Savage spur gear
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> HPI Monster Truck Forum >> Savage spur gear
Page: [1]
Login
Savage spur gear - 8/11/2007 4:59:43 AM
zud00
Status: offline
What's the stock savage spur gear...how many teeth? stock cb/sg teeth?
What's the benefits of changing it higher or lower?
I'm having problems stripping my spur gear. I need to learn how to set it up properly.
_____________________________
Savage X w/LRP z28 spec 3
Bash Big or Go Home!!!
       Post #: 1
RE: Savage spur gear - 8/11/2007 5:19:58 AM
gravediggerracing
Status: offline
Depends on the Savage. The original .21 Savage used a 52T spur and a 14T CB. All the .25s used a 49T with a 15T CB, but a 18T CB was optional. A 47T also came with the .25 Limited Edition version along with the standard 49T and it used a 15T CB or the optional 19T CB. All .28s used a 47T with a 17T CB.
< Message edited by gravediggerracing -- 8/11/2007 5:32:38 AM >
There is no replacement for displacement
(in reply to zud00)
       Post #: 2
RE: Savage spur gear - 8/11/2007 5:37:03 AM
zud00
Status: offline
Sorry...guess I should have mentioned I have Savage X 4.1 rtr.
(in reply to gravediggerracing)
       Post #: 3
RE: Savage spur gear - 8/11/2007 12:45:02 PM
munro300
Status: offline
Its a 49 tooth, just put a piece of note book paper between gears then push engine up tight and make sure its lined up then tighten it down. Pull the paper out and feel the tiny bit of play in the mesh, it has to be so small you can hardly feel it.
(in reply to zud00)
       Post #: 4
RE: Savage spur gear - 8/11/2007 5:17:50 PM
evaderstbasher
Status: offline
are you suppose to fold the paper in half or anything? to double it up?
and are you using actual notebook paper with lines?
Savage .25 starting to possibly like it?!
Nitro Evader ST (hopped up)
(in reply to munro300)
       Post #: 5
RE: Savage spur gear - 8/11/2007 6:38:14 PM
gravediggerracing
Status: offline
No fold. I find slighter thicker printer paper works better than thinner notebook paper.
Once you get a feel for what kind of play is supposed to be between the gears, you'll find yourself setting the mesh without the paper.
(in reply to evaderstbasher)
       Post #: 6
RE: Savage spur gear - 8/11/2007 7:35:11 PM
zud00
Status: offline
Tell me if I'm understanding this correctly...put the piece of paper between the two gears and smash them together, tighten down the motor, and then pull the paper out and you should be good to go. They should be synced so that if you move the spur, it moves the clutch bell. But you should be able to move the spur ever so slightly without moving the clutchbell before they catch. is this right?
       Post #: 7
RE: Savage spur gear - 8/11/2007 7:43:26 PM
46u
Status: offline
When taking the paper out it should not tear. When turning the spur you should not feel any bind and there should be just a small amount of gear lash.
Rebel Racing, Sponsored by, Byron Fuel Looking for a new engine sponsor!
(in reply to zud00)
       Post #: 8
RE: Savage spur gear - 8/11/2007 7:55:47 PM
zud00
Status: offline
Got it. Thanks for the replies.
(in reply to 46u)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU4
