RE: Hangar 9 1/4 Scale Piper Cub ARF???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Hangar 9 1/4 Scale Piper Cub ARF???
Page: <<   < prev  48 49 50 [51] 52 53 54 55 56 57   next >   >>
Login
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/24/2012 4:55 PM
GalenB
Score: 105
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: BlitzPig
quote:
ORIGINAL: GalenB
Can someone provide a link to the O-ring mod for the gear?
TIA!
Think it's somewhere in the middle. Maybe a few pages earlier,
It was farther back than I remembered... Post #796
_____________________________
Cheers!
Hide Signatures
(in reply to BlitzPig)
       Post #: 1251
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/30/2012 4:32 PM
rtn9105
Score: 100
Last Login: 5/20/2013
Status: offline
Do you guys think this airframe is strong enough for a 40cc gas engine?
Hide Signatures
(in reply to GalenB)
       Post #: 1252
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/30/2012 5:09 PM
cannonball200
Score: 105
Last Login: 6/19/2013
Status: offline
You would need to do some firewall work bracing. My Dle 20 fly's it with plenty of power. Are you planning on hovering and etc.?
Eddie
cannonball200
Waco" Brother #191 @ Cub Brother #122
Hide Signatures
(in reply to rtn9105)
       Post #: 1253
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/30/2012 6:05 PM
rtn9105
Score: 100
Status: offline
No not hovering
My plane has a G20 on it and it flies very nice and very scale but I do think it would be fun to have some extra power.
Hide Signatures
(in reply to cannonball200)
       Post #: 1254
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 4/30/2012 6:53 PM
cannonball200
Score: 105
Status: offline
That would work.... You always have throttle control.... try it and then it will have the horsepower of a Super Cub for short take offs and landings.
Eddie
cannonball200
Hide Signatures
       Post #: 1255
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/1/2012 5:28 PM
Bob dunlop
Score: 115
Status: offline
 Throttle control ?  I thought you just pushed that stick all the way up and left it
Hide Signatures
       Post #: 1256
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/1/2012 10:56 PM
hidaven
Score: 100
Last Login: 4/22/2013
Status: offline
What size servo arms are needed for the ailerons, rudder, elevator?
Hide Signatures
(in reply to Bob dunlop)
       Post #: 1257
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/3/2012 4:06 PM
tevans55
Score: 123
Status: offline
I am building this plane for for our local children's hospital. We have a Wings for KIds Air Show every June and we have raised $118,400 to date for the hospital. The hospital purchased this plane for our club to fly and display to raise money for the hospital. But I digress...
I tell you this because the servos were donated. They are the recommended Spektrum DS 821 servos. I fly Futaba and typically use Futaba and Hitec servos. As I began to cut the extra arms off of the Spektrum servo arms they seemed to be more brittle than what I was used to with Futaba or Hitec. I therefore purchased the DuBro HD Spektrum/JR servo arms and used those.
I don't know that there is any evidence that the standard arms would not work just fine...I just made the change primarily based on the size and ownership of the plane. I have put a donated 30cc engine on the plane so I feel the ounce of prevention is warranted. If the plane were to always be flown in a scale manner then standard arms again would probably be fine. This plane will be flown in air shows and demonstrations and will probably be flown beyond the scale parameters of the full scale cub. The reason for this will be to show off the modified graphics being added to the plane.
Hope this helps a little.
Nothing difficult is ever easy.
Spitfire Brotherhood #44
Hide Signatures
(in reply to hidaven)
       Post #: 1258
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/4/2012 8:33 PM
Bob dunlop
Score: 115
Status: offline
Finally got some time to work on the Cub again...it's ready to fly now...vacation starts Monday so I will maiden her then
Took some ideas from you guys and others for cockpit detailing...here are some pics
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to tevans55)
       Post #: 1259
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/4/2012 8:59 PM
lumpy649
Score: 100
Status: offline
Hi Bob,
How did your CG come out, I'm going to be installing the same power package as you and I am wondering if you had to add any addition weight for balance. Plane looks great by the way, Good Luck with the maiden
Gary
Hide Signatures
       Post #: 1260
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/4/2012 9:10 PM
Bob dunlop
Score: 115
Status: offline
 Thanks for the compliment...it's a little nose heavy ATM but that will be fine for the maiden...I like my planes a little nose heavy anyway
Hide Signatures
(in reply to lumpy649)
       Post #: 1261
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/4/2012 11:38 PM
Bob dunlop
Score: 115
Status: offline
 Just measured it on the CG machine...4 1/4.....I would imagine that should be ok...if not I can always tape a brick to the rudder
Hide Signatures
       Post #: 1262
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/5/2012 12:32 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Bob dunlop
W/all that awesome cabin detail a nice, detailed, scale Continental sticking out the sides of the cowl would make you Cub even more impressive.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 1263
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/5/2012 12:54 AM  1 votes
Bob dunlop
Score: 115
Status: offline
 Wow!  Thank you so much for that link....I was just sitting here wondering what to do about an engine..I'm all over this!
Thanks again,Bob
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 1264
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/5/2012 12:18 PM
SrTelemaster150
Score: 229
Status: offline
Thanks again,Bob
Here's the pdf file for the assembly manual.
http://www.topnotchkits.com/index_files/Gallery/ContEngine/Cont_Assembly_Manual.pdf
I'm going to get one of these in 1/5 scale for the World Models J-3 I just ordered.
Hide Signatures
       Post #: 1265
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/5/2012 6:04 PM
cannonball200
Score: 105
Status: offline
Great job on the interior of your J-3 Cub!!!!!!!!!
cannonball200
Hide Signatures
       Post #: 1266
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/5/2012 8:46 PM  1 votes
Bob dunlop
Score: 115
Status: offline
 Thanks Cannonball!...I just ordered the dummy engine and a new cowl to put it in...I'll post pics of the build
Hide Signatures
       Post #: 1267
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/5/2012 9:00 PM
SrTelemaster150
Score: 229
Status: offline
Did you order the Top Notch dummy engine kit?
Hide Signatures
       Post #: 1268
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/5/2012 9:26 PM
Bob dunlop
Score: 115
Status: offline
 Yep
Hide Signatures
       Post #: 1269
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/6/2012 1:56 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: SrTelemaster150
 Yep
Cool, let us know how it goes.
I want to get the 1/5 scale for my World Models Cub.
Hide Signatures
       Post #: 1270
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/6/2012 4:24 AM
hidaven
Score: 100
Status: offline
Anyone find a 12mm prop nut or spinner? This bare nut looks like junk! : (((
Hide Signatures
       Post #: 1271
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/6/2012 4:25 AM
BlitzPig
Score: 100
Last Login: 3/2/2013
Status: offline
For those using the DLE-20, how much and what parts of cowling are you cutting away for cooling? I've run a gallon through mine in the air without the cowling for break-in. I put the cowling on and it overheated after about 10 minutes of low power cruising around. I had only cut a 3 inch long gap for spark plug on bottom, opened the square airbox and opened the aft side of the the false cylinder baffling.
I came home and enlarged the two holes above the airbox and opened a large triangle on the bottom. I hope this is enough. I want to preserve as much cowling as possible. It doesn't help that it was 90F today.
Click for fullsize
Click for fullsize
< Message edited by BlitzPig -- 5/6/2012 4:57 AM >
Hide Signatures
       Post #: 1272
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/6/2012 5:52 AM
Bob dunlop
Score: 115
Status: offline
quote:
ORIGINAL: hidaven
I agree...I was going to use the WWI washer from Balsa USA but it just doesn't look right with that 12mm nut....I have scoured the Internet and have not been able to find anything in 12mm....I'm thinking about buying another 12mm prop adapter and taking it to a machine shop and having it turned down to 10mm...that will open up a number of possibilities,like the Balsa USA WWi 10mm prop washer and nut in that antique brass finish.
Bob
Hide Signatures
       Post #: 1273
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/6/2012 5:54 AM
Bob dunlop
Score: 115
Status: offline
quote:
ORIGINAL: BlitzPig
You may need to run your engine a little richer to keep it cool with the cowl on it
Hide Signatures
       Post #: 1274
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 5/6/2012 5:58 AM
Bob dunlop
Score: 115
Status: offline
 Yep
Will do
Hide Signatures
       Post #: 1275
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.796RCU1
