34% Colombo Anderson Extra 300L Build!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> 34% Colombo Anderson Extra 300L Build!!
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
34% Colombo Anderson Extra 300L Build!! - 8/9/2007 4:55:20 AM
Steve
Status: offline
Well, after a couple of years on the shelf, I've decided to finish my 34% CA models Extra 300L. This is the older version of what is available today, but it should be an excellent project. I've got a BME 105 for power. I'm thinking of using dual recievers with no powerbox system, just the recievers. I'll use dual reciever batteries and switches, and a Smart Fly Optical Kill Switch. Servos will be Hitec 5955's for the elevators and rudder. I'd also like to use them in the ailerons, but I may use 5925's. There will be two per aileron. I'm going to use a Hitec programmer for the syncronizing.
I still have to do some sheeting on the fuse and install a couple more formers.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Steve -- 8/18/2007 3:32:46 PM >
_____________________________
AKA,, "The Spleen"
If you want to see my Super Power,,, pull my finger.
       Post #: 1
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/9/2007 4:57:33 AM
Steve
Status: offline
The rudder is HUGE on this plane.
Click for fullsize
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 2
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/9/2007 7:55:50 AM
Ragz
Status: offline
Steve, a very nice plane indeed. I have 31 flights on mine with a DA100. I dont do much 3d, but it can fly precise manuevers quite well. Enjoy the plane.
Anurag
(in reply to Steve)
       Post #: 3
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/9/2007 1:50:17 PM
Steve
Status: offline
Thanks Ragz,
Did you modify anything when you built yours?
AKA,, "The Spleen"
(in reply to Ragz)
       Post #: 4
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/9/2007 2:06:25 PM
Ragz
Status: offline
ummm..nothing really...except maybe bolted the stabs differently. Also cut the elevator with counter balance. used CF mains and tail gears...i will think about it more and let you know.
Anurag
(in reply to Steve)
       Post #: 5
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/9/2007 2:10:57 PM
Steve
Status: offline
I already have the Graphtec mains. I just need to pick up a Petes Models tailwheel. I plan on counter ballancing the elevators, "I think". I may go a little larger on the ailerons also. I need to look into some wing fasteners.
AKA,, "The Spleen"
(in reply to Ragz)
       Post #: 6
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/9/2007 2:18:23 PM
Ragz
Status: offline
i use bolts from the inside the fuse to hold the wing roots, rather than bolt from the top of the wings INTO the wing tube. I dont like that method. if u PM me your email, i will send u some pics.
Anurag
(in reply to Steve)
       Post #: 7
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/9/2007 3:17:35 PM
Steve
Status: offline
I've followed a couple of Carden threads and I also like the way they have the wings atached.
AKA,, "The Spleen"
(in reply to Ragz)
       Post #: 8
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/10/2007 10:26:55 PM
Steve
Status: offline
Got some more work done on it. I added the bottom sheeting. I also added a little extra where the stringers are a little weak due to length.
Click for fullsize
Click for fullsize
Click for fullsize
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 9
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/10/2007 10:29:26 PM
Steve
Status: offline
I also glued in the tri stock on all the formers where they meet the fuse. The rudder tray was also glued in.
Click for fullsize
< Message edited by Steve -- 8/10/2007 10:30:18 PM >
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 10
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/11/2007 5:36:53 PM
Steve
Status: offline
After looking over the instructions, there didn't seem to be any suports for the wing and stab tubes sockets in the fuse, so I made some rings out of scrap for the stab tube. Once glued in, I checked alignment and glued the stab tube in place. I also glued the wing tube sockets in place. I'll add some 1/4 X 1/4 to the top of the wing tube sockets. I also capped the ends of the tubes that will be glued into the wings and stabs.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 11
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/11/2007 5:40:01 PM
Steve
Status: offline
Couple more photos.
Click for fullsize
Click for fullsize
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 12
RE: 34% Colombo Anderson Extra 300L Buld!! - 8/12/2007 7:14:55 PM
Steve
Status: offline
Built the fuel and smoke tank mount next. I used a piece of 1/4 light ply and drilled some holes to lighten it up some. The rails are 1/4 X 3/16 spruce. This mount was set up parallel with the thrust line.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
AKA,, "The Spleen"
(in reply to Steve)
