20 bolts. I'm using plastic bolts, so I also drilled the rear anti-rotation dowls for pins as an extra safety measure.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 32
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/23/2007 1:18:48 AM
Steve
Status: offline
Next was to figure out where I was going to mounts the servos. The instructions don't give a lot of detail in this area. The wings are marked, but the servos run horizontal to the hinge line. I moved the servos 90* and closer to the hinge line. The instructions also don't give much detail on mounting the servos, so I decided to use a Dalton type servo mount. I built these out of 1/4" balsa sheet for the sides, 1/8" balsa sheet for the ends, and 3/8" X 1/4" spruce for the servo mounts. The servos are in about the same area that CA had them marked.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Steve -- 8/23/2007 2:16:21 PM >
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 33
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/23/2007 1:44:05 AM
Steve
Status: offline
Once I cut the sheeting with the hobby knife, I used my dremmel with the router bit to cut out the foam.
Click for fullsize
Click for fullsize
Click for fullsize
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 34
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/23/2007 1:46:56 AM
Steve
Status: offline
One more.
Click for fullsize
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 35
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/24/2007 2:01:11 AM
Steve
Status: offline
All of the servo mounts are in the wings and stabs.
Click for fullsize
Click for fullsize
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 36
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/24/2007 2:06:50 AM
Steve
Status: offline
The lines on the stab are marked for 3/8" balsa. I had to move the hinge line back 1/8" and use 3/8" balsa, (not the supplied stock), to get the amount of area I wanted to seat the hinges. I also counter-ballanced the elevators, which will help make up the diffferance plus some. The stab tube is very close to the hinge line at the stock location, and with the stock balsa sheet. I also wanted more deflection on the elevators, and 3/8" sheet on the elevator leading edge and stab trailing edge will do the trick. I'm going to use 1/2" balsa on the ailerons.
AKA,, "The Spleen"
(in reply to Steve)
