RE: Hangar 9 1/4 Scale Piper Cub ARF???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Hangar 9 1/4 Scale Piper Cub ARF???
Page: <<   < prev  47 48 [49] 50 51 52 53 54 55 56   next >   >>
Login
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/2/2012 10:47 PM
Howard
Score: 120
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: Planejaw
Four good flights on the J-3 with DLE-20. Plenty of power but not so much that it's ridiculous! Lots of one-wheel landings across the runway. This has to be the best aircraft to do that with!!
On one (standard OEM) tank of fuel, I was able to get 4, 10-minute flights, plus have enough left in the tank for the better part of a fifth. Didn't actually fly the fifth, was working on fine-tuning the engine. Had a ''miss'' that was occurring at mid and high throttle settings that no amount of low or high needle adjusting could eliminate. Going to replace the plug and check the ignition timing before the next flights. Other than that, the DLE-20 is a sweetheart of an engine and just sips gas!!
Did you use the CA hinges or did you replace them Robarts or pinned hinges? I was thinking that it would be ok to use the CA hinges with the DLE 20. Thanks
Howard
_____________________________
If you want to be politically correct, try lying.
Hide Signatures
(in reply to Planejaw)
       Post #: 1201
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/2/2012 11:36 PM
cannonball200
Score: 105
Last Login: 5/18/2013
Status: offline
Howard, Eddie here, I started to change mine over to robart hinges but decided to use ca hinges instead..
The ca hinges will work fine on this plane and it was a lot easier. My last hanger 9 100" cub had ca hinges
And had lots of flights without any hinge problems at all..
Eddie
cannonball200
Waco" Brother #191 @ Cub Brother #122
Hide Signatures
(in reply to Howard)
       Post #: 1202
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/3/2012 12:07 PM
Planejaw
Score: 105
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: Howard
quote:
ORIGINAL: Planejaw
Howard
Howard,
I replaced all of the hinges with Robart 1/8" Point Hinges on the tail surfaces and DuBro 1/4 Scale hinges on the ailerons. I always replace the CA hinges. My preference over 47 years of building and flying. And I've even had the epoxy bond break on these type hinges in rare occasions, so I know it can happen. I think more "stout" hinges, if nothing else, have a longer useful life in an aircraft, particularly one where your running a gasoline engine and prone to much more vibration. And I'm not a 3-D flyer!!
John from Portage, Michigan
Cub Brotherhood #137, Fleet Brotherhood #6, Sig Kadet Brotherhood #38
Hide Signatures
       Post #: 1203
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/7/2012 11:12 PM
hidaven
Score: 100
Last Login: 4/22/2013
Status: offline
Im attaching the tail wires. Top ones are easy enough, what about the bottom wores? No location info in the manual.....for that matter, no info on where the tail wheel sits. Am i trying to line up the rearward tailwheel hole so the wires sit straight? Thanks!
Hide Signatures
       Post #: 1204
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/8/2012 6:10 PM
fly_69
Score: 100
Last Login: 5/27/2012
Status: offline
hidaven, There should be two holes in the aft bottom fuselage that you will need to remove the covering from those two holes to attach the tail wheel assembly. Look closely and you should be able to see where those pre-drilled holes are. There should already be blind nuts installed in the holes so be careful when using your hobby knife not to nick the threads of the blind nut as that can make the bolt not thread in easily. The bottom tail support wires will attach to the furthest rearward hole in the fuselage with the rear bolt for the tail wheel assembly.
Use blue Loctite (#242) on EVERY metal to metal nut and bolt. But! NEVER use Loctite with plastic nuts and bolts or with the metal locknuts with plastic in them. The Loctite will deteriorate the plastic and cause it to fail.
Fly
Hide Signatures
(in reply to hidaven)
       Post #: 1205
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/11/2012 4:17 AM
BlitzPig
Score: 100
Last Login: 3/2/2013
Status: offline
Planejaw,
Could you post pics of your throttle arrangement with the DLE-20?
BB
Hide Signatures
       Post #: 1206
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/11/2012 11:42 AM
Planejaw
Score: 105
Status: offline
quote:
ORIGINAL: BlitzPig
Planejaw,
BB
I'll shoot some photos in the next couple of days.
Hide Signatures
(in reply to BlitzPig)
       Post #: 1207
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/11/2012 6:42 PM
Bob dunlop
Score: 115
Last Login: 5/15/2013
Status: online
Started building mine today...took a little break and thought I would post some pics
Motor standoffs came up 1/8" short so I sandwiched the drilling template between the standoffs and the firewall after covering with aluminium and machine turning.
E-Flite Power 160
NanoTech 10s 35-70c 5000mah
Castle HV120 v2 esc
Dubro 6" air tires
Did not do the Oring conversion yet...the springs feel super stiff....wondering if they are using better springs these days...I bought a bag of Orings just in case
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1208
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/12/2012 9:09 PM
Bob dunlop
Score: 115
Status: online
 Kinda torn between using a BEC or RX pack....I have both....the BEC is certainly lighter but not sure that makes any real difference on this plane.
I have a brand new Castle BEC Pro that's good up to 12s and I have 2 brand new Lipo 2100mah RX packs.
What do you guys think?
Hide Signatures
(in reply to Bob dunlop)
       Post #: 1209
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/12/2012 10:25 PM
GalenB
Score: 105
Status: offline
quote:
ORIGINAL: Bob dunlop
I use a separate rx battery on my giant electrics 1/3 scale L-4 and 1/4 scale Fokker DVII... It just seems better to have redundancy.
Cheers!
Hide Signatures
       Post #: 1210
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/12/2012 11:47 PM
lumpy649
Score: 100
Status: offline
Hey Bob, where did you get that adjustable plane stand you are using? Looks very handy.
lumpy649
Hide Signatures
       Post #: 1211
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/13/2012 12:28 AM
Bob dunlop
Score: 115
Status: online
 The stand came from Ronny Garris...Rgarris@aol.com.....he advertises them here at RCUniverse
You can email him if you want one...they are very handy
Hide Signatures
(in reply to lumpy649)
       Post #: 1212
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/13/2012 4:42 AM
Bob dunlop
Score: 115
Status: online
quote:
ORIGINAL: GalenB
When you say "redundancy" are you saying you run 2 RX packs or a BEC and a battery?
Thanks,Bob
Hide Signatures
(in reply to GalenB)
       Post #: 1213
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/13/2012 7:15 PM
ZX11
Score: 100
Last Login: 10/29/2012
Status: offline
Bob,
I think electric wires need a grommet in the hole when ran thru metal firewalls. Prevents the metal from wearing thru the wire insulation.
Hide Signatures
       Post #: 1214
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/13/2012 8:10 PM
GalenB
Score: 105
Status: offline
quote:
ORIGINAL: GalenB
When you say ''redundancy'' are you saying you run 2 RX packs or a BEC and a battery?
Thanks,Bob
Redundancy is not the best word to use here... I think having an rx battery that is separate from the motor battery is a good idea. Any failure in the motor system, batter, ESC, etc should still allow for a normal dead stick landing. When using a BEC this may not be the case. This is how I setup my giant scale electrics... These planes use 5000-5800 mah 10 cell batteries and 90+ amp ESC...
Cheers!
Hide Signatures
       Post #: 1215
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/13/2012 8:16 PM
trixieandme
Score: 100
Last Login: 5/2/2013
Status: offline
That big they are really tail heavy and are not much fun just a flat flying plane not aerobatic.
Hide Signatures
(in reply to mobyal)
       Post #: 1216
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/13/2012 8:30 PM
Bob dunlop
Score: 115
Status: online
quote:
ORIGINAL: ZX11
Bob,
I agree...just have not had a chance to run over to Lowes yet
Hide Signatures
(in reply to ZX11)
       Post #: 1217
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/13/2012 8:34 PM
Bob dunlop
Score: 115
Status: online
 I think you are correct...a separate RX battery will be the safest solution...that's what I'll do...thanks for helping me make up my mind
Hide Signatures
       Post #: 1218
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/13/2012 8:46 PM
hidaven
Score: 100
Status: offline
Hi all.......going electric with a power 160 on 10s and a xoar 18x10. The collet or shaft is 12mm! Thats a big hole! Should I get a 12mm bit? Hope theres enough wood left on the hub!
Lastly, my freakin cowl opening is 5.5 NOT 6 inches off the firewall!!
Hide Signatures
       Post #: 1219
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/13/2012 9:38 PM
GalenB
Score: 105
Status: offline
quote:
ORIGINAL: hidaven
You need a 12mm reamer. They are available from Tower... http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNL18&P=ML
Cheers!
Hide Signatures
       Post #: 1220
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/15/2012 5:07 AM
Bob dunlop
Score: 115
Status: online
 I'll probably get mine in the air next week so while I'm thinking about it...is the recommended cg in the manual correct or have you guys found something else?
Thanks in advance ,Bob
Hide Signatures
       Post #: 1221
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/15/2012 1:51 PM
harttvboy04
Score: 100
Status: offline
Hi guys!
I just picked up a dle 30 that I feel would power the plane nicely. Can anyone show me some photos of their installs? I am thinking that the normal stand off's might be to long? I am also wondering about how/where the fuel tank should go- let me know guys - thanks!
Best,
Chris
Hide Signatures
       Post #: 1222
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/15/2012 11:19 PM
cannonball200
Score: 105
Status: offline
Blitzpig, Here are my throttle and tank hook up pictures. My J-3 is finished and tuned and ready for the test flight. Just waiting on the tornado's and wind to get past. The throttle and choke arms are PSP brand for the Walbro ordered from Chief Aircraft. They have dual set screws to keep them tight. The fuel filler is the gas version by slimline also from Chief Aircraft...
Eddie
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by cannonball200 -- 4/16/2012 12:48 AM >
cannonball200
Hide Signatures
       Post #: 1223
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/15/2012 11:48 PM
BlitzPig
Score: 100
Status: offline
Cool beans! Thanks for the info..
BB
Hide Signatures
(in reply to cannonball200)
       Post #: 1224
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/16/2012 1:38 AM
SkyPilot101
Score: 125
Status: offline
Eddie, Nice Look'in Cub! Did you have to add lead to C/G with the DLE-20? Are you running multiple battries? Fuel tank in stock location? I plan to power mine the same, reports have been good with the 20, let me know what you think after you ger some air under the tires. Thank's, Mike.
Hide Signatures
       Post #: 1225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.344RCU1
