RE: 34% Colombo Anderson Extra 300L Buld!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: 34% Colombo Anderson Extra 300L Buld!!
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/1/2007 4:40:12 PM
Steve
Status: online
A couple more.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
AKA,, "The Spleen"
If you want to see my Super Power,,, pull my finger.
(in reply to Steve)
       Post #: 76
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/1/2007 5:44:49 PM
airborneSGT
Status: offline
I know its a strange question, but could you not run the ailerons and wing through table saw set at the correct angle and depth to get your bevels quickly?
(in reply to Steve)
       Post #: 77
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/1/2007 8:05:43 PM
Steve
Status: online
I know there are some people that do that. I just can't see how with the slight taper from the inboard end to the tip. If I practiced, or had a much larger saw, I could probably get it down. I just don't want to take a chance and mess up so I carve it down close, then sand it right on. A palm sander does make things go quicker, you just need to use a finer sand paper like 200 grit. I've also seen the dremel tool planer atatchment that looks way cool for this process.
AKA,, "The Spleen"
(in reply to airborneSGT)
       Post #: 78
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/1/2007 8:38:42 PM
airborneSGT
Status: offline
By trade I am a carpenter and I use the same method for wood paneling and wainscoating. I would think so long as you had a helper you could do it. For that matter perhaps its a posibility to do this PIOR to installing them. A simple jig of the female verions of your bevels would allow an accurate alighnment of your hinging.
Regarding the taper of the wings, I dont think it would be an issue. The portion being cut is going to be up againse the fence of the table saw. This will ensure a straight cut so long as you hold it firm againse the fence. I might trim a few pieces as an example to explain what I am talking about.
(in reply to Steve)
       Post #: 79
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/1/2007 9:25:00 PM
Steve
Status: online
I may have to give it a try on my next one. I'm giving seriouse thought to the Dremel planer atatchment at the moment.
AKA,, "The Spleen"
       Post #: 80
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/1/2007 9:37:14 PM
airborneSGT
Status: offline
Come to think of it you might even be able to get away with a router table using the correct bit.
(in reply to Steve)
       Post #: 81
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/1/2007 10:04:37 PM
Steve
Status: online
Absolutley. I've also seen those sanding drum tables that would be great for this hobby!!
AKA,, "The Spleen"
       Post #: 82
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/2/2007 3:44:01 AM
wifpwcf
Status: offline
she be ready to cover soon.looking forward to seeing colour go on it,
the wings i made were tested on sunday & they work great floats like a foamy.
cg
TEAM AUSTARS,TEAM TO MUCH FUN CLUB
TEAM BIG COURAGE DIAMONDS
(in reply to Steve)
       Post #: 83
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/2/2007 5:29:24 PM
Steve
Status: online
Yep, its getting closer. Looks like you did a good job on those wings! Glad to hear it flew great. I've got the right wing about rapped up. I went through some tools I had and found a long bladed sheetrock knife. This worked very good for carving the taper on the hinge line. I spent about half the time carving, and I needed very little sanding afterwards. I should have found that sooner!! I've got a strong 4.5" deflection each direction on the ailerons.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Steve -- 10/2/2007 5:30:13 PM >
AKA,, "The Spleen"
(in reply to wifpwcf)
       Post #: 84
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/2/2007 5:33:49 PM
Steve
Status: online
Its getting real close!!
Click for fullsize
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 85
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/3/2007 12:51:44 AM
airborneSGT
Status: offline
Steve,
Great to see you found a solution. I will post some pictures of my little carpentry experiment. Heck I should make a website with all the little tricks I have learned for model planes and carpentry.
(in reply to Steve)
       Post #: 86
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/3/2007 1:26:24 AM
Steve
Status: online
Souds good. Every bit of info helps!! I've been looking at some new tools.
AKA,, "The Spleen"
       Post #: 87
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/3/2007 4:40:45 AM
wifpwcf
Status: offline
looks wicked steve,im sure the long hrs will pay of
cg
(in reply to Steve)
       Post #: 88
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/3/2007 1:59:41 PM
Steve
Status: online
Thanks Glen,
covering is not my strong suit, but I'm going to try and get this one right.
AKA,, "The Spleen"
       Post #: 89
RE: 34% Colombo Anderson Extra 300L Buld!! - 10/10/2007 4:30:53 PM
Steve
Status: online
Just picked up an SWB 4" rudder horn. Can anyone give me some info on installation?
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 90
