shall36
FL, USA Status: offline
Here's an update on the bird and the engine. After much discussion with lots of people, I think there are three things going on with the engine. First, the engine only has about 3 gallons through it. From what I hear, things don't start to settle down until about 5 gallons. Second, I think the low-end needle is still rich. When I measure head temp after a flight (with engine at high idle), I'm reading about 125* F. No where near what other guys report. Third, the 23x8 prop may be a bit much. I'm going to throw a 22x8 prop and see if that resolves the power band issue. I upgraded to a 9303 TX. What a big improvement over the 8103! Setup is a breeze. I resolved the uneven throw issue. What I found is that I had to use quite a bit of subtrim to get the left elevator servo arm to be 90* to the servo body. The spines were just too coarse to make a mechanical adjustment. Given that offset in subtrims, I found that if I jacked-up the throw on the computer for the servos to get the throw I wanted, one of the servos would finish before the other servo. The order of finish flips when you go in the other direction. So, I just backed off on the travel adjust and made sure that the servos finished at the same time. The 9303 makes dual elevator servo setup a breeze! The plane will mildly snap to the right IF you pull back hard on the stick and you are slow (or bleed off too much speed to fast). The plane is laterally balanced; I think the preference of the plane to snap to the right is a function of engine/prop dynamics. The plane is flying good, not perfect. Coupling on knife-edge is minimal. Rolls are close to axial (I need to play with the differential to correct this problem). Stalls are predictable and clean. Full 3-D throws are a blast and the plane can do some interesting things with full throws and full power! I can just about hover in an inverted spin. Landings are a breeze...if anything, the plane will float on me. I can idle the engine down to about 1500 for approaches. There might be a better 50cc plane on the market, but it can't be much better than this one!
