Sheeks Spitfire stunt silk covered wing
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Control Lines >> Sheeks Spitfire stunt silk covered wing Page: [1]
Login
Sheeks Spitfire stunt silk covered wing - 8/10/2007 5:29:43 PM
cutaway
Status: offline
Outboard panel has a couple of thin coats of Butyrate on it so far after nitrate prep, inboard is raw waiting to dry out completely from the wet covering. It'll get a few thin coats of nitrate, then I'll start on the butyrate.
I would add that SIG's recommendation to not use Nitrate for initial coats over silk is a crock. Two thin coats of nitrate to seal the weave a bit work just fine. A subsequent thinned butyrate coat will soften up the underlying nitrate and shrink it up "drum tight".
< Message edited by cutaway -- 8/11/2007 3:55:20 PM >
       Post #: 1
RE: Sheeks Spitfire stunt silk covered wing - 8/10/2007 7:53:19 PM
culver
Status: offline
Looks sweet, keep posting pictures of your progress.
(in reply to cutaway)
       Post #: 2
RE: Sheeks Spitfire stunt silk covered wing - 8/11/2007 6:55:29 PM
cutaway
Status: offline
I just weighed it now that its got a few coats of Butyrate on all the panels -- 11.5oz. Not too outlandish I guess, but a bit on the plump side.
When I was building the I-beam I didn't have any 1/16 ply on hand and used 1/8 instead. That cost some and I widened up the center ribs to get more gluing area which cost some too.
(in reply to culver)
       Post #: 3
RE: Sheeks Spitfire stunt silk covered wing - 8/27/2007 11:02:28 PM
cutaway
Status: offline
With some of the fuselage completed. Being a bit scared of it going tail heavy on me, I've substituted a stringer fabed top rather than the big balsa block the plans showed. I think the stringer deck will look cooler when its covered in silk too;->
       Post #: 4
RE: Sheeks Spitfire stunt silk covered wing - 8/29/2007 1:29:00 AM
dasflugmodele
Status: offline
Looks like a great job you are doing. I have a Spitfire, Mackey plans and it flies great. If you do a search for Spitfire Stunter there are several postings with pictures. Vauxhall has a nice one also. Great airplane. It shoud be a fine flyer.
Dasflugmodele
       Post #: 5
RE: Sheeks Spitfire stunt silk covered wing - 8/29/2007 3:37:12 AM
cutaway
Status: offline
The Sheeks Spitfire is a 1967/68 vintage design. It was originally featured in Flying Models. I wish I had the mag with the construction article. The plans were lacking in some areas and I had to kinda freehand a few aspects of it.
(in reply to dasflugmodele)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU5
