Old plane caution
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Control Lines >> Old plane caution Page: [1]
Login
Old plane caution - 8/11/2007 5:31:35 AM
cutaway
Status: offline
I just tore the ratty 20 year old solid color Monocoat off my 30 year old Magician to re-cover it for the 3rd time and the leadouts were VERY VERY RUSTY inside the wing. To the point where their strength was clearly compromised. The portion of wire extending out the tip was fine...I'm guessing due to fairly constant exposure to oil residue.
Its going to need some surgery as well as new covering.
I'm thinking I'll wipe down the new leadouts with acetone and paint'em with Rustoleum before fishing them back in.
UPDATE: pic of rebuilt Magician with new silk covering, new cloth hinges, beefed up spar, new leadouts, and fresh paint. Ready for another 20 or 30 years ;->
< Message edited by cutaway -- 8/17/2007 10:34:48 PM >
       Post #: 1
RE: Old plane caution - 8/11/2007 4:07:22 PM
build light
Status: offline
great tip.
Robert
_____________________________
Roll! Tide! Roll!
Go Crimson Tide!!!
(in reply to cutaway)
       Post #: 2
RE: Old plane caution - 8/12/2007 4:38:35 AM
cutaway
Status: offline
Heh, on closer inspection I found a cracked main spar too. This is the 3rd cracked spar I've had on this plane. Maybe the old MAgician wasn't really designed to handle a pressurized open venturi G21 .35 Tigre ;->
(in reply to build light)
       Post #: 3
RE: Old plane caution - 8/12/2007 6:10:00 AM
cutaway
Status: offline
And a couple of the old cloth hinges on the elevator have given way too...
       Post #: 4
RE: Old plane caution - 8/15/2007 3:13:49 AM
Lou Crane
Status: offline
The advantage of building from kit or plan as against ARF, etc., is that you did it once, so you have an idea - even years later - of how to do again what is needed.
Magician is a fine flier! Clean it up; correct what's needed, and enjoy a great model!
Have you tried a wipe, say 3-in-1 on a paper towel, on the leadouts to see how much is left usable? Might be more that you think, but if it isn't, you'll be sure you need to replace them. If that's the case, it WILL be worth the effort.
LUCK!
\BEST\LOU
Lou Crane, Sierra Vista, AZ
       Post #: 5
RE: Old plane caution - 8/15/2007 3:17:06 AM
Lou Crane
Status: offline
Oh, and yeah, mebbe a BTTW G21-35 is a bit much for a long-nose profile.
If you're in the market for a modern engine, an OS LA40, or better, LA46, is reasonable in price. The LA46 in particular is very little trouble to get working VERY nicely.
\BEST\LOU
       Post #: 6
RE: Old plane caution - 8/15/2007 7:44:17 AM
cutaway
Status: offline
It was just that goofy capped/notched 3/32 spar the Magician has. Unless the spar and cap are pretty hard stuff, you get a heavy stress point right at the end of the sheeting. If I ever scratch build another one, that scheme is going away.
(in reply to Lou Crane)
       Post #: 7
RE: Old plane caution - 8/17/2007 10:35:40 PM
cutaway
Status: offline
Added pic of rebuilt Magician to OP.
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU5
