RE: Hangar 9 1/4 Scale Piper Cub ARF???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Hangar 9 1/4 Scale Piper Cub ARF???
Page: <<   < prev  48 49 50 51 52 53 54 55 [56] 57   next >   >>
Login
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/9/2012 9:44 PM
perreback
Score: 105
Last Login: 6/20/2013
Status: online
Hi guys,
today I put a new pilot in my cub. She did a rather good job, don't you think?
< Message edited by perreback -- 9/10/2012 1:43 PM >
Hide Signatures
(in reply to Pogs2004)
       Post #: 1376
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/10/2012 2:28 AM
cannonball200
Score: 105
Last Login: 6/19/2013
Status: offline
I have since removed the 8 oz of lead from the motor mount on my Hanger 9 1/4 J-3 Cub. I am running the DLE 20 with a custom Jtec muffler and the 6 volt nicad 2400 pack is stuffed under the floor up front below the fuel tank.
Balances just right @ 4 1/2" back and flys great.
Eddie
Click to see fullsize image.
Click for fullsize
_____________________________
cannonball200
Waco" Brother #191 @ Cub Brother #122
Hide Signatures
(in reply to cannonball200)
       Post #: 1377
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/28/2012 12:07 PM
Planejaw
Score: 105
Status: offline
Getting a little too cool here in SW Michigan for float flying, so removed the floats and installed landing gear and tailwheel. DLE-30 for power and Dave Patrick Super Cub cowl via Fiberglass Specialties on the business end. Hoping for a maiden maybe this weekend.
Recovered with Solartex and painted with Rustoleum rattle-can paint.
Click for fullsize
Click for fullsize
John from Portage, Michigan
Cub Brotherhood #137, Fleet Brotherhood #6, Sig Kadet Brotherhood #38
Hide Signatures
       Post #: 1378
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/28/2012 6:05 PM
Howard
Score: 120
Status: offline
quote:
ORIGINAL: cannonball200
Balances just right @ 4 1/2'' back and flys great.
Eddie
Eddie,
Can you take some pictures of the throttle arm and choke connections with the cowl removed. Also, did you have to move the fuel tank rearward any to accomodate the throttle arm or choke connection? I am trying to decide between the DLE 20 and the Zenoah 20ei. Thanks.
Howard
If you want to be politically correct, try lying.
Hide Signatures
       Post #: 1379
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/28/2012 7:11 PM
rcflyertim
Score: 100
Last Login: 12/6/2012
Status: offline
I have a first release version of the Hanger 9 PNP with a Zenoah Engine. There are 2 main problems that are being worked out.
#1 is the electronic ignition module. We I flew it it would cut out in flight after a minute or so for a second or two and then back on. It would never do it on the ground. After all kinds of email and options that were explored I finally removed it and sent it in to Horizon for a replacement. What I noticed about the mounting of the module was interesting. Contrary to what the book said the module was mounted with the epoxy side near the firewall. According to the book that was the only way you were NOT supposed to mount it. I informed Hanger 9 of this as well. When I received the new module and mounded it as the Zenoah manual indicated it has ran flawlessly. I suspect that the original install cause the module to overheat and that was causing the intermitted short.
#2 is the landing gear is so weak that it has spread out so far that I have to be careful not to let the prop hit the ground on landing. Not sure why the springs are so weak (cheap metal) but I have replace them. I still get bent wheels after 4-5 flights. I see that some have installed O-rings. Is that the best way to go?
Happy Flying
Tim
Hide Signatures
(in reply to Howard)
       Post #: 1380
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/28/2012 7:34 PM
cannonball200
Score: 105
Status: offline
I like my O'Ring conversion just fine.....Conversion thanks to "Planejaw"
Click for fullsize
Click for fullsize
Click for fullsize
cannonball200
Hide Signatures
(in reply to rcflyertim)
       Post #: 1381
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/28/2012 7:44 PM
cannonball200
Score: 105
Status: offline
Here are a couple of pic's w/the Dle 20. I drilled a small hole in the cowl for the choke rod to go through to thread into the dubro clevis. You can see the nylon tie wraps holding the 8 oz lead weights on the frame. I have since removed the lead weights as they are not needed. I have also put a small black sleeve on the choke pull wire end and touched up the drill marks which you see in the hole in cowl.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by cannonball200 -- 9/29/2012 5:28 PM >
cannonball200
Hide Signatures
       Post #: 1382
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/29/2012 1:17 AM
rcflyertim
Score: 100
Status: offline
Help me out here....what is holding the o-rings to the landing gear? Did you drill a hole through the LG?
Hide Signatures
       Post #: 1383
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/29/2012 1:52 AM
cannonball200
Score: 105
Status: offline
The hex nuts are already welded to the landing gear individual struts. The struts are 2 pieces per side and the tubes slide into each other. You just bolt in a 4/40 bolt the correct length to hold the spacers and washers; then wrap the o'rings around the washers, at least 2 per side.
It is a very easy fix. It then operates like the Robart's Cub gear.
cannonball200
Hide Signatures
       Post #: 1384
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/29/2012 11:00 AM
Howard
Score: 120
Status: offline
Thank you very much.
Howard
Hide Signatures
       Post #: 1385
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/29/2012 5:32 PM
rcflyertim
Score: 100
Status: offline
ok...got it thanks
Hide Signatures
       Post #: 1386
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/29/2012 8:57 PM
Lifer
Score: 153
Status: offline
Finally tried my Cub on floats today. Absolutely no problems. Need to keep a little more airspeed when attempting to flair, but other than that, no problems.
Hide Signatures
       Post #: 1387
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 10/3/2012 12:56 PM
Planejaw
Score: 105
Status: offline
Held a little "Cub" event at our field this past Sunday. I'm on the far left, my two Cubs, Army Cub and blue/orange Franken-Cub nearest the camera. Also attached is a You-Tube video of three of the four Cubs landing after a 4-airplane flight. My son was flying the Army Cub, I flew Franken-Cub.
http://www.youtube.com/watch?v=uv2TWr9L_Hc
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Lifer)
       Post #: 1388
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 10/3/2012 2:39 PM
JustFlyIt
Score: 100
Status: online
 Glad to hear that about the floats.  I have been working up the nerve to try mine.
DRS
Hide Signatures
(in reply to Lifer)
       Post #: 1389
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 10/3/2012 10:18 PM
Lifer
Score: 153
Status: offline
Just keep a little more airspeed when landing with the floats. They do create a lot of drag. Also, the water rudder servo arm needs to be short. The water rudders are VERY effective and the less movement you have at takeoff speed, the better. Save high-rate on the rudder/water rudders for taxi.
The plane flys much more sedate with floats. Everything is toned down. I spent most of the flight sitting on a log next to the shore.
Hide Signatures
(in reply to JustFlyIt)
       Post #: 1390
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 11/5/2012 1:49 PM
chuck l
Score: 108
Status: offline
I haven't had a chance to read this entire thread so bear with me if it has. Wil lthe new DLE-35 with the rear exhaust fit inside the cowl? My real concern is if the engine is too long to fit inside the cowl without moving the firewall.
WACO Brother #233
Hide Signatures
(in reply to Lifer)
       Post #: 1391
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 11/7/2012 2:19 AM
JustFlyIt
Score: 100
Status: online
 Lifer, thanks for the advice for float flying.  I didn't get a chance to try it but will definitely be hitting it next spring.
Also, I just bought the larger Du-Bro Cub tires....man do they look better.  I can't wait to fly it with them.
DRS
Hide Signatures
(in reply to chuck l)
       Post #: 1392
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 11/7/2012 10:55 AM
Lifer
Score: 153
Status: offline
Always a pleasure to assist a fellow modeler!
Hide Signatures
       Post #: 1393
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 1/2/2013 3:23 AM
nippaero
Score: 100
Status: offline
 Got a couple more flights in today at our club Polar Bear event. It was fun making soft field takeoffs and landings in the snow. Those big tires sure help
Click for fullsize
Fleet Brotherhood #27
Hide Signatures
(in reply to Lifer)
       Post #: 1394
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 1/2/2013 2:34 PM
hidaven
Score: 100
Last Login: 4/22/2013
Status: offline
Try the air filled Dubro 6 inch tires. The best aftermarket addition one can make on the plane. Very scale and it will save your stock gear springs. I have many flights on my stock gear with the stock springs with no hint of stretch due to the very forgiving nature of the low pressure tires.
Hide Signatures
(in reply to nippaero)
       Post #: 1395
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 1/2/2013 3:26 PM
nippaero
Score: 100
Status: offline
I've had the dubro 6" wheel and o-rings on the stock landing gear for two years now. No problems at all with a lot of flights.
Hide Signatures
(in reply to hidaven)
       Post #: 1396
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 1/2/2013 5:47 PM
hidaven
Score: 100
Status: offline
Do you all think I can run the power 160 on 12s??
Hide Signatures
       Post #: 1397
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 1/3/2013 3:41 AM
Wyoming Cowboy
Score: 105
Last Login: 5/24/2013
Status: offline
This is virtually unrelated but I happened upon the older red H9 Super Cub with a Saito FA-125.  I acquired it from a deceased club member but I'm moving and can't bring it with me.  Anyone know approximately how much it is worth fitted with the 125?  There are 3 Futaba S3010's in it for (rudder and ailerons) with S3004's elsewhere.  Runs on a R617FS FASST receiver and a 7C transmitter.  Located in the Ohio area...if interested PM me but just curious on the value, not really experienced enough to know.  Everything is new, never flown.
Top Flite B-25J Mitchell, Top Flight Cessna 182, Hangar 9 1/4 Super Cub, Hangar 9 Toledo Special
Hide Signatures
       Post #: 1398
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 1/3/2013 4:31 AM
nippaero
Score: 100
Status: offline
quote:
ORIGINAL: hidaven
As long as you watch the amps and don't over prop it. There are lots of guys running a 12s configuration on warbirds. Check your configuration on ecalc first.
I am using the Tacon 160 in my cub on 10S with a Xoar 19x10. It will hover and go vertical straight up on takeoff. I have three of these motors is 1/4 scale planes and all are performing great.
http://www.hobbypartz.com/96m608-bigfoot160-5335-245kv.html
Hide Signatures
       Post #: 1399
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 1/3/2013 1:33 PM
hidaven
Score: 100
Status: offline
Yeah your numbers are exactly what I'm getting on the power 160. I want to run 12s on a 17x8 xoar so I can use my 6s 5000s in there. I have way more planes and helis on 6 or 12 s and don't need to keep 4 new 5s5000s for one plane. Only problem is with the 12s config. I'm def. going to be nose heavy and may need to move my 2s 1800 mah life RX pack to the rear as I don't see any other alternative.........anyone cut a air hole in the back under the tail area?
Hide Signatures
       Post #: 1400
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.607RCU1
