RE: Hangar 9 1/4 Scale Piper Cub ARF???
Tower Hobbies
Logged in as Guest
  Printable Version
Wow! H9 33% Cap 232 New in Box! No Haggle Price!
Seller:  Dustflyer
Details:   $550.00   |  12/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Hangar 9 1/4 Scale Piper Cub ARF???
Page: <<   < prev  6 7 8 9 10 11 12 13 [14] 15   next >   >>
Login
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/2/2008 12:29:23 AM
captinjohn
Status: offline
That sure was some good flying....real fun to watch...so here it is again! http://www.youtube.com/watch?v=8OD8AFbYZ6c Capt,n
_____________________________
I never met a engine I did not like !
(in reply to Smokin Cap)
       Post #: 326
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/2/2008 3:34:15 AM
Joe McBride
Status: offline
That was great times Ken.
Looking forward to the vid!
Here are some pics:
http://picasaweb.google.com/bakinov9/BushCubbin
Team JR ~ Fromeco ~ Desert Aircraft
www.joemcbride.com
(in reply to captinjohn)
       Post #: 327
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/2/2008 6:32:04 AM
Smokin Cap
Status: offline
quote:
ORIGINAL: Joe McBride
Here are some pics:
And here it is............... http://www.youtube.com/watch?v=s_nv0xBMMaY
Keep it low....keep it Slowwwww
(in reply to Joe McBride)
       Post #: 328
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/2/2008 4:49:03 PM
CptCliffhanger
Status: offline
That was SUPER FUN!!! Thanks ken for the Video, and Mcbride, for all the shots! I can't wait to do it again!
Go big or go HOME!!! http://lunatique.com/stephan
       Post #: 329
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/2/2008 4:51:15 PM
CptCliffhanger
Status: offline
Oh and one more thing, maybe more on topic. These PNP cubs ar TOUGH!!!!! we are pounding these things, and they keep coming back for more!
< Message edited by CptCliffhanger -- 9/2/2008 7:18:47 PM >
       Post #: 330
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/3/2008 12:35:07 AM
MOTORMAN37
Status: offline
How is every body routing there antenna with a PCM system. The manual does not mention it.
********UPDATED*********
Got it figured out
< Message edited by MOTORMAN37 -- 9/3/2008 2:20:20 AM >
(in reply to CptCliffhanger)
       Post #: 331
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/3/2008 4:10:31 PM
CptCliffhanger
Status: offline
pretty sure there is a tube ran through the fuse for 72 mhz antenna, it lets out on the belly near the tailwheel.
(in reply to MOTORMAN37)
       Post #: 332
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/8/2008 12:16:17 AM
MOTORMAN37
Status: offline
What prop are you guys running on the G20's. I have been running a APC 16-6, but it seams just a smig to big (slow spool up). I am running 93 octane with Bell Ray MC-1 at 50:1 and getting 8,800. Has anyone tried the Evoulution 16-6 on the G20? I forgot, I am also running C&H ignition set at 30 degree's.
       Post #: 333
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/8/2008 1:14:06 AM
CptCliffhanger
Status: offline
mine is the PNP so it's running the oroginal evo 16x6 that it came with, spool is fast after leaning the low end quite a bit from factory..
       Post #: 334
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/15/2008 11:14:18 PM
richardfrancisburton
Status: offline
Question for your 1/4 scale Cub guys from Hangar 9...
My question is this: I just bought a Hangar 9 1/4 scale Super Cub. It does not have the fancy cockpit kit that this J3 Cub does. I wondered if you guys think that the seats and pilot figure will fit just fine into the Super Cub ... ??? Do you think the Cabin area is the same on them??? Anybody out there own one of each? The wingspan and dimensions of the plane are outwardly the same. Mine just has flaps and a G-26 Zenoah engine.
Any thoughts on this would be appreciated and thanks.
       Post #: 335
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/16/2008 2:20:50 PM
bbrundle
Status: offline
Unfortunately they are two totally different models. I do however think that you could make a floor piece that would accept the seats from the current 1/4 Scale J-3 Cub. The new seats are designed to interlock into the florr and then the center access hatch in the floor locks them in place. This allows for easy removal, but you could just cut off the small tabs on the bottom of the seats and just lue or velcro in place with the addittion of a balsa base piece.
I hope this helps answer your question?
Bill Brundle
Senior Product Developer Hangar 9, Saito, & Evolution
(in reply to richardfrancisburton)
       Post #: 336
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/16/2008 3:58:49 PM
CptCliffhanger
Status: offline
any plans for a supercub again from H9.. seems this j-3 would be super easy to convert, flaps, square the tips, new cowl, and maybe counterbalance the elevators if you're feeling ambitious, and presto, best supercub on the market!
Stephan
(in reply to bbrundle)
       Post #: 337
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/25/2008 1:23:28 AM
ezflyr
Status: offline
Hi All,
With the weather turning colder in the Northeast, I'm thinking it would be fun to fly my Hangar 9 1/4 scale Cub on skis this winter. Does anyone know of a source for the correct size skis, hopefully somewhat scale?
John
John
       Post #: 338
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 9/25/2008 3:13:33 PM
overbuild
Status: offline
My Hangar 9 Cub is powered with a Saito 120.I could not keep engine running air bubbles in fuel line.I tried new tubing from clunk out to carb. still air bubbles.I think tank stopper plug may have been leaking air.Horizon sent me a new tank assy. which I installed [it was assy. I did not have to install clunk etc.] started engine no air bubbles run fine. Hope this information may help.
       Post #: 339
RE: Hangar 9 1/4 Scale Piper Cub ARF??? - 10/7/2008 1:48:47 AM
jradley
Status: offline
I put one togeather for a new club member, and I mean new, so I had to fly it also, We put a zenoah 20cc electronic ign. and a futaba 7c radio, This thing flys great, Take off is smooth and landing is just as good, only thing that happened was the spring on one side of the tail wheel came off. Balance was perfect following directions. Crabs just like the real thing. You can't go wrong!!! Jeff
(in reply to mobyal)
       Post #: 340
