RE: Hangar 9 1/4 Scale Piper Cub ARF???
Tower Hobbies
Logged in as Guest
  Printable Version
Advantage 2x2 meter F3A Pattern - RTF
Seller:  dbarrym
Details:   $1,250.00   |  12/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Hangar 9 1/4 Scale Piper Cub ARF???
Page: <<   < prev  6 7 8 9 10 11 12 [13] 14 15   next >   >>
Login
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 8/3/2008 12:18:03 AM
SKYPILOT
Status: offline
WELL,
I WAS going to install a Saito 125 in mine!! My Dad has the 1/4 sacle Super Cub (very similar in size and weight) with a 125. It was great on wheels, but now on floats is clearly underpowered. So, some decissions need to be made. I can upgrade the 125 to a 150 or 180, but i'm also looking into the Evolution 26. Lighter and more compact than the G20, but probably TOO much power. What to do?? decissions decissions
_____________________________
Regards, Scott
(in reply to EdChristian)
       Post #: 301
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 8/3/2008 12:23:01 PM
hercibird
Status: offline
quote:
ORIGINAL: SKYPILOT
WELL,
...... i'm also looking into the Evolution 26. Lighter and more compact than the G20, but probably TOO much power. What to do?? decissions decissions
SKY,
I have the EVO 26GT in my H9 25% cub. It is the PERFECT engine for this plane. It is not anywhere close to being overpowered. I get some really nice "CUB-speeds" at bout 1/4 throttle. Open her up to full and you have plenty of power for a vertical line to a gentle wing-over or a loop.
"When landing, the probability of survival is inversely proportional to the angle of arrival."
(in reply to SKYPILOT)
       Post #: 302
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 8/3/2008 10:01:35 PM
Joe McBride
Status: offline
Vic finally finished his Saito FG36 (over)powered Cub with some serious mods... clipped wing and crazy flaps. Good times shooting short field approaches in the local soccer field/track. Think I'll get me a pair of 6" Dubro's for those rough field days.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Team JR ~ Fromeco ~ Desert Aircraft
www.joemcbride.com
(in reply to hercibird)
       Post #: 303
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 8/3/2008 11:49:45 PM
rslstft
Status: offline
Joe,
Haven't even started on the Cub yet. Won't be home for quite a while, racing season going full swing and no time to get home, so probably will have to wait until late Sept or Oct before I get home. Hopefully won't take long to get together and head for the pond in Anaheim. Have a new TopFlite Staggerwing with a Evo 35 gasser all done and STILL haven't flown her yet either. Gotta find another job!!!!!
Russ
(in reply to Joe McBride)
       Post #: 304
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 8/4/2008 2:47:01 AM
SKYPILOT
Status: offline
Hercibird,
Thats intresting news. Could you load us up some pictures of the install ??. I'd love to see how it looks and fits in the cowl. Does it fit completely inside, or is there some exposure??.. Also, what muffler did you go with??..
Regards, Scott
(in reply to rslstft)
       Post #: 305
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 8/4/2008 1:14:35 PM
EdChristian
Status: offline
Update on engine sputtering problems. While changing out the electronic ignition unit, I was checking the clunk in the fuel tank and saw more in the tank than the clunk. I loosened the screw on the stopper and pulled it out to find that there was no back plate on the stopper. What I saw in the bottom of the tank was five pieces of the back plate that had been overtightened during the original build. I contacted Hangar-9 on Friday and told them about what I had found and wondered if that could be my problem. Was put on hold for a couple of minutes then the tech from Hangar-9 said a new tank would be sent. He did not say anything about whether that could be the problem or not. If the weather cooperates I'll be trying the new EI unit and a cleaned out fuel tank tomorrow evening.
Ed Christian
       Post #: 306
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 8/4/2008 10:33:44 PM
hercibird
Status: offline
quote:
ORIGINAL: SKYPILOT
Hercibird,
SKY,
I went with EVO pitts style muffler. Go to post #187 on this thread (pg. 8) for a pic of my EVO 26. I did a Super Cub mod on my cub, the engine sticks out of the bottom a little. Still looks great though.
       Post #: 307
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 8/4/2008 10:35:50 PM
hercibird
Status: offline
quote:
ORIGINAL: Joe McBride
Joe,
I knew the Big Wheel look and flaps would catch on ..............
-steve
       Post #: 308
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 8/4/2008 10:57:59 PM
dbarrym
Status: offline
Hey Joe - Isn't Vic taking the scale "rough field" landing thing a bit too far?
The FG36 is sweet, I have one in a 25% Decathlon, perfect match.
STILL waiting for my own 25% H9 Cub kit to show up (2 months+ and counting)....the floats are getting dusty...
Barry
       Post #: 309
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 8/5/2008 7:58:24 PM
Joe McBride
Status: offline
Right on Barry, call me when you get that CUB. We can go fly off of water in Chula Vista.
I threw the 6" Dubro's on mine yesterday and had a BLAST flying off that rough field.
Joe
www.joemcbride.com
(in reply to dbarrym)
       Post #: 310
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 8/5/2008 9:56:18 PM
SKYPILOT
Status: offline
Hercibird,
Am i right in saying that the stock cowl is deeper through the bottom section, from the crank center down than the cowl you used?? So, if the Evo 26 were used with the stock cowl, would it therefor fit in with less sticking out the bottom as yours does?? trying to get an idea of what it would look like.
I looked over your pics from post 187, and she looks great, congrats I personally don't like engines sticking out, and large cowl cutouts. Thats why i was intrested in the Saito 125 150 180, as they provide a completely inclosed instalation, but the tradeoff there is the oily mess, leading me to be intrested in a gas install..
Regards, Scott
       Post #: 311
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 8/22/2008 2:48:13 PM
louierc
Status: offline
Bill - I am planning to do an electric version of the Cub ARF with the recommended Eflite motor, etc. I see that there is no info in the manual showing motor mounting or battery placement. Has this been done before? Do you have any details? Thanks, Louie
(in reply to bbrundle)
       Post #: 312
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 8/23/2008 2:12:48 PM
fsheplavy
Status: offline
Has anyone yet found a Super Cub cowl that will accept an OS 160 twin for the H9 Cub? Would appreciate any info available.
TIA
Fred
(in reply to louierc)
       Post #: 313
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 8/23/2008 6:01:20 PM
sj3cub
Status: offline
Fred, You can buy a Dave Patrick Super Cub cowl from fiberglass spec. I have the DP Super Cub with a OS 1.60 twin and it fits in the cowl with no problems at all. I also have the H9 J-3 and it looks like the DP cowl could be fitted to the J-3 with a little modification.
Scott
(in reply to fsheplavy)
